Results 1 to 7 of 7
Thread: Miro 111 18x8.5 et 35 or 45 all around??
  1. 06-12-2012 08:45 PM #1
    I just want to know if it can fit with an 35 offset all around or 45 will be better for front?!? I would like to have the same fitment, front to back.
    Thx for help!
    Car is sitting on ST Suspension at lowest setting and I project to buy 215/40R18 and stretch it...
  2. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    06-12-2012 09:05 PM #2
    215 on an 8.5" won't be a lot of stretch.
    Personally I'd run the ET35s all around, but the ET45 will be a very nice fit. Almost flush.
    MKV | MKIV | AWhiteRabbit| perfect.
  3. 06-12-2012 09:18 PM #3
    This is what it looks like since last week!
    PSU...et35 would look a lot more aggressive than 45 or not? I have to make a choice soon! One of my oem wheels is broken(hit a fuc**** hole)
    Sry for my english I'm a french canadian!
  4. Member Slave IV's Avatar
    Nov 15th, 2010
    B5 S4, MkV R32, W203 C240, W123 300D Turbo, W210 E320 4Matic
    06-12-2012 09:46 PM #4
    You don't need a forum to tell you that ET35 is more "aggressive" than ET45...ET35 is going to stick out 10mm more than ET45 on each side, giving you a 20mm wider track..those numbers actually mean something, it's not some opinion type of thing.
    http://www.tirerack.com/wheels/tech/...&affiliate=HK8
    If your gas cap light comes on even if you think you tightened the cap, try pulling on the cap as you tighten it. Worked for me.
    Help us with suspension specs!
    Vag Evolution: MkI Rabbit -> MkII 16v GTI -> B5 S4/MkV .:R32
  5. Member Tampavw's Avatar
    Nov 16th, 2006
    Tampa FL
    2008/VW/R32
    06-12-2012 10:45 PM #5
    et 45 all around, T.235x40
  6. 06-12-2012 11:54 PM #6
    I'm lower than that! That's why I'm wondering if et35 is too wide to fit easily without rubbing or I should go et45.... or, it simply depends on how wide the tire will be?!?
  7. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    06-13-2012 10:48 AM #7
    Quote Originally Posted by MaxKenyon View Post
    Just do the ET35.
    Take the screw out of each front fender, roll the fenders and then hand pull them.
    You will be fine with 215/40s.
