VWVortex.com - 97 jetta gl 2.0 no power to fuel pump when key turned
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 76
    Thread: 97 jetta gl 2.0 no power to fuel pump when key turned
    1. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      1997 Volkswagen Jetta GL
      06-11-2012 08:31 PM #1
      Hey guys i've been stuck without my jetta for about a week and can't seem to find the issue. I hooked a multimeter to the fuel pump and when my key is turned my fuel pump doesn't turn on. When i push start my car the pump has power and runs good. Could this be the fuel pump relay?
    2. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      06-15-2012 03:56 PM #2
      My check ENG light is on when I turn the key so its not my ECU, Also I tested the fuel pump voltage after poping the clutch to start it and it gets 12v. BTW its a 97 jetta GL 2.0 aba 5 speed.
    3. 06-15-2012 06:43 PM #3
      Ignition switch. Try it post back.
      Did you know that it's not pronounced Em Kay ? ALL OF THE CAR LOUNGE WILL BE HAPPY TO LET YOU KNOW THAT. SERIOUSLY. IT STANDS FOR MARK. DID YOU KNOW THAT? BEFORE THAT A1,A2, A3, ETC WAS USED. LIVE UP TO TCL STANDARDS BEFORE YOU GET ON MY ASS. THAT'S DISGUSTING.
      Example of TCL's standards
    4. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-12-2012 08:40 PM #4
      Hey guys, I changed my Ignition switch today and still no power to the fuel pump when the ignition is turned on.
      So far i've changed the following:
      Crankshaft Sensor
      Distributor Cap/Rotor
      Ignition Switch
      Any other suggestions guys? I'd hate to have to scrap the thing, its so fun to drive.
    5. 07-12-2012 10:13 PM #5
      Now I could feel safe saying change the relay #167.
    6. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-12-2012 10:19 PM #6
      Actually I changed that as well, but forgot to list it. Fuel pump relay right?
    7. Member sic_null's Avatar
      Jun 22nd, 2012
      Brick,NJ
      98 GLX VR6, 86 Mercedes 300D, 01 Jetta Wolfsburg
      07-13-2012 12:12 AM #7
      Just to clear things up. You are unplugging the connector to the Fuel pump and measuring Voltage. You have no voltage with the Key on/Engine off?
      But when you bump start it, you have 12v to the pump?
      Very odd. it is almost like your power wire to the fuel pump is only live when the alternator is pumping out voltage. Something is wrong with your Wiring possibly. I would definitely trace the circuit very carefully to rule out any problems such as a frayed wire or bad ground.
    8. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-13-2012 12:23 AM #8
      Yeah that's exactly whats going on, and yeah i will have to check the wiring out with a multimeter, but its weird because when its bump started it runs good.
    9. Member 87veedub's Avatar
      Oct 22nd, 2007
      Lancaster, PA
      400k b4 wagon
      07-13-2012 02:43 PM #9
      My car did not have power to the fuel pump with the key in the "on" position and had me tracing wires and all sorts of nonsense. Then I checked it while cranking and sure enough it has proper voltage.
      Quote Originally Posted by jbigs268 View Post
      Then wait till you can afford the CXs, buy them so your kid doesnt get shaking baby syndrome from the racelands
    10. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-14-2012 07:40 PM #10
      Yeah I've checked it while its cranking still nothing, any other suggestions? We put starting fluid to it and it wouldn't start so I'm thinking its something more than some faulty wiring.
    11. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-17-2012 08:29 PM #11
      So i noticed today while cranking the starter that my fuel pump relay is clicking rapidly when the key is turned. Anyone else run into this problem?
    12. 07-18-2012 03:08 AM #12
      Seems to be a pretty common issue, I ran into it myself. We back probed it and got schematics. Replaced relays, pumps, tried with different chip in ecu and nothing. We narrowed it down to a possible broken wire from ecu to fuse box, Some sort of grounding wire was broken somewhere along the line. Simple fix for me was to wire in a switch to manually controll the pump. When starting the car I could flick the switch on to get fuel to the motor and when it fired I turned the switch off. After that never had a problem with mapping or burning out the pump or anything like that. Be sure to always turn the switch off if you do take that route
      Sent from the mother ship
    13. Member Kenny13245's Avatar
      Aug 15th, 2009
      (717) PA
      88 cabby gone,98 Golf,94 Jetta gone, 13 Dodge Dart Ralley
      07-18-2012 05:35 PM #13
      im having the same problem myself as we speak. i changed all the wiring to the bay and it didnt fix and thing for me, my next step is replacing the wiring from the pump to the fuse box. i wish you luck if i figure anything out ill be sure to post back if i figure anything out myself GL
    14. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-18-2012 09:45 PM #14
      I took it to a shop today that does foreign cars, they told me that my distributor was bad. I have a new one and am having it installed tomorrow, ill let you know if its the problem.
    15. Member
      Mar 23rd, 2008
      N/A
      N/A
      07-19-2012 12:48 AM #15
      Quote Originally Posted by Irose123 View Post
      I don't think the shop knows what they're talking about.
      If you scan the engine not running, you always get a engine speed sensor fault, and a cam position sensor fault. The engine does not even need the cam sensor to start and run (on a car that is working properly, you can unplug the cam sensor, and the engine will still start and run), the ECU will run a default setting.
      There are two different circuits that power the fuel pump. One is activated when you turn the key to the "START" position (bad ignition switch or ignition switch start wiring and the car will not power the fuel pump when the key is turned to "START". When you let go of the key, and the ignition switch drops down to the RUN position, the fuel pump is run off the ECU, and relies on sparkplugs impulses (no pulses to the sparkplugs means no fuel pump power).
    16. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-19-2012 12:11 PM #16
      Well they had the car start with the ignition 4 times while they were diagnosing it and apparently they were tapping on the distributor cap.
    17. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-19-2012 08:43 PM #17
      Well I changed my Distributor and coil and still nothing, anybody else have any suggestions?
    18. Member Kenny13245's Avatar
      Aug 15th, 2009
      (717) PA
      07-19-2012 10:39 PM #18
      im still fighting with the same problem myself so far ive replaced the wiring from the bay to the fuse box, fuel pump, distributor, coil, cap and rotor, plugs and wires, Ignition switch, ecu, fuel rail and injectors, and the crank sensor. replacing everything listed hasnt helped me. hopefully one of us can get it figured out.
    19. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-19-2012 11:13 PM #19
      How did you go about putting that switch into your fuel pump ObeyJettamk3 ?
    20. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-19-2012 11:58 PM #20
      Yeah hopefully we can figure out a solution. I'm going to take it back to the shop that looked at it and have them look it over again. I'll let you know if there is any good news.
    21. Member Kenny13245's Avatar
      Aug 15th, 2009
      (717) PA
      07-20-2012 02:27 PM #21
      bump
    22. Member Kenny13245's Avatar
      Aug 15th, 2009
      (717) PA
      07-22-2012 11:01 PM #22
      any progress ?
    23. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-23-2012 12:02 AM #23
      I resurfaced a few grimy looking grounds and still nothing
    24. Member Kenny13245's Avatar
      Aug 15th, 2009
      (717) PA
      07-23-2012 12:08 AM #24
      im about to head over you garage tonight yet and see if i cant get anywhere. ill reply with any progress
    25. Junior Member
      Jun 4th, 2012
      Cadillac, Michigan
      07-23-2012 01:17 AM #25
      Sounds good man, I plan on going down tomorrow and having the shop look it over again. I'll let you know if there is any headway
