Results 1 to 7 of 7
Thread: Digital v2 comm error
  1. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    06-14-2012 10:18 AM #1
    Anybody experienced comm error ?
    Suspecting a connection problem but when i restart my car its allright.
    Happens at startup, more and more often.
    My build thread here here
  2. 06-14-2012 11:24 AM #2
    Please call Customer service if this doesn't work for you.. Probably, you have the power wire hooked to accessory power that turns off briefly as you turn the key to start position.
    Imagine it like this: you power on and it is powering up, , then you cut the power before it establishes complete communication with the ECU. Some cars are really bad for this, other are not. Change your wiring to a circut that stays how when you crank and it should fix it .
    One work around is to put car in the ON position, wait for V2 to communicate and go to preset 1, then start engine.
    Hope that helps.
    Brian@AirLift
    Engineer Dude
    http://airliftperformance.com/
  3. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    06-14-2012 12:43 PM #3
    Yeah thats what i do, i put it on acessory and air up, then start my car.
    Could i plug it directly on my battery instead of my power supply box?
  4. 06-15-2012 10:27 AM #4
    Quote Originally Posted by juldupp View Post
    If you wire it to the battery, then you will have the display and ECU active all the time. Probably not what you want.
    Brian@AirLift
    Engineer Dude
  5. Member hussdog426's Avatar
    Nov 20th, 2011
    North Jersey
    Bagged 2012 Golf TDI
    06-15-2012 04:52 PM #5
    The best way to start it is ignition on, wait for ecu to communicate, then power car on
    2012 Bagged United Gray Golf TDI OEM+
    follow me on instagram: @hussdog426
  6. Member juldupp's Avatar
    Feb 12th, 2011
    Quebec (canada)
    bagged mk6 2.5
    06-19-2012 08:16 AM #6
    Comm error happens less often now, the bug i have now is that my preset screen is bugged, i cant push any preset buttons, i have to go to manual mode, then back to preset mode and then its working fine
  7. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    06-19-2012 08:19 AM #7
    Give us a call, it sound's like there still may be an issue with the ignition signal wire as Brian mentioned.
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
