VWVortex.com - Ordering a replacement key for VW Jetta
    The Car Lounge
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 42
    Thread: Ordering a replacement key for VW Jetta
    1. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 08:13 AM #1
      2004 Jetta. Anything I need to look out for in ordering a key fob. Alternatives to getting it cut and programmed at the dealership? Thanks
      I should have stated that I currently have no key in my possession, it is lost in my house or was stolen along with my by some girls that are not too fond of me while I was under the influence of ....
      8V///
    2. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      06-12-2012 08:17 AM #2
      Quote Originally Posted by stormtroopered View Post
      There are a few locksmiths that can do keys like that, but they're unusual. How much is it to do at the dealership? It may not be worth the hassle trying to find an aftermarket solution when you can just walk into the dealership, give 'em your paperwork and voila! Instant key!
    3. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 08:20 AM #3
      Sitting in a Business Law class right now, about to call on break and find out, I believe I've read up to $350 at the stealership, had this predicament a couple of months ago. Regardless, I need a spare so its time to go forth with it take the shot to the wallet.
      8V///
    4. Member jasonknezo's Avatar
      May 16th, 2002
      Downingtown, PA
      06-12-2012 08:21 AM #4
      2004 jetta will have an immobilizer. Will need some registration copies and drivers license generally to order the key at the dealer. At that point the key will need programmed to the immobilizer (generally 1 hr shop time). Dealer is pretty much only spot to go.
    5. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 08:25 AM #5
      http://www.ecstuning.com/Volkswagen-...Key/ES1866570/
      Would getting the "guts" off of ebay and ordering this part be an alternative to buying the key from the dealer?
      8V///
    6. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      06-12-2012 08:26 AM #6
      Quote Originally Posted by jasonknezo View Post
      $350? Ouch.
      I remember back in about 1990 having to tell people that their 928 keys were $75.00! Of course, they were laser cut on 3 planes (tumblers at three angles - six cuts if you count both sides of the key) and had to come from Germany after proof of ownership. There were no electronics involved back then. Well, other than the watch battery and the tiny light bulb in it!
    7. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 08:31 AM #7
      You wouldn't have happened to be Memphis Raines younger brothers friend Tumbler would you?
      I know this situation is killing me!
      8V///
    8. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      06-12-2012 08:33 AM #8
      If you're talking to me, no. I worked at a Porsche dealership parts department in '89-'90.
    9. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      '03 BMP 20th GTI, '84 TD Jetta
      06-12-2012 10:02 AM #9
      This place can cut keys for you: http://sidewinderkeys.com/
      We just had a key cut for our '01 through there. Cheaper than the dealer. We have a buddy who is going to help us match the immobilizer too. No dealer needed!
      Quote Originally Posted by TM87 View Post
      VW-making mechanics out of owners since 1957.
      The project - '84 Jetta 1.6TD
      The Wheelbarrow - '82 Rabbit Pickup
      Hers - '03 BMP 20thAE GTI
      His - '16 GLI SE
    10. Member 2.0T_Convert's Avatar
      Mar 23rd, 2009
      Jerzey
      06-12-2012 10:07 AM #10
      When I had my Honda I bought a flip key shell on ebay for a cheap, swapped the guys, then had the dealer cut it for $8.
      I take it your fob isn't working so you need a whole new key with internals? $350 sounds expensive
      Sent from my tablet while sipping weak drinks over fancy brunch with a view
    11. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 10:22 AM #11
      The problem is the key is lost in my house. I'm moving out in a month so I figure what better time to get a spare, right? Talked to the dealership, $165 for the key, $53 for programming. Problem is that the car needs to be at the dealership for programming, I am 22 miles away from the dealership. Haven't even begun to call towing companies yet.
      I can get a blank with no transponder for $45 from ECS, does anyone know if I get the lower half off of eBay with the buttons can they clear that and program it to my car?
      8V///
    12. Member Ben.Reilly's Avatar
      Jun 20th, 2008
      RI
      2015 Jeep Wrangler
      06-12-2012 10:28 AM #12
      Does he look like a boxer?
      F1
      RED BULL Racing Formula One
      Final Gear
      "Here's a couple things America got right; cars and freedom"
    13. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 10:34 AM #13
      8V///
    14. 06-12-2012 11:01 AM #14
      My dealership has several signs up that clearly state they will not cut keys that are not bought from them.
    15. Member Shmi's Avatar
      Mar 25th, 2009
      Fairfax, VA
      2014 Fiesta ST, 2004 Accord EX, 2003 LS430
      06-12-2012 11:30 AM #15
      Cutting is to be different for every dealer. The Audi dealer i work at (I work in Parts), we can't even cut keys, they are cut at the warehouse and sent with the rest of the parts we order.
      The electronic fob CAN be programmed/reprogrammed to another car, as long as the part number is correct (i.e. as long as it's the right key.) This is essentially how it works when you order a 2nd or 3rd key. You bring all the other keys in, and they all get reprogrammed sequentially.
      That said, keep in mind that if you order a new key, get it cut and programmed, if you ever find the one key you lost, it won't work anymore. It'll still open doors/trunk/glove box, but won't start the car.
    16. Geriatric Member Turbio!'s Avatar
      Feb 21st, 2005
      Colorado Springs, CO
      '13 Subaru Outback
      06-12-2012 11:36 AM #16
      Please ask model specific questions in the appropriate model specific forum.
      IPRO Meat-Director and High Minister of Terror-Grilling and
      Quote Originally Posted by caj1 View Post
      the magniloquent messiah of the butthurt former VW owners.
    17. Member The Swami's Avatar
      Oct 16th, 2001
      Washington, DC
      Loaded 2012 BMW 550xi M-Sport, Previous owner of 5 Passat 4 Motions; including a W8 and 3.6
      06-12-2012 11:37 AM #17
      8 years ago there was a Class-Action Lawsuit settlement dealing with the issue of Smart-Key replacement. Check out the following documents:
      VW/Audi Settlement Notice
      List of Authorized Independent Repair Shops that can cut/program VW/Audi Keys.
      I hope this helps!!
      Will aka The Swami
    18. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 11:42 AM #18
      Overnight parts from... Germany, must be used. I do not have the key pattern to copy from at the dealership, hence the problem I'm in, so I must get my car to the dealership and order a new key, whatever screw it, its only money.
      8V///
    19. Member mhjett's Avatar
      Oct 16th, 2000
      Northern Virginia
      '08 VW Jetta SE 2.5
      06-12-2012 11:45 AM #19
      Quote Originally Posted by The Swami View Post
      I hope this helps!!
      Will aka The Swami
      Was going to post that.
      The dealer can probably cut the key from the VIN number but they can't program the key without the car.
      2008 VW Jetta SE 2.5
      1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
    20. Banned hognhominy's Avatar
      Jan 31st, 2005
      sleeping at the overlook
      53 Cylinders & 6 turbos
      06-12-2012 11:50 AM #20
      As an independent I can program them but i still order the key and upper by vin from my local stealership, the remote/lower portion i buy from a distributor, and program them all together, and as stated if you ever find the old key it will be locked out of the immo, only keys present at time of programming will start the car.
      a full set of keys (2 remotes, one flat key) are a 500$ bonus when i look at used VW/Audi
    21. Junior Member stormtroopered's Avatar
      Oct 20th, 2010
      2004 Jetta
      06-12-2012 11:57 AM #21
      I began reading the key settlement notice, I'm between classes so time limited, if I printed that out and brought it to the dealership do you think they would offer me any discount? Also I talked to the dealership again about bringing in a blank key and they said the only way is to order a new one. I'm an Automotive Aftermarket major at Northwood, so I understand the run around and malarkey that takes place at a dealership. Not a bad thing, I'll eventually be working in a service department somewhere.
      8V///
    22. Member personman's Avatar
      Sep 24th, 2008
      TX
      03 Golf, 15 CX-5
      06-12-2012 12:07 PM #22
      I've had to replace keys for mkiv's on 3 different occasions, sent you a pm about the best way I've found to do it.
    23. Member Egz's Avatar
      May 30th, 2002
      Virginia
      2006 Ford Fusion 2.3 Turbo, 2016 Ford Fusion Hybrid
      06-12-2012 12:14 PM #23
      Are VWs like Fords, where you can program your own keys if you have at least 2? Or is the owner 100% dependant on the dealer?
    24. Senior Member Chris16vRocco's Avatar
      Apr 29th, 2006
      Maryland
      Scirocco x2, QSW, FJ40, E30, S4, W123, 745GLE TD
      06-12-2012 12:23 PM #24
      They might give you negative 20% off.
      Nil Satis Nisi Optimum
    25. Senior Member Chris16vRocco's Avatar
      Apr 29th, 2006
      Maryland
      06-12-2012 12:23 PM #25
      Quote Originally Posted by Egz View Post
      It has to be done through VW's computers.
