VWVortex.com - Holy AWESOME - Bloodhound SSC inside
    The Car Lounge
    Page 2 of 2 FirstFirst 12
    Results 26 to 41 of 41
    Thread: Holy AWESOME - Bloodhound SSC inside
    1. Geriatric Member Chapel's Avatar
      Jun 23rd, 1999
      New England
      '97 BMW 328i | '10 Mazda5
      10-03-2012 01:52 PM #26
      Quote Originally Posted by MikkiJayne View Post
      If the rocket is anything like as impressive as the rocket scientist's mustache they should have no problems getting to 1000mph
      I'm pretty sure that rocket science is only as good as the scientist's mustache... I think that's the Bernoulli Principle... don't quote me on that.
    2. Member Shmi's Avatar
      Mar 25th, 2009
      Fairfax, VA
      2014 Fiesta ST, 2004 Accord EX, 2003 LS430
      10-03-2012 01:58 PM #27
      Quote Originally Posted by RacingManiac View Post
      Shooting from the hip only gets you so far though....
      As far as tires....Thrust SSC had solid aluminum wheels....I am assuming Bloodhound will do the same...
      Meaning just metal, no rubber at all? Interesting.
    3. Member Uberhare's Avatar
      Jul 30th, 2003
      Spokane WA
      2012 Golf TDI, 2015 Triumph Rocket 3 Roadster
      10-03-2012 02:04 PM #28
      Quote Originally Posted by Shmi View Post
      Yup. You gotta realize the wheels are subjected to a huge amount of centrifugal force and friction. Think about the rotational speed of the wheels at 1000mph. No tire on Earth could handle that. A solid chuck of metal is the only thing that can withstand those forces and not melt due to heat generated from the frictional forces.
    4. Member Shmi's Avatar
      Mar 25th, 2009
      Fairfax, VA
      10-03-2012 02:27 PM #29
      Quote Originally Posted by Uberhare View Post
      Yeah I mean I kind of figured it wouldn't be rubber, but thought maybe there was another material covering the metal they'd use instead(dunno, kevlar or something??) Interesting though, thanks
      Isn't aluminum very malleable though? I suppose at the salt flats it wouldn't be an issue since there's not much risk of running over anything. I wonder how it behaves at those speeds/temperatures.
    5. Banned Kumamon's Avatar
      Jun 13th, 2012
      It's just jokes, my guy.
      10-03-2012 03:09 PM #30
      Quote Originally Posted by GLgod View Post
      It's all HP and no torque!
      Developed in conjunction with Honda.
    6. Banned StormChaser's Avatar
      Jan 3rd, 2000
      Annapolis, MD
      2006 Volvo V50, 1993 RX-7 R1, 1980 Hatteras 53MY, 2002 Grady White Release 283, 1958 Mohawk 14
      10-03-2012 03:24 PM #31
      vtec yo
    7. Member compy222's Avatar
      Apr 7th, 2005
      Pothole, Midwest
      Honda Fanboy Collection
      10-03-2012 03:51 PM #32
      Quote Originally Posted by StormChaser View Post
      vtec yo
      when the second stage kicks in...it will be almost as epic as normal vtec.
      Quote Originally Posted by capsaicin View Post
      AP1 S2000? I can not in good conscience talk you out of that. May your slip angle be great and your bed not be the couch!
    8. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      91 Audi D11 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
      10-03-2012 04:03 PM #33
      thats gotta sound nuts, a jet engine, a rocket, and a cosworth engine
      one huge fireball if something goes wrong
    9. Member nickthaskater's Avatar
      Apr 17th, 2007
      Vancouver, BC
      2002 Mazda Protege5
      10-03-2012 04:24 PM #34
      What does this thing use for tires?
      Probably something like billet titanium wheels; no rubber involved.
    10. Senior Member AZGolf's Avatar
      Jun 6th, 2000
      Phoenix area
      10-03-2012 05:11 PM #35
      Quote Originally Posted by AdrockMK2 View Post
      "a shoestring project run by Waldo Stakes, a general contractor from California who is aiming to hit 2,000 mph with a vehicle he is working on called Sonic Wind, which is built around the engine from the X-15 experimental plane that hit 4,159 mph in 1967."
      ...2000! Ya, sure Waldo.
      Yeah I'm not sure he understands how this works. Based on this table of the X-15's fastest flights it appears they were all set at 100,000 feet or so. The atmosphere is about 1% as dense at that altitude as it is at sea level. Granted, the salt flats are going to have something like 87% of sea level density due to the elevation there but that's still 87 times as much air mass to punch through the X-15 had to deal with on its record setting flights.
      We're actually getting pretty close to the land speed records closing in on the maximum low-altitude flight record, set by a privately owned F-104 Starfighter at 988mph in October of 1977. If these 1000mph land records turn out then we'll have an odd situation where the fastest land vehicle is faster than the fastest aircraft ever flow at low altitude for an FAI record.
    11. Member Uberhare's Avatar
      Jul 30th, 2003
      Spokane WA
      10-03-2012 05:15 PM #36
      Wheel specs are here: http://www.bloodhoundssc.com/project/car/wheels
      The high speed wheels will be forged from solid aluminium, using low-risk techniques and materials that have worked well in the past
      Each wheel weighs 95 kilogrammes, will spin at over 10 000 RPM and will be subject to a force of 50 000 ‘G’ at the wheel rim..
      The wheels are fairly straightforward ...but nothing is simple when you’re planning to do 1000 mph!
      No exotic alloy. Just billet aluminum, probably a very high grade type.
    12. Member Uberhare's Avatar
      Jul 30th, 2003
      Spokane WA
      10-03-2012 05:17 PM #37
      More info about the wheels:
      http://www.bloodhoundssc.com/news/wheel-story-so-far
      Check out the different profiles they proposed to use. And the brake they plan to use is nuts.
    13. Member Rukh's Avatar
      Mar 25th, 2003
      Colorado
      Mk4 Jetta Wagon, Mk1 Rabbit, FIAT 500
      10-03-2012 07:08 PM #38
      Quote Originally Posted by .LSinLV. View Post
      THAT motor is known to have issues....XLR 11 motor can be a bit "explosive", 5:40 mark
      I sincerely hope somebody said, "whoops" when that happened.
      HAVE/HAD: Mercedes, Porsche, Cadillac, Land Rover, VW (x5), Buick, Mitsubishi, Chrysler, Dodge, Nissan, Ford, GMC, Jeep, Fiat
      WANT: Fiat 500C Abarth, VW Scirocco Mk1, Alfa Romeo GTV, Lotus Esprit, Audi TT, 240Z, Lancer Evo VIII RS,
      Hudson Hornet, Porsche 964, Mini Cooper, Caterham SV, M-B CLS63 AMG, DeTomaso Pantera
    14. Member compy222's Avatar
      Apr 7th, 2005
      Pothole, Midwest
      10-03-2012 07:12 PM #39
      120mm aluminum wheel. "it'll be like driving a road car on ice" AT 1000mph!
    15. Member nickthaskater's Avatar
      Apr 17th, 2007
      Vancouver, BC
      2002 Mazda Protege5
      10-03-2012 10:12 PM #40
      I would have thought aluminium to be too soft for such high speeds...
    16. Member aussie88's Avatar
      Dec 13th, 2010
      ɐıןɐɹʇsnɐ
      1988 Mercedes-Benz 190e, 1970 VW Lowlight pickup, 2007 Honda Accord Euro
      10-04-2012 05:28 AM #41
      I couldn't focus on the car due to the sheer lenght of the scientists moustache.
      ಠ_ಠ
