Results 1 to 10 of 10
Thread: Audi C5 A6 Avant/Wagon 2.8L - *Part Out!*
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    06-13-2012 03:09 PM #1
    Car needs to go ASAP, all prices are now best offer!
    1999 Audi A6 Avant/Wagon 2.8L with 177k miles - I'm parting out the whole car so let me know if you need any parts that are not listed below.
    More Pictures!:
    1999 Audi A6 Avant pictures by VTEC_THIS - Photobucket
    Engine:
    - 2.8L Shortblock/Engine (Engine was running) - $600
    - 2.8L Cylinder Heads (Engine was running, valves are intact!) - $550 for both
    - Shortblock & Heads Together - $950
    Misc Engine:
    - Camshaft Position Sensors - $25 each
    - Valve Covers - $35 each or $60 for both
    - Timing Belt Covers - $80 for all
    - Main Engine Cover (Audi V6) - $40
    - Side Engine Covers (5V) - $25 for pair
    - Engine Cover that goes over intake area - $20
    - Plastic Cover that goes across the engine bay and covers the battery - $35
    - Front Windshield/Wiper Plastic Trim Piece - $30
    - Crankcase Breather Hose/Tube - $30
    - AC Compressor - $180
    - AC Condenser - $60
    - AC System (lines, etc.)
    - Alternator *practically new, installed less than two months ago!*
    - Serpentine Belt Tensioner
    Intake and Cooling:
    - Air Intake Ducting - $20/section
    - Air Box
    - MAS/MAF (Mass Air Flow Meter) *practically brand new, installed less than 50 miles ago!* - $150
    - Throttle Body - $50
    - Intake Manifold - $35
    - Radiator - $75
    - Fan (slim fan) - $40
    - Coolant Reservoir Tank - $30
    - Meziere Inline Thermostat (allows you to put the thermostat in the radiator hose and save you the trouble and labor of re-doing your timing belt if your thermostat goes!) - $60 - I can include the modified radiator hose with it for $70
    Fuel and Spark:
    - Fuel Injectors
    - Fuel Rail
    - Fuel Pressure Regulator
    - Spark Plug/Ignition Wires (both sides) *practically brand new, installed less than 50 miles ago!* - $120
    - Coilpack *practically brand new, installed less than 50 miles ago!* - $125 - SOLD
    Exhaust:
    - Exhaust
    - O2 Sensors - $30 each
    - Catalytic Converters - SOLD
    Electronics:
    - ECU
    - Stock B5 S4 Giac Chip M/T (from my previous Audi)
    - ABS Module *serviced/recently rebuilt* - $120 - SOLD
    - V-Checker (OBD-II Scanner) does KWP1281 and KWP2000 - $45 - SOLD
    Drivetrain and Suspension:
    - Automatic Transmission - $450
    - Shifter Knob - $30
    - 16" Wheels with 205/55/16 Hankook Ventus V4 ES Tires (75-80% Tread) - $550
    - 3x Extra 205/55/16 Hankook Ventus V4 ES Tires (50-75% Tread) I was holding onto these as spare/replacements - $200
    - Front Brake Calipers (One was recently replaced less than three months ago) - $150/pair
    - Rear Brake Calipers - $120/pair
    - Front & Rear Brake Rotors
    - Shifter Plate/Cover (Painted black, looks better than scratched chrome any day!) - $35 - SOLD
    - Shifter/Tiptronic Circuit Board - $35 - SOLD
    Exterior:
    - Front Core Support (by itself) - $150
    - Front Core Support with Radiator, AC Condenser, etc. - $300
    - Fenders - $60 each - Passenger side fender is sold!
    - Sideskirts/Rocker Panels - $120 per long piece (Passenger side is sold!), $30 per end cap (Driver side is sold!)
    - Side Markers - $25
    - Taillights - $120
    - NEW Antenna (7" Black Short/Stubby Antenna - fits most Audis) - $15
    - Audi Front Grille (Four Rings) - $75
    - Bumper Grille (between fog light grilles) - $45
    - Wiper Arms (Front) - $15 each
    - Rear Wiper Motor - *Replaced less than a year ago!* - $55
    - Rear Windshield Washer Pump - *Replaced about a year ago!* - $15
    - Front OEM Heated Washer Nozzles - *Replaced about a year ago, spent $70 per nozzle!* - $80/pair
    - Hatch/Tailgate with Tinted Hatch Glass (Glass was replaced and tinted less than a year ago) - $375
    - Rear License Plate Surround/Panel - $80
    - Front Bumper - $200 - SOLD
    - Headlights with OEM HIDs - $250/pair - SOLD
    - Side Mirrors: Housings with Memory, Blind Spot Mirrors (with line) and tinted blue to cut down on glare (best mirrors I have ever used!) - $150/pair - SOLD
    - Foglights - $40/pair - SOLD
    - Fog Light Grille - $30/pair - SOLD
    Interior Switches:
    - OEM Hazard Switch - $30
    - Sunroof Switch - $30
    - Front Driver Seat Memory Switch - $35
    - Power Mirror Switch with Memory - $15
    - Headlight Control Switch - $30
    - Window Switches - $8 each for passenger doors (Master switch is sold)
    - Rear Heated Seats Switch & Air Vent - $30
    - Master Window Switch: rear window lock switch has been disabled so rear windows always work - $30 - SOLD
    - Motion Sensor Switch - $25 - SOLD
    Interior Parts:
    - Instrument Cluster with NO missing pixels, it's in perfect condition! - *LCD was replaced less than a year ago!* - $325
    - Headliner - $100 - Pick up Only
    - Cup Holder (Front pop out on dash) - *replaced less than a year ago!* - $35
    - Ultimate Cup Holder - $25
    - Storage Holder to the left of the cup holder (Front pop out on dash) - $35
    - Center Arm Rest - $75
    - OEM Headunit/Radio with Radio Code - $80
    - Climate Control Unit with Heated Seats - $100
    - 6 Disc CD Changer with Cartridge in Hatch - $75
    - Bose Amplifier
    - CD Changer Bracket - $20
    - Front Heated Seats - $225/pair - Pick up Only
    - Rear Heated Seats (Bottom and Back) - $175 - Pick up Only
    - (Nice) Wood Trim - make offers on pieces
    - Hazard/Cup Holder Trim Piece - $20
    - Interior Door Panels - $50/panel
    - Steering Wheel (without airbag) - $40
    - Air Bag for Steering Wheel - $50 - Pick up Only
    - Visor with HomeLink - $50
    - Partiton/Divider Between Seats and Cargo Area (Cargo Net Style) - $100
    - Spare Tire Tool Kit - $50
    - Spare Tire Cover - $50
    - Spare Tire Well Foam Insert - $20
    - Spare Tire Hold Down Nut/Screw - $10
    - Hatch Access Doors on Left and Right (covers CD changer, etc.) - $15 each
    - Cup Holder (Front pop out on center console) - *replaced less than a year ago!* - $35 - SOLD
    - Rear View Mirror (Automatic Dimming) - $50 - SOLD
    - Hinged Spare Tire Cover Panel - $65 - SOLD
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    06-23-2012 09:01 AM #2
    Ad updated with parts sold.
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    06-25-2012 11:10 AM #3
    Ad updated with more parts!
  4. Member
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    06-29-2012 09:09 PM #4
    Fog light grilles are sold.
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    07-11-2012 10:55 AM #5
    Ad updated with parts sold!
  6. Member ontheedge56's Avatar
    Jun 14th, 2008
    Ithaca, NY
    01.5 S4 Avant
    07-20-2012 07:31 AM #6
    was the car wrecked???
    im in Ithaca NY looking for an avant chassis.... doors fenders...trunk...hatch... hood an rear bumper are pretty much what im looking for and of course a title.
    VW's are great an all, but they have their purpose and one day I'll figure that out.
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    07-20-2012 07:47 AM #7
    Quote Originally Posted by ontheedge56 View Post
    No, the car was not in an accident or wrecked. The title is clean and I have it in hand.
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    07-23-2012 02:02 PM #8
    Back up!
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    07-27-2012 08:09 PM #9
    Front bumper and passenger side fender are sold!
  10. Member
    Dec 11th, 2006
    Northern NJ
    '99 Audi A6 Wagon
    08-11-2012 07:28 PM #10
    Everything needs to go, best offer!
