Page 4 of 13 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 106 to 140 of 428
Thread: APR K04 Build experience 2012 GLI bad software?
  1. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    2011 Jetta TSI/APR K04
    07-21-2012 12:47 AM #106
    Back to zero....... New misfire
    Sent from my GT-I9100 using Tapatalk 2
    2011 Jetta TSI
    APR K04
    Aug 30th, 2009
    Santo André SP Brasil
    Passat Wagon 2.0 TSI 09; APR K04 ;carbonio; DP APR;cat 200 cels inox;paddle shifts; VCDS;
    07-21-2012 12:10 PM #107
    Quote Originally Posted by fea30boy View Post
    I was told you got new misfire yesterday night. Holy s***..,Once again.
    Suggestion: run today, and pay attention at temp.
    Only real change between yesterday during the day, and during the night, was a big drop in outside temp.
    Meanwhile, lets see if get some answers from APR....Or maybe one of these expert guys in the forum can get you a solution!!!!!
  3. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    07-21-2012 12:27 PM #108
    Hope so..........
    2011 Jetta TSI
    APR K04
  4. Junior Member bmllr8's Avatar
    May 18th, 2012
    Charleston, SC
    2012 GLI
    07-22-2012 11:05 AM #109
    One of the few threads I have read all the way through not for information, but for entertainment purposes. Can't wait to see what happens next.
  5. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    07-22-2012 11:12 AM #110
    Quote Originally Posted by bmllr8 View Post
    Entertainment?................... man, this is for crying purposes
    2011 Jetta TSI
    APR K04
  6. Member
    Aug 30th, 2009
    07-22-2012 12:52 PM #111
    Hi,
    How was yesterday? Still getting misfires? Have you talked to someone from APR?
    I did some runs in the 104 program (I know that I don´t have to) just to see the diff between your logs (K04) and mine (stage 2+). Like I thought, too mucho timing advance stage 2+ that it´s impossible to keep running.......timing pull around 12 most of the time. I am luck to haven´t broken anything.
    Once again I hope you get a solution asap.
  7. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    07-22-2012 02:59 PM #112
    Quote Originally Posted by zucchini View Post
    Hi,
    Yesterday I did 4 runs...in D, S, Tip...........and everything was ok, no misfires! I guess that the cause of the last misfire was that the outside temperature!
    2011 Jetta TSI
    APR K04
  8. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    07-22-2012 03:01 PM #113
    Hi,
    104 is really too agressive!
    2011 Jetta TSI
    APR K04
  9. Junior Member bmllr8's Avatar
    May 18th, 2012
    Charleston, SC
    2012 GLI
    07-22-2012 04:03 PM #114
    Let me clarify, the entertaining ppart was watching Schrottplatzer's posts and subsequent forum responses. I do sympathize for your situation.
  10. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    07-22-2012 04:29 PM #115
    Thanks man..............
    2011 Jetta TSI
    APR K04
  11. Member
    Aug 30th, 2009
    07-22-2012 06:27 PM #116
  12. Member simon-says's Avatar
    Oct 20th, 2007
    Portland,Oregon
    1978 Miami Blue 16v Rabbit on side drafts, 1980 Jetta Coupe,1988 Vanagon Wolfs., 2003 TDI Golf, and,
    07-25-2012 10:42 AM #117
    The OP has had legitimate issues with the tune of his car. And you all bash him.
    And now another fellow with the exact same issues (sounds like it to me) and you all want to sympathies his problem.
    Both guys are victims of the of the high and all mighty APR product. No other people here are coming out with the same problem publicly. But I can assure you all that there are several others with the same problem. I have gotten forwarded PM's from others. Trust me when I say. APR is aware of the problem and they havent been able to identify it.
    So in closing.
    There is nothing wrong or bad with the coil packs/ plugs/ MAF./fuel, OR HARDWARE. Its a software issue.
  13. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    07-25-2012 10:50 AM #118
    Quote Originally Posted by simon-says View Post
    So in closing.
    2011 Jetta TSI
    APR K04
  14. Member
    Aug 30th, 2009
    07-25-2012 02:14 PM #119
  15. Junior Member
    Oct 31st, 2011
    Arm-Chair Forum Wizarded 2010 ko4'd 4Dr GTI
    07-25-2012 02:28 PM #120
    So in closing.
    Are you the OP's mom?
    Outside of some goofy causal logic how is it a software problem?
    Everything the op presented as a problem in this thread says coil problem. The thing that needs definition in this thread is misfire.
    The car can misfire without ever tripping a code. No combustion cycle is 100% perfect. The misfire counter incrementing is different than the ecu detecting a problem like the OP's and flagging a code. And disabling cylinder(s).
    Instead of blaming the software as a problem since you can't make the stock software run and fuel 20 psi of boost, you guys need to be looking at the crank and cam position signals on an oscilloscope to see what is happening under load both with and without the software tune. And make some informed Descisions instead of accusatory guesses.
  16. Member sh{}e's Avatar
    Aug 6th, 2004
    Maryland
    2012 GLI Autobahn
    07-25-2012 02:31 PM #121
    So in closing.
    How do you know it is not the hardware?
    The OP has been receiving feedback concerning his issue. He came back and said that his problems went away after flashing the car back to stock. There is more testing to do because that could be attributed to the flash creating more load on the components. Weak components being problematic is not a new issue when chipping a car. His next step is to use another software vendor.
    In the end, we have been giving his logical starting points to diagnose his problem. I gave him a list to start with, which included flashing back to stock. As a group, we can only go by what he shares with us. Is the information accurate on his part? Who knows? We will never know how "thorough" Schrottplatzer was in his tests.
  17. Member NEW2B's Avatar
    Nov 30th, 2006
    USA/SALONIKA
    09 GTI - 06 PASSAT
    07-25-2012 05:48 PM #122
    has similar issues right after k04 install.
    changed all 4 coils, problem was solved.
    2009 GTI -APR K04- FULL ECU- A&L 3" CATLESS DP - INTAKE --FORGE DV.
    STAGE2 --13.9@101---6SPEED , ON STOCK 17" --- USA, NJ
    2006 PASSAT-AUTO APR STAGE 2+ APR HPFP -DRIVE GEAR SPRINGS - APR TBE- NS PULLEY
    FORGE AUTO INTAKE- 18"ACE DIMENSION /PROXY4.--------GREECE SALONIKA.
  18. Junior Member bmllr8's Avatar
    May 18th, 2012
    Charleston, SC
    2012 GLI
    07-25-2012 07:12 PM #123
    Quote Originally Posted by sspcivic31 View Post
    I started losing sympathy and interest somewhere near post 44 and ending with post 73. There are plenty of smart people on here and in the beginning, people where willing to offer suggestions for helping. However a forum, and the world in general, can only take so many arm chair wizard and when I was in college statements before they turn on you. Learn how to interact with the community and you will be rewarded. I may be a noob on this forum but I learned this truth a long time ago.
  19. Member jspirate's Avatar
    Jan 15th, 2011
    Virginia
    2011 CC 6MT
    07-25-2012 09:07 PM #124
    So in closing.
    I agree. Well said
    Daily | Weekend | Project
  20. Junior Member
    Jul 20th, 2012
    São Paulo, Brasil
    07-27-2012 07:48 PM #125
    I'm starting to get tired of APR! Customer Support very flawed, perhaps there in the U.S. to work, but here in Brazil is proving a shame and many people who were thinking about preparing their cars with the APR, seeing what has happened here are really thinking twice!
    2011 Jetta TSI
    APR K04
  21. Member
    Apr 4th, 2012
    Sacramento, CA
    2012 GLI Autobahn DSG Black Metallic Pearl
    08-09-2012 11:45 AM #126
    any updates from OP?
  22. Member T0neyDanza's Avatar
    Apr 25th, 2007
    Langley AFB VA
    MK5 GTI, 2012 cc (wife's car) and 4 previous VW's
    08-11-2012 12:44 AM #127
    Sounds to me like he re-enlisted... Got a bonus. bought a car, bought all his new parts and said hey install this... now has no money left to buy the **** that matters. He dropped a ton a money on all this stuff with wheels and suspension etc, yet later complains at the price of spark plugs.
    APR is a stand-up company... Obviously they know what they are doing or they wouldn't be one of the largest names in the tuning industry. Stop being hard headed and listen to people here. I seriously wanted to quote so many peoples replies to you but could not stop reading through your whiney ass responses Mr. associates degree. BTW just because you sat through a few night classes, and rebuilt your dad's 1976 fastback whatever ( yes I made that up) does not mean you know everything about cars. The guys that do this for a living every day ie. the installers that did the work to your car, VW techs, and even the guys at APR that build ACTUAL race cars on these platforms still can't figure your car out based on what small amount of info you have given them.
    I'd take 90% of the peoples advice on here and try it. Stop pointing fingers at APR. Oh and the NEW ECU thing... seriously. You think they let you just try it out as a guinea pig. I'm sure their R&D guys took care of all the testing before releasing the product. I'm not saying their **** don't stink and it can't have flaw because we all know that's not true. I'm just saying stop being stubborn and pointing fingers. Swallow your pride and actually open your hood and start from scratch as if the k03 were still in there... With your vast amount of automotive knowledge it should be pretty easy from there. God I hope it's something simple that's just not plugged in all the way... yet you don't realize until you really break something and then warranty doesnt cover it.
    1. yes I'm an APR fanboy
    2. rant over.
  23. Member T0neyDanza's Avatar
    Apr 25th, 2007
    Langley AFB VA
    08-11-2012 12:46 AM #128
    Weird. I PM'd Arin today about some stage 3 questions and he responded within minutes. We actually had a good conversation back and forth about some technical crap I had concerns with. Now if he were out of country for a while I could understand a delay, but I have never had a problem ever being able to get a hold of them. As a matter of fact he is online right now. WEIRD!
  24. Member NEW2B's Avatar
    Nov 30th, 2006
    USA/SALONIKA
    09 GTI - 06 PASSAT
    08-11-2012 05:41 AM #129
    Quote Originally Posted by Schrottplatzer View Post
    I took my list and car to Double J Motorwerks in Portland. They did a great job putting the below together in very quick time:
    2012 GLI: Volkswagen Racing Intake/Induktion Motorsports pipe. APR Stage III K04 kit, S3 FMIC, Techtonics Tuning 2.5" downpipe, Techtonics Tuning 2.5" Dual Borla exhaust, H&R Springs
    why did you go with a 2.5" downpipe?
    usually apr users will go with the recomended 3" downpipe.
  25. Member
    Aug 30th, 2009
    08-11-2012 05:12 PM #130
    Quote Originally Posted by T0neyDanza View Post
    Good for you! And so what?
  26. Member sh{}e's Avatar
    Aug 6th, 2004
    Maryland
    2012 GLI Autobahn
    08-12-2012 11:00 AM #131
    I believe he is stating the fact the OP said their customer service sucks, which is not true.
  27. Member T0neyDanza's Avatar
    Apr 25th, 2007
    Langley AFB VA
    08-12-2012 10:37 PM #132
    Quote Originally Posted by sh{}e View Post
    Thank you.
    I thought it was obvious with the quote that I posted above my comment.
  28. Member Schrottplatzer's Avatar
    Jun 13th, 2009
    1987 Junkyard Golf, MKV Jetta, 2004 V8 Toureg, 2012 GLI
    08-13-2012 12:22 AM #133
    I spoke with APR this week and they are now acknowledging that there is a problem with this particular combo on some 2011 CCs and 2012 GLIs (same computer). They are working on a solution, but are lacking a test car at the moment. The customer service guy I spoke to was great. He didn't fix my problem, but was honest and up front about it. So now the waiting continues...
    It has nothing to do with spark plugs or coil packs.
  29. Member
    Aug 30th, 2009
    08-13-2012 11:33 AM #134
    We already know about here in Brasil, and APR is doing a great job helping people like fea30boy to solve it.
    What makes me angry, is that there are some people that think they know everything, and keep posting BS......
  30. Member
    Jul 16th, 2012
    Dirty South
    Mk6 GLI K04, KLE-650
    08-13-2012 03:40 PM #135
    Good to know.. Hopefully a solution is found soon.
  31. Junior Member
    Aug 10th, 2012
    Kitchener, Ontario
    08-13-2012 09:41 PM #136
    It would be nice to hear something from APR on this issue. I am considering a 2013 GLI and I wanted to upgrade right away to a Stage II with intake and downpipe. I am now somewhat concerned that this is not a select issue. I may contact APR on my own....
  32. Member Schrottplatzer's Avatar
    Jun 13th, 2009
    08-14-2012 10:11 AM #137
    I haven't heard of anyone with the stage II problems on the GLI, it's just the Stage III K04 kit that seems to have the problem.
  33. Junior Member
    Aug 10th, 2012
    Kitchener, Ontario
    08-14-2012 10:50 AM #138
    A few threads in the Jetta VI Section:
    http://forums.vwvortex.com/showthrea...e-(-)-2200-RPM
    http://forums.vwvortex.com/showthrea...7984-VW-vs-APR
  34. Member Schrottplatzer's Avatar
    Jun 13th, 2009
    08-14-2012 08:38 PM #139
    Quote Originally Posted by srobin01 View Post
    Damn, I guess it's worse than I thought.
  35. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    30 S 5th Ave, Lebanon PA 17042
    MK6 GTI S3+, MK6 Golf R, MK4 R18, Q5 3.0T
    08-17-2012 05:01 PM #140
    I sympathize with your issues. As many cars that we have done we have not ran into this but I also don't remember doing a 1767 ecu with one either.
    Also not trying to be overly critical but I saw it mentioned a couple times, StageIII is not K04
    APTuning LLC, 30 s 5th Ave, Lebanon PA 17042, (717)272-0916
    aptuning.com - tom@aptuning.com - Facebook - Twitter
    APR Stocking Master Distributor - United Motorsport Distributor
