VWVortex.com - Throttle body
    Results 1 to 6 of 6
    Thread: Throttle body
    1. 06-18-2012 10:02 PM #1
      On my 2002 jetta wagon 1.8t It has been idleing a little rough, so I removed and cleaned out the throttle body. Followed instructions and turned key on too allow for alignment
      . No high pitched sound was heard to indicate it was adjusting. Started car and it runs but shakes very much. Drove for ten minutes and the engine learches alot. No trouble lights are on. What happened? Any help would be great.
    2. Member 01TornadoWolf's Avatar
      Jun 17th, 2009
      Winooski, VT
      2001 Jetta 1.8T Wolfsburg Edition
      06-19-2012 09:42 AM #2
      need to perform throttle body adaptation/alignment via vagcom
      | 802 |
    3. 06-19-2012 09:52 AM #3
      A tbody alignment wont happen on its own by just turning the key on... That is a vortex fairy-tell. If you were using vag and didn't exit out of basic settings before cranking then you damaged your throttle body and need a new one....
      Clarify if you were using vag?
    4. 06-19-2012 06:14 PM #4
      Quote Originally Posted by Twopnt016v View Post
      No, I was not using vag. Did not realize it would not adjust when key turned on. I will try to use vagcom alignment and hope it works. Thanks.
    5. 06-19-2012 07:47 PM #5
      Quote Originally Posted by mappy62 View Post
      Please got to Rosstech and read how to perform the Tbody alignment. Like I said if you fail to do it right you can destroy your tbody.
    6. Member
      Jan 4th, 2007
      MA
      2004 Jetta GLS 1.8T
      06-21-2012 02:11 PM #6
      check for codes first and see what it says. i think you have an ignition coil problem.
