Results 1 to 8 of 8
Thread: badly missing / barley running 1998 2.8 30V
  1. Semi-n00b
    Aug 20th, 2007
    boulder,co
    75 scirocco
    06-11-2012 03:19 PM #1
    badly missing / barley running 98 2.8 30
    its a 5 spd car with 146k, was running great then went down hill fast.
    I started with plugs, then plug wires. no help.
    tried 3 different coil packs, no different.
    cleaned the mass air flow sensor and it ran good for about 30 seconds than back to missing bad.
    runs the same plugged in or not.
    did a compression check , all good.
    any thoughts?
    bad mass?
    thanks,
    B
  2. Member koidragon1980's Avatar
    Jul 8th, 2011
    Astoria, NY
    2001.5 VW Passat V6 FWD
    06-12-2012 08:49 AM #2
    Quote Originally Posted by bfreehill View Post
    any thoughts?
    bad mass?
    thanks,
    B
    could be a bad MAF sensor if it runs the same plugged in or not. any CEL? get it scanned anyway and research any codes you find.
    any other work done recently that was unrelated to the issue?
    post any codes you get from the scan and take it from there.
    God bless the homicidal maniacs... they make life worthwhile. - George Carlin
  3. Semi-n00b
    Aug 20th, 2007
    boulder,co
    75 scirocco
    06-12-2012 10:58 PM #3
    I pulled PO302 misfire code but nothing else.
    With VAG-Com I observed misfires at idle on plug one,
    above 3000 rpm the misfire jumps around randomly to other plugs.
  4. Member koidragon1980's Avatar
    Jul 8th, 2011
    Astoria, NY
    06-13-2012 03:10 PM #4
    read through this thread: http://www.passatworld.com/forums/68...e-insight.html
    there a couple of ideas in there for you. if you use the google custom search bar on the passatworld site and search for "P0302 v6", you'll find more info and suggestions.
  5. Semi-n00b
    Aug 20th, 2007
    boulder,co
    75 scirocco
    06-13-2012 04:42 PM #5
    great thread, thanks for the link.
    tried my purge valve plug but no difference.
    however I also tried my mass again and it runs better without, and kinda drivable.
    this time got PO304, mis-fire on #4
    but in general its running better today, so weird.
    may remove my EGR and see if I can clean it, do the fuel filter, and do a little dance.
  6. Member koidragon1980's Avatar
    Jul 8th, 2011
    Astoria, NY
    06-14-2012 08:08 AM #6
    if it feels better without the MAF, then i'd definitely replace that sensor as well. running without a MAF should be causing things to get worse, not better.
  7. Member tryin2vw's Avatar
    Dec 29th, 2006
    Greensboro, NC
    99 MK3 and 98 MK3 2.0, '01 B5.5 1.8T
    06-15-2012 01:36 PM #7
    Have you checked the vacuum hoses?
  8. Semi-n00b
    Aug 20th, 2007
    boulder,co
    75 scirocco
    06-22-2012 09:23 AM #8
    So it was my fuel pump intermittently going out.
    replaced the pump, put the original coil pack and mas back on & all seems good.
