Results 1 to 3 of 3
Thread: snow performance VAC25-MAF to use on MAP signal
  1. Member umphufu's Avatar
    Mar 17th, 2008
    In your moms closet
    My other ride is your mom
    06-11-2012 05:19 AM #1
    hey guys
    well i purchased a snow performance kit from a guy locally here in Namibia, but i wasnt informed that it gets its signal from the MAF, am i able to use this from the MAP as both use a 0-5v reading.
    the guy i bought it from says i can but at times i feel he's a bit clueless and is just trying to make money
    i need to have this resolved because in August im travelling to South Africa to get a Unitronics MAFless file, and if this wmi only works with MAF signals, im pretty scr3wed and wasted $550 on this
    CURRENT - 2004 MK4 GTI .:R - GT3071R vband, Pagparts SS manifold, FMIC, Custom CAI, Custom 3" DP, siemens Deka 630cc Injectors, FRC Water/Meth Stg 1 Kit, Unitronics 630 Mafless
    EX: 2000 MK4 GTI - SAC Conversion
    EX: 1992 CITI 1.3
  2. Member sabbySC's Avatar
    Dec 28th, 2009
    Toronto/Ottawa
    2003 GTI
    07-24-2012 12:33 AM #2
    Did you ever get this figured out?
    If not you can use this controller conected to your map sensor. Just meter the wires coming off the sensor itself, one will be ground, the other 5v and the third will be the variable signal, should be around 1.7v at idle and rise in voltage with boost.
    CTS gt3071r and more
  3. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    08-16-2012 07:16 PM #3
    run it via the boost tap..really simple...that's what i did since i am mafless. i use the same controller.
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
