give it some more time... Not parting yet
Got a truck and the wife says something has to go.
It needs a good bit of work still. Pictures will explain.
Engine:
3a with 13k miles
Rebuilt big valve head
270 autotech cam
Tt adjsustable cam gear
Tt dual downpipe into custom 2.25 back
E30 motor mounts
Poly trans mount
New clutch and resurfaced flywheel
Was going with motorcycle carbs because I fried the ecu when I didn't have my grounds sorted.
The manifold isn't built for the carbs but have the flange and pipe. They are cbr600 carbs.
New intank pump from an evo 8. (put in before I decided to go carbs)
I've heard motor run a handful of times, but it was on starting fluid.
Suspension:
Boge turbo gas all around
G60 fk 60/40 springs
Custom rear strut brace
Wheels:
Mb motoring 16's need refinished and tires
Also have some 15x8 steelies in need of tires that I may let go for extra money.
Brakes:
10.1's in front g54 calipers
Drums in rear, but do have spindles to convert to rear discs.
Passenger side has new bearing, ball joint and tie rod end
Body:
Custom Led taillights
Brazil dual round headlights
Treated rust spots with por15 (and spots prone to rusting)
Sparco gas cap .
Rare fox trunk lip spoiler
Mk2 front air dam
Needs painted.
Interior:
Stripped
Seats are from a Suzuki swift gti. Pretty deep bolsters, need brackets made.
5 point harnesses
New ignition switch from auto zone ...
Car was initially going to be my autocross car, just ran out of time, got married, and wife is on me pretty hard about getting rid of my project... Kills me to do it...
I would love to see this finished. If it doesn't sell I will be parting. My zip is 26155...
Interior, paint, and carbs is all she needs! Btw way I have fuel pumps and everything for the carbs to go on!
X2 On the part out... Would love to have that spoiler! Good luck with the sale.
Ok let's do this....mods can you put this in the fox parts category? Parts will be cheaper if you come pick them yourself.![]()
#11
2000 Jetta VR6 GLS <-- She's dead. | 2003 Jetta GLS 2.slowasballs | 1993 Fox Wolfsburg Edition Coupe
8v Society #8
