VWVortex.com - Bulbs "burning out" consecutively
    The Car Lounge
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 63
    Thread: Bulbs "burning out" consecutively
    1. Member Time for a GTI's Avatar
      Apr 25th, 2006
      NH
      '12 Golf R
      06-12-2012 02:23 PM #1
      Well I tried this in the MkV forum without much luck. We'll see what TCL has to say I guess. The question is this: Is it possible that these bulbs keep actually burning out one after another after another or is it more likely some electrical issue that's causing them to go? The dealer keeps telling me that it's a coincidence but I find that hard to believe.
      Quote Originally Posted by Time for a GTI
      So the wife drives a 2009 Jetta. It has roughly 40K on the clock. In the last 2 months or so we've had a number of lights "burn out".
      First, one of the brake lights went. I replaced it myself.
      Second, a side marker went. I thought it was odd that two lights would go within a couple days so I ran a fault scan with the VagCom. Something to the effect of "Intermittent electrical signal" came up (can't find the log...I think I may have lost it when my hard drive fried). Because of the oddness we brought it to the dealer.
      Dealer replaced sidemarker and oh, by the way, you had another 2 rear lights out. Replaced all the bulbs for me without asking (for $50 ). The dealer states it's normal though. They see it all the time...bulbs going all in close proximity to each other. Sounds fishy to me since it's now 4 lights in the course of 3-4 weeks or so. But hey, what do I know?
      Driving away from the dealership her dash light comes back on. She drives back, oh you have a headlight out. We'll change that for you too...no worries though, no charge. No, no you don't have an issue...this is normal...we swear.
      Since then I've changed the driver's side DRL (last week) and today she called me to tell me her passenger side DRL is now out.
      That's 7 bulbs in 2 months. That can't be normal can it? What does the wisdom of the MkV forum say?
      My main question is whether or not it's possible the bulbs are going or is there some electrical issue?
      Scanned the car again just now with the passenger side DRL out. This is the return from the lighting section.
      Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
      Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
      Component: Bordnetz-SG H54 2602
      Revision: 00H54000 Serial number: 00000001102043
      Coding: 14058E234004150007140000001400000008730B5C00012000 0000000000
      Shop #: WSC 00066 000 00000
      VCID: 32600564AD34409
      Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
      Component: Wischer 171008 021 0501
      Coding: 00038805
      Shop #: WSC 00066
      2 Faults Found:
      00978 - Lamp for Low Beam; Left (M29)
      010 - Open or Short to Plus - Intermittent
      Freeze Frame:
      Fault Status: 00101010
      Fault Priority: 1
      Fault Frequency: 1
      Reset counter: 154
      Mileage: 77648 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 14.30 V
      ON
      ON
      OFF
      OFF
      ON
      00979 - Lamp for Low Beam; Right (M31)
      Freeze Frame:
      Fault Status: 01101010
      Fault Priority: 1
      Fault Frequency: 1
      Reset counter: 118
      Mileage: 78964 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 14.00 V
      ON
      ON
      OFF
      OFF
      ON
      Why two faults? Would one of them still be from the one I replaced a couple days ago? The cluster indicator did go away (immediately) when I replaced it.
      Also, not sure what this is all about.
      Address 19: CAN Gateway Labels: 1K0-907-530.lbl
      Part No SW: 1K0 907 530 Q HW: 1K0 907 951
      Component: J533 Gateway H07 5063
      Revision: H07 01 Serial number: 060908F2000273
      Coding: ED807F060003021002
      Shop #: WSC 01084 444 89147
      VCID: 356A3E785C5A571
      1 Fault Found:
      01044 - Control Module Incorrectly Coded
      000 - -
      Freeze Frame:
      Fault Status: 01100000
      Fault Priority: 1
      Fault Frequency: 254
      Mileage: 75497 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 00:53:37
      Quote Originally Posted by @McMike View Post
      We can not be trusted.
    2. Banned seadoo2006's Avatar
      Feb 4th, 2008
      Mayfield Heights, OH
      04 Audi S4 Avant 6MT
      06-12-2012 02:34 PM #2
      There's a good reason for this:
      VW sucks at making cars with working light bulbs.
      Seriously, drive around and tell me how many VWs have a tail light out compared to any other car manufacturer ... I have an album on Facebook devoted to "MK4s with burnt out tail lights" ... pretty funny shiate.
      Oh, and it's not just me who has noticed:
      http://forums.redflagdeals.com/volks...lights-785059/
    3. Member VwG60Kid's Avatar
      Jan 27th, 2000
      Singapore
      1992 Corrado SLC
      06-12-2012 02:42 PM #3
      there is truth to the vw sucks at making cars that don't burn out bulbs... every dub i have owned has gone through bulbs at 10x the rate of any other car I have owned.
    4. Member VR6 GLX Man's Avatar
      May 19th, 2008
      El Centro, CA
      1994/VW/JETTA/GLX 2014/Ford/FIESTA ST
      06-12-2012 02:45 PM #4
      I currently have two bulbs out in my jetta, im part of the burnt out bulb club also I guess.
      VRSociety #293
    5. Member Time for a GTI's Avatar
      Apr 25th, 2006
      NH
      '12 Golf R
      06-12-2012 02:47 PM #5
      I drove a MkV GTI for 6 years and I can't recall a single bulb burning out.....
      So what is the correct course of action? Just keep replacing the bulbs? There's no faulty electrical business going on behind the scenes that's causing it?
      edit: also keep in mind we're talking about a 2009 here...not a MkIV or earlier lighting shenanigans
    6. Member VwG60Kid's Avatar
      Jan 27th, 2000
      Singapore
      1992 Corrado SLC
      06-12-2012 02:48 PM #6
      i keep a complete set of bulbs in my corrado at all times for just that reason... have two bulbs out right now that i haven't gotten around to fixing yet though... drivers side parking light and passenger side license plate light. I think alot of the problem in the CE2 cars was lazy ass wiring... running all the power for the headlights THROUGH the headlight switch for instance.
    7. Banned seadoo2006's Avatar
      Feb 4th, 2008
      06-12-2012 02:51 PM #7
      Quote Originally Posted by Time for a GTI View Post
      Yup ... pretty much what I did ... I used to keep a small box in the spare wheel well with extra bulbs when I owned my MK4 ... two sets of every bulb the car had ... headlights, running lights, tail lights, brake lights, turn signal bulbs, 194s for the repeaters and city lights, and a couple plate lights ...
      Part of owning a VW my friend ...
    8. Member someguy123's Avatar
      Sep 30th, 2005
      The Financial Lounge
      Handed in my car enthusiast 'card'.
      06-12-2012 02:52 PM #8
      VW, more bulbs than you can replace pal.
    9. 06-12-2012 02:55 PM #9
      My 2006 MKV keeps burning out the inside bulbs of the "circle" brake light. Every 6 months i'm replacing both inners, no clue what's up with that yet. I've owned VW's for 15 years now and generally i find that they go through bulbs more than any other car.
      On my B5 passat it was my H7's, barely used them and when i did, one of them would be out. Expensive but hey at least they were easy to change.
      My mk4 gti, city lights always burning out. PITA to change so I would leave them til I had a headlight or high beam go out to make it worth my effort.
      on my MK2 it was the bumper signal bulbs. Couldn't make contact with a ground with anything but oem bulbs and even then, i'd hit a bump and out would go the light parking light. I eventually cut these off and wired in some good old GM flashers.
    10. Member Time for a GTI's Avatar
      Apr 25th, 2006
      NH
      '12 Golf R
      06-12-2012 03:02 PM #10
      Quote Originally Posted by someguy123 View Post
      vroom vroom
    11. Member BobL2438's Avatar
      Apr 29th, 2006
      SL,UT
      '17 Tundra CrewMax, '13.5 GLI Autobahn, 1967 Shortbed Chevy C10
      06-12-2012 03:03 PM #11
      Quote Originally Posted by maxxam View Post
      I have the same situation with my 2006 MKV... I keep a set of bulbs in my glovebox because its only a matter of time after the first goes out that the others will too.
    12. Member Egz's Avatar
      May 30th, 2002
      Virginia
      2006 Ford Fusion 2.3 Turbo, 2016 Ford Fusion Hybrid
      06-12-2012 03:05 PM #12
      And I thought GM was bad with their DRLs.
    13. 06-12-2012 03:13 PM #13
      Never had problems with my MkIII or MKIV GTIs. B5.5 Passat only had a tail light go out once. Our 97x though had serious lighting gremlins... taillights, and recurring DRL's (including melted connectors and bulb bases). No clue as to the OP's issue... a recurring burnout might indicate short, but different bulbs who knows...
    14. Member
      Jun 2nd, 2005
      the burgh
      04.5 blue lagoon gli, 1976 bmw 2002, audi TT(project)
      06-12-2012 03:23 PM #14
      yep my mkiv gli def is eating thru bulbs, and when a bulb is out does your traction and abs light come on, because mine are, but when I replace the bulb the lights go away on my dash. I have replaced all the bulbs and as far as I know none are out besides possibly the 3rd brake light and possibly the liscense plate light, maybe thats why those stupid abs and traction lights are on...hmmm
    15. 06-12-2012 03:43 PM #15
      I don't see this around here at all nor did I ever experience this on my MKIIIs, MKIV or MKV GTIs. The ones that always have burned out bulbs are the Chevy/GM trucks with the small running light, always the passenger side it seems.
    16. Member rbloedow's Avatar
      Aug 14th, 2003
      Warner Robins, GA
      2016 Chevy Colorado LT 4cyl, 2015 Audi A6 2.0 Premium Plus
      06-12-2012 03:57 PM #16
      Ever try bulb grease? I had the same thing happen in my previous car - a friend told me to use bulb grease because there was a little moisture in the headlight.
      After the grease, the problem was solved.
    17. Member
      Jun 2nd, 2005
      the burgh
      06-12-2012 04:01 PM #17
      I have used the bulb grease on the bulbs I have had to install, I think one of them burnt out relatively quickly but it couldve just been a different bulb...did other people get not a check engine light but the combo of the ABS/traction light on when they had bulbs out or was that just me??? on mkiv that is
    18. Member Time for a GTI's Avatar
      Apr 25th, 2006
      NH
      '12 Golf R
      06-12-2012 04:04 PM #18
      Quote Originally Posted by rbloedow View Post
      That's not like blinker fluid, is it?
    19. 06-12-2012 04:05 PM #19
    20. Member BetterByDesign's Avatar
      Sep 7th, 2004
      morgan hill, ca
      E46 320, MK IV GTI
      06-12-2012 04:07 PM #20
      I have all kinds of bulbs, tools, electrical tape and plastic bits in my trunk. Are you new to VW or something?
      ______________________________________________
    21. Member Time for a GTI's Avatar
      Apr 25th, 2006
      NH
      '12 Golf R
      06-12-2012 04:12 PM #21
      Quote Originally Posted by BetterByDesign View Post
      Nope. You new to being smug?
    22. Member WhitePoloCT's Avatar
      Jul 28th, 2005
      Cape Town WC South Africa
      '09 Fiat Bravo, '05 Honda S2000
      06-12-2012 04:27 PM #22
      I had a MkII Golf that would burn out the left hand side tail lamp quite regularly. Then I had a Polo that would do the same for the right hand side tail lamp. My fathers MkIII Jetta would burn out the left side tail lamp bulb. My Cabrio has burnt out one left side tail lamp bulb.
      Let's just say I like my women like I like my cars - fast, cheap, kinda ugly and beaten up, unreliable, dangerous, unwanted....
      4 coilpacks, 2 gearboxes and counting...
    23. Member AWDTurboLuvr's Avatar
      Dec 29th, 2003
      Montreal
      2003 Audi A4 1.8T
      06-12-2012 04:35 PM #23
      I had this problem with our '03 Audi A4. It's their crappy bulbs that they stock at the dealership. Once the free-service period was over and I replaced the bulbs myself, they last much, much longer.
    24. Member koolkevin43's Avatar
      Aug 19th, 2006
      Hollywood East
      85 GTI, 92 GTI 16V, 02 GTI 1.8t, 93 B3 Passat GLX Wagon, 91 LA5T Golf, 04 BMP .:R32T, 99.5 MKIV TDI
      06-12-2012 04:41 PM #24
      I've never had a bulb burn out on my MKII, MKIV, or my B3 Passat. Wait, scratch that. I had to replace a license plate bulb on the Passat that looked old enough to be the original from '93.
    25. 06-12-2012 04:48 PM #25
      What do you think that big storage compartment in the trunk is for? It's for replacement bulbs.
      I think I've replaced just about every bulb on my 08 over the past year or so. Even the interior.
      Quote Originally Posted by xtravbx View Post
      No one was talking about crub sensors, whatever those are.
      And also, what are "fents, burshes, and briks." ?
      We must not have those in Florida.
