Results 1 to 29 of 29
Thread: G60 MS suddenly died
  1. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-18-2012 11:55 PM #1
    Preface - 80 Scirocco with a stage 3 G60 swap. Was running the stock Digi setup but switched over to MS. It's MS2 v3, running MSnS 3 with relay board and JAW WB controller. Still using the stock Ignition system (distributor, hall sender and coil).
    I had it running great for about 2 weeks. Was driving it one day in 5th gear and the car just suddenly dies. No bangs, sputters or Pull over to the side of the road and open the hood and look it over. Nothing looked out of place so I try and start it. It turns over fine but won't start.
    Tow it home and confirm there is no spark. Check all the connections on the relay board and all look fine. The computer light for the injectors light up when cranking and I have a noid light and it flashed while cranking at the injector. The wiring to the dizzy checks out as does the wire to the - side on the coil (continuity and signal).
    After changing out the coil and distributor with different used components I can get an inconsistent very weak spark at the coil wire but not enough to start it. Both coils pass the Bentley tests. I have hooked up my megastim and all the reading on Tuner studios look correct when the dials are turned.
    Any theories why my system would just quit? I am not very familiar with the MS board but familiar with all the car wiring. Is there some things to check that I am missing? Any help at this point would be appreciated, thanks.
    Gordy S
    MK1 x 3
  2. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    06-19-2012 05:41 AM #2
    Does your MS tuning software show rpms while cranking? No rpms into MS = no spark and no fuel.
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
  3. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    CW mkv GTeye,BM20th toilet#461(dead to me),91 EA cabby, yellow C
    06-19-2012 06:34 AM #3
    Check your grounds, I learned the hard way where not to put them.
  4. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-19-2012 09:00 AM #4
    Check for spark at the plugs? Could be a dizzy/rotor/plug wire problem.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  5. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    06-19-2012 11:10 AM #5
    What are you using for the Ign Driver (Ignitor)? The Scirocco IGN Module wired to MS or an internal IGBT?
    If internal IGBT, make sure it did not get cooked (take cover off MS and inspect), which is my suspect. Especially, if it were the older VB921 IGBT.
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  6. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-19-2012 11:55 PM #6
    Quote Originally Posted by Prof315 View Post
    Yes, it does show 200-250 rpms while cranking.
    Gordy S
    MK1 x 3
  7. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-20-2012 12:11 AM #7
    Quote Originally Posted by oldschool eighty8 View Post
    Oh yeah, I have a Scirocco and know all about bad grounds and have a good amount of them. Where would you recommend not putting them?
    Gordy S
    MK1 x 3
  8. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-20-2012 01:41 AM #8
    Quote Originally Posted by sdezego View Post
    Thanks for the tips! I know very little about the MS computer itself but I was able to so some searching of IGBT. I was able to locate where the IGN bridges were installed on the board to run the IGN and found the VB921. Upon opening the MS case there was that burnt electrical odor. The 3 fingers that go from the VB921 do look heated compared to the rest of the units on the heat sink but the connection to the board look ok and not burnt.
    I will continue searching the web but is there a test for the VB921 to see if it is toast? I have a feeling it might be. Not sure if a photo will help but everyone like pictures
    I just tested the voltage at the coil. I am getting 12V at both the + (battery) and - (S5 from relay board) side at key power. Is that correct?
    Thanks for all the help so far. I am getting a lot further along with your ideas.
    Gordy S
    MK1 x 3
  9. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    06-20-2012 05:30 AM #9
    Your VB921 IS toast. (good call shawn!) I'm not sure if the board is damaged from your picture.
    The Professor
    Melbourne, FL
  10. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    06-20-2012 07:30 AM #10
    Quote Originally Posted by ydrogs View Post
    Keep them off the body, I ground my ms ecu by itself on the block.
  11. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-20-2012 07:53 AM #11
    Just looking at the color of the nylon nut it looks like the igbt overheated. I have a ton of Bips if you need one on the quick.
    -Paul
  12. Member DieGTi's Avatar
    Jun 19th, 2001
    Manchester, NH
    1990 Jetta 12v VR6T; 98 Audi A4 30v QS, 74 911
    06-20-2012 10:38 AM #12
    Underlying cause so it doesn't happen again? Better grounding of the board to the block? Less dwell?
  13. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    06-20-2012 10:42 AM #13
    Quote Originally Posted by DieGTi View Post
    VB921 is the underlying cause. BIP373s are MUCH more robust and have built in overheat/over current protection.
    The Professor
    Melbourne, FL
  14. Member sdezego's Avatar
    Apr 23rd, 2004
    06-20-2012 10:43 AM #14
    ahh, yes. It is cooked. I had the same thing happen to me when I first built mine for my G60 some years back. I got only about 12 miles though and mine was a bit more meltier LOL... Luckily, I was able to replug in Digi to make it back home.
    I never really found out why it happened (either the coil/dwell settings I was using, Nylon bolt loosening to heat sink or just a finicky VB921 IGBT).
    At the time, there was no BIP IGBT option recognized, so I replaced it with another VB921 and changed my coil/dwell settings. Been running like that for years now, however, I would absolutely replace with the more reliable BIP IGBT.
    As Jeff stated above, check that tracer on the board. That last leg looks like it definitely transferred some heat to the board. I also got rid of that Nylon bolt afterward and used a real bolt/nut to attach the IGBT to the heat sink (I don't recall if it needed to be isolated or not).
    Definitely check your coil and dwell settings after you replace.
  15. Member sdezego's Avatar
    Apr 23rd, 2004
    06-20-2012 10:48 AM #15
    Pic so you don't feel alone
    Replaced with Screw and Brass standoff from old computer case hardware (ignore the TIP120 added to the left for IAC)
  16. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-20-2012 11:24 AM #16
    I have used nylon on all my builds without issue, but I do use just a tiny hit of superglue to lock the threads. The BIP373 needs to be isolated with mica and the nylon hardware is some extra insurance.
    -Paul
  17. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-20-2012 10:23 PM #17
    I currently have a ground flower attached to the firewall in the passenger foot well where all the MS components are. I will take the MS ground off the flower (shared by small amp, relay board and wideband controller) and run it through the fire wall to the block.
    Can I ask what the difference between the 2 grounding locations is though? Wouldn't the negative post on the battery be the best place to ground?
    Gordy S
    MK1 x 3
  18. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-20-2012 10:32 PM #18
    This is what I think I should have done on install. I bought the system out of a running car and I do not think we checked the coil settings when it got installed. I do think we were both using the same Bosch coils but without checking the serial numbers I can not be certain. A lot of coils look the same but do have different properties.
    Gordy S
    MK1 x 3
  19. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    06-20-2012 10:32 PM #19
    Grounding to the block is the best option for anything ecu related. The problem with grounding to the body where other things are grounded like the radio and interior lights ect. is it's not a clean ground sigal. It shoud be in a location by itself.
  20. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-20-2012 10:43 PM #20
    Quote Originally Posted by need_a_VR6 View Post
    The quicker the better but since I did not assemble this or any other computer board I am not sure I want to risk doing this. I have soldered a lot of wires together but never on a circuit board.
    Any comments on this company and their service?
    http://www.symtechlabs.com/catalog/m...vice-p-44.html
    $30 seems acceptable to me but do not know anything about them.
    I do have a soldering iron and a gun so maybe I should just sack up and do it myself.
    How much would you charge for a BIP?
    Gordy S
    MK1 x 3
  21. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-20-2012 10:56 PM #21
    I will do it for $20 plus shipping.
    -Paul
  22. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-20-2012 11:10 PM #22
    Do these help?
    It looks ok except for that last pin where it bubbled up. I think I can still see the board wire intact though.
    Gordy S
    MK1 x 3
  23. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-20-2012 11:14 PM #23
    Never knew that about ECU grounds. Thanks for that nugget of info
    Gordy S
    MK1 x 3
  24. Member sdezego's Avatar
    Apr 23rd, 2004
    06-21-2012 03:24 PM #24
    Yea, the board looks fine. That goop looks like it either oozed out of the IGBT or is from the nylon bolt, etc.
    Send it to Paul ^ need_a_VR6 He will square it up for you and likely give it a once over to make sure there is nothing out of place.
    In that last pic, I noticed they used a Resistor on the IGN. You can see where I used a straight piece of wire to jump. iirc, the resistor is only used to scope the IGN signal. Not sure if could have caused anything adverse here. My guess is just a crap VB921.
    I am running the stock G60 coil and have been running for over 5 years now since I initially smoked my VB:
    In MS1 my settings were
    6.0 Crank
    2.5 Running
    0.1 Min Discharge
    (Inverted Spark of COURSE)
    In MS3:
    Cranking Dwell: 6ms
    Max Dwell Duration: 2.6ms
    Max Spark Duration: 1ms
    Spark output: Going High (Inverted)
    Some settings may be different in MSII
  25. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    06-22-2012 02:15 AM #25
    Going in the mail tomorrow
    Gordy S
    MK1 x 3
  26. Member ydrogs's Avatar
    Aug 6th, 2005
    Tigard, OR
    07-11-2012 12:32 AM #26
    Got the ECU back back from Paul and it started right up after installing it back in my Scirocco. Thanks goes out to all who helped me work out this problem on here and especially to Paul who replaced the fried transistor.
    Gordy S
    MK1 x 3
  27. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    07-11-2012 04:26 PM #27
    Glad it's back up and running
    -Paul
  28. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 tdi
    07-20-2012 05:34 PM #28
    yeah this...
    vbs dont like to take a lot of dwell... the bosch stuff is much nicer.
  29. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    East of the Mountains, WA
    77' Rabbit 16v, '92 Passat Syncro Wagon1.8t
    08-08-2012 10:35 PM #29
    Was this car ever up in WA? That looks shockingly similar to the car my roomate had YEARS ago.
