It means that the rear 02 sensor is getting data that indicates the Cat has failed; the cat could have actually failed or the O2 sensor could have failed. I have no cat and I'm throwing the same code (for obvious reasons) Though I did purchase the downpipe program from Revo and it is still throwing a code.
If you get a new DP and high-flow cat, you'll need to purchase the downpipe program for your software as well as an O2 spacer (elbow) to blind the 02 sensor and keep from throwing a code.
