Page 1 of 2 1 2 LastLast
Results 1 to 35 of 41
Thread: Holy AWESOME - Bloodhound SSC inside
  1. Member pinktshirt's Avatar
    Jul 25th, 2007
    Jerusalem/Orléans(FR)
    VW 2.oh?
    06-16-2012 07:45 AM #1
    I just stumbled upon this while reading the Guardian.
    The next land speed record car will aim for 1000 MPH, will be powered by a Eurofighter jet engine, coupled with a rocket, fuel for which will be supplied using a pump driven by a Cosworth Formula 1 engine!!!
    Video here:
    http://www.guardian.co.uk/science/vi...0mph-car-video
  2. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    06-16-2012 08:02 AM #2
    Yeah its quite a thing when it needs 800hp just to drive the fuel pump
    If the rocket is anything like as impressive as the rocket scientist's mustache they should have no problems getting to 1000mph
    Dec 15th, 2010
    Fall River area
    06-16-2012 08:10 AM #3
    Quote Originally Posted by MikkiJayne View Post
    Fuel consumption astronomical.
  4. Member scott_0's Avatar
    Dec 21st, 2010
    Oxford, Pa
    1991 Civic dx 2011 Ingot silver Mustang GT
    06-16-2012 10:23 AM #4
    wow thats amazing! good posting here
  5. Member Internal Combustion's Avatar
    Apr 17th, 2007
    Columbus, OH
    E92 335xi and a Prius
    06-16-2012 10:29 AM #5
    Quote Originally Posted by corrago View Post
    Yeah it's bad when your Fuel pump uses ~40 gallons per hour (F1 cars 3mpg @ 120 mph average = 1 gallon every 90 seconds)
    TCL pearl #452: You cannot name a car that would not be improved with a LSx engine.
    Formerly of Lexington, KY
    Kentucky Wildcats-Go Big Blue!
  6. Member worth_fixing's Avatar
    Dec 23rd, 2009
    St-Jean-sur-Richelieu, Qc
    2009 Volks GTI Tornado Red
    06-16-2012 10:32 AM #6
    Quote Originally Posted by Internal Combustion View Post
    f*ck...
    It's probably pumping 5 gallons per second to fuel the jet motors.
    Quote Originally Posted by slide13 View Post
    My ITR can probably smoke that sporty cavalier, called corvette.
    Kind regards,
    James
  7. Member elementpb's Avatar
    Feb 23rd, 2008
    Mechanicsville, VA
    2011 Rustang. Secretary Edition.
    06-16-2012 10:57 AM #7
    can't someone just strap a solid rocket booster to a roller skate? Sure, stopping the thing might prove a bit difficult, but it'll run out of fuel eventually!
  8. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    06-16-2012 12:18 PM #8
    Quote Originally Posted by worth_fixing View Post
    f*ck...
    One ton of rocket fuel in 17 seconds
  9. Member mike minnillo's Avatar
    Sep 23rd, 2007
    Colorado Springs, CO
    MKIV 12v VRT GTI, B5 Passat Wagon
    06-16-2012 12:41 PM #9
    f*ck...
    My math says 19 gallons/sec.
    Jack of all trades.
  10. Member Uberhare's Avatar
    Jul 30th, 2003
    Spokane WA
    10-03-2012 11:43 AM #10
    UPDATE....
    Oct. 3, 2012 - The race to build the first car to break 1,000 mph took a big step forward today after a successful test firing of the rocket that will power the Bloodhound SSC. It was the largest rocket firing in the U.K. in over 20 years.
    The British team behind the project ignited the propulsion system inside a hardened aircraft shelter at Newquay Cornwall Airport, which was originally designed to protect fighter planes from bomb attacks from the outside.
    The unique engine is described as a "hybrid" as it runs on a mixture of a liquid high test peroxide oxidizer and solid synthetic rubber fuel and uses the V8 from a Formula 1 racing car as an ignition system. The design is said to be safer and more controllable than either either a liquid or solid-fueled rocket alone can be.
    The data has yet to be fully analyzed, but the engine is expected to have developed over 30,000 hp during the short 10-second burn. It was designed to produce a total of 80,000 hp and 27,500 pounds of thrust in competition trim.
    The needle-nose car that it will be installed in is currently under construction, and also features a jet engine from a Typhoon fighter plane which will be used to accelerate the vehicle to more than 230 mph before the rocket system is fired for the sprint to its target speed of 1,050 mph, which it is expected to reach in 42 seconds.
    Three more tests of the propulsion system are planned before the record attempt, which is scheduled to take place next October on the Hakskeen Pan dry lake bed in South Africa, where a 12-mile track will be marked out for the run. If all goes to plan, the Bloodhound will hit its top speed within 6.5 miles, then use a combination of wind resistance, air brakes and two parachutes to slow it down over the course of 5.4 miles, leaving a buffer of just over 500 feet before the end of the track.
    British Royal Air Force pilot and current land speed record holder Andy Green will be driving the Bloodhound for the record and 51 years old at the time. In 1997 he became the first person to break the sound barrier on land in the ThrustSSC, which reached 763 mph in Nevada's Black Rock Desert.
    After seeing the size of the bright orange flames coming out of the engine during the test, Green remarked cheekily, "I'm going to have to have a chat with the engineers, I didn't know my A** was going to be on fire."
    The Bloodhound effort is one of several underway with the goal of setting a new land speed record. Former record holder Craig Breedlove is heading up a team that is hoping to celebrate the 50th anniversary of his first title with an 800 mph run at the Bonneville Salt Flats in 2013, while a shoestring project run by Waldo Stakes, a general contractor from California who is aiming to hit 2,000 mph with a vehicle he is working on called Sonic Wind, which is built around the engine from the X-15 experimental plane that hit 4,159 mph in 1967.
    http://www.foxnews.com/leisure/2012/...ntcmp=features
    Now
    Ford Flex AWD, Vulcan Nomad 1600
    Prior Ownership:
    VW Mk4 R32, Chevy Z71 Colorado 4x4, Audi A6 2.7T (RS6 replica wannabe), Audi 90Q, BMW X5 4.4i, VW 20AE GTI #0651, Aprilia RSV Mille, Suzuki V-Strom DL1000
  11. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    00' VR6 12' V6 TDI 72' 914-6
    10-03-2012 11:46 AM #11
    the rocket motor sounds like a scaled up version of a hybrid motor used in sport rocketry....I've built a few level III hybrid motors and they KATO often....not an exact science, but they are stable until ignited.
    Larry
  12. Member Uberhare's Avatar
    Jul 30th, 2003
    Spokane WA
    10-03-2012 11:49 AM #12
    Rocket = controlled explosion
    Now
    Prior Ownership:
  13. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    10-03-2012 12:07 PM #13
    Quote Originally Posted by uberhare View Post
    rocket = vectored explosion :d
    ftfy :p
    Larry
  14. Member compy222's Avatar
    Apr 7th, 2005
    Pothole, MI
    2012 Cruze Eco, 2006 Lancer Evo IX MR
    10-03-2012 12:14 PM #14
    that has got to be the most terrifying pull EVER.
    Regarding DD'ing a tuned Evo:
    Quote Originally Posted by SchrickVR6 View Post
    It's composed at all speeds and at all times...it just feels like you're holding the leash on a 150lb pit bull and praying you don't see a squirrel.
  15. Member AdrockMK2's Avatar
    Apr 11th, 2005
    NOTL, ON
    Mazda 3 GT
    10-03-2012 12:15 PM #15
    I'm very happy to see there are still people pushing the Land Speed Record even higher...and always there are crazy ones that think they can reach ABSURD speeds. Andy Green and crew probably have the best chance of breaking 1000mph, but there will always be this guy:
    "a shoestring project run by Waldo Stakes, a general contractor from California who is aiming to hit 2,000 mph with a vehicle he is working on called Sonic Wind, which is built around the engine from the X-15 experimental plane that hit 4,159 mph in 1967."
    ...2000! Ya, sure Waldo.
  16. Member O_loung1's Avatar
    Feb 13th, 2001
    11 gti st2-
    10-03-2012 12:23 PM #16
    Quote Originally Posted by compy222 View Post
    reminds me of the rocket sled at stage 2 + 300mph
    vortex folding thread.................. ............. ............... ...... ............ ........... .... ... ......... ..... ........ .... ..... ... intention
  17. Senior Member FlashRedGLS1.8T's Avatar
    Apr 17th, 2001
    Ohio
    10-03-2012 12:25 PM #17
    Quote Originally Posted by elementpb View Post
  18. Member GLgod's Avatar
    Aug 23rd, 2006
    Philly
    '03 GTI 24V, '03 R6
    10-03-2012 12:34 PM #18
    Quote Originally Posted by Uberhare View Post
    UPDATE....
    It's all HP and no torque!
    The Elite 24v VR6 Club: Member #245
  19. Member Uberhare's Avatar
    Jul 30th, 2003
    Spokane WA
    10-03-2012 12:36 PM #19
    Quote Originally Posted by GLgod View Post
    It's all HP and a crap load of thrust!
    Now
    Prior Ownership:
  20. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    10-03-2012 12:39 PM #20
    Quote Originally Posted by AdrockMK2 View Post
    THAT motor is known to have issues....XLR 11 motor can be a bit "explosive", 5:40 mark
    Larry
  21. Member Uberhare's Avatar
    Jul 30th, 2003
    Spokane WA
    10-03-2012 12:39 PM #21
    Have you seen this guy and his project?
    http://sonicwind.com/
    No bad for a non-engineering type guy.
    Now
    Prior Ownership:
  22. Member AdrockMK2's Avatar
    Apr 11th, 2005
    NOTL, ON
    Mazda 3 GT
    10-03-2012 12:48 PM #22
    He lost me at Papyrus
  23. Member Cousin Eddie's Avatar
    Dec 17th, 2005
    Ontario, Canada
    That there's an RV, Clark
    10-03-2012 12:51 PM #23
    Holy Foxtrot Uniform Charlie Kilo!
  24. Member
    Mar 25th, 2009
    Fairfax, VA
    04 M3, 99 A4 2.8
    10-03-2012 12:55 PM #24
    What does this thing use for tires?
  25. Member
    Mar 18th, 2011
    2011 DB GTI DSG 2 Door
    10-03-2012 01:18 PM #25
    Shooting from the hip only gets you so far though....
    As far as tires....Thrust SSC had solid aluminum wheels....I am assuming Bloodhound will do the same...
  26. Geriatric Member Chapel's Avatar
    Jun 23rd, 1999
    New England
    '97 BMW 328i | '10 Mazda5
    10-03-2012 01:52 PM #26
    I'm pretty sure that rocket science is only as good as the scientist's mustache... I think that's the Bernoulli Principle... don't quote me on that.
  27. Member
    Mar 25th, 2009
    Fairfax, VA
    04 M3, 99 A4 2.8
    10-03-2012 01:58 PM #27
    Quote Originally Posted by RacingManiac View Post
    Meaning just metal, no rubber at all? Interesting.
  28. Member Uberhare's Avatar
    Jul 30th, 2003
    Spokane WA
    10-03-2012 02:04 PM #28
    Quote Originally Posted by Shmi View Post
    Yup. You gotta realize the wheels are subjected to a huge amount of centrifugal force and friction. Think about the rotational speed of the wheels at 1000mph. No tire on Earth could handle that. A solid chuck of metal is the only thing that can withstand those forces and not melt due to heat generated from the frictional forces.
    Now
    Prior Ownership:
  29. Member
    Mar 25th, 2009
    Fairfax, VA
    04 M3, 99 A4 2.8
    10-03-2012 02:27 PM #29
    Yeah I mean I kind of figured it wouldn't be rubber, but thought maybe there was another material covering the metal they'd use instead(dunno, kevlar or something??) Interesting though, thanks
    Isn't aluminum very malleable though? I suppose at the salt flats it wouldn't be an issue since there's not much risk of running over anything. I wonder how it behaves at those speeds/temperatures.
  30. Member Crimping Is Easy's Avatar
    Jun 13th, 2012
    Findlay, Ohio
    2001 Honda Prelude, 1984 Honda Gyro, 2001 Subaru Outback
    10-03-2012 03:09 PM #30
    Developed in conjunction with Honda.
    Quote Originally Posted by MidnightSpecial View Post
    Germans need to be kept away from automobiles.
    Quote Originally Posted by ShoutMan View Post
    I fight for Trees, animals, forests and good people.
  31. Senior Member StormChaser's Avatar
    Jan 3rd, 2000
    Galesville, MD
    2006 Volvo V50, 1993 RX-7 R1, 1980 Hatteras 53MY, 2002 Grady White Release 283, 1958 Mohawk 14
    10-03-2012 03:24 PM #31
    vtec yo
    Dave
    Demokratically Elekted Minister of Ginger Affairs and Fist Dates; Orakle of the Weathers; Creeper Extraordinaire of the Independent People's Republik of Offtopikstan
    Quote Originally Posted by Biz View Post
    If Chilledman and Stormy won't hit it, you know it's gone rancid.
  32. Member compy222's Avatar
    Apr 7th, 2005
    Pothole, MI
    10-03-2012 03:51 PM #32
    Quote Originally Posted by StormChaser View Post
    vtec yo
    when the second stage kicks in...it will be almost as epic as normal vtec.
  33. Member 71DubBugBug's Avatar
    Dec 3rd, 2006
    Chicago
    91 Audi D1 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
    10-03-2012 04:03 PM #33
    thats gotta sound nuts, a jet engine, a rocket, and a cosworth engine
    one huge fireball if something goes wrong
  34. Member nickthaskater's Avatar
    Apr 17th, 2007
    Vancouver, BC
    An imaginary one
    10-03-2012 04:24 PM #34
    Probably something like billet titanium wheels; no rubber involved.
  35. Senior Member AZGolf's Avatar
    Jun 6th, 2000
    Phoenix area
    10-03-2012 05:11 PM #35
    Yeah I'm not sure he understands how this works. Based on this table of the X-15's fastest flights it appears they were all set at 100,000 feet or so. The atmosphere is about 1% as dense at that altitude as it is at sea level. Granted, the salt flats are going to have something like 87% of sea level density due to the elevation there but that's still 87 times as much air mass to punch through the X-15 had to deal with on its record setting flights.
    We're actually getting pretty close to the land speed records closing in on the maximum low-altitude flight record, set by a privately owned F-104 Starfighter at 988mph in October of 1977. If these 1000mph land records turn out then we'll have an odd situation where the fastest land vehicle is faster than the fastest aircraft ever flow at low altitude for an FAI record.
