If you open and close the door, do you hear the pump prime?
#1
So I was driving home from work yesterday and the car just cuts off at the light. I try to start it and it only turns over, so I know its not the battery and the starter. I know there is a few threads on this but they are older ones and was just wanted to know how many of you guys have had to replace the fuel pump. I only have 40k on the car and had it towed to the shop to have this confirmed on Monday.![]()
#2
IMS built UM tuned Golf RS.
#3
No you cant hear it prime when you open the door, But when you turn the key you can hear the fuel pump relay click and the tack will bump when the motor turns over. So I dont think its the crank shaft sensor. I am still thinking its the pump but will not find out for sure till Monday. Do you know where its located on the V R32? Is it under the back seat?
#4
Check the cam shaft postion sensor connectors to oil ingress (unplug them and look at the pins for oily debris)
...remember, short controlled bursts
Steam VendettaGTI
Origin: VTMTK_Vendetta
Youtube: InsertCoinToBegin
#5
I've had the fuel pumps replaced three times at the dealer. It got so bad that the car would shut off while driving on the high way numerous times. :bang head: I'm back up to running and problem free now. It was a long battle to get them to find the pump bad as it was never throwing any codes to lead to the pump.
#6
#7
no, to get to the fuel pump simple pull up on the front edge of the rear seat bench, you will see a black metal cover with three screw, remove that cover and you have access to the fuel pump, also one a side note, you maybe want to just disconnect the hose at the fuel rail and see if there is fuel present and if there is pressure. The R32's fuel filter (located under the vehicle by the back wheel) is also the fuel pressure regulator and can become clogged easily. If you have fuel, and you're RPM gauge is going up while cranking the engine then you know your crank shaft position sensor is working. you then need to check spark, things like faulty cam shaft sensors will stop the signal to/from the ECU giving the motor a firing signal, I've seen this many times on the R32.
Steam VendettaGTI
#9
I just changed mine in 35 minutes in the street. Super easy to do.
#10
#12
Sounds like some of the discussion in there is related to the HPFP (something with it goes bad, causing the LPFP to run at 100% duty cycle), which we don't have since we aren't FSI.
I've been having trouble starting it after it's been baking in the sun for hours. I hear the pump prime (or at least I hear the relays go), but it doesn't crank cleanly. Give it a second crank and it usually sputters up (sounds crappy, not normal start), but then it seems to run OK... I'm thinking it's just minor vapor lock but i don't know?
