VWVortex.com - what size nozzles should i be running?
    Results 1 to 10 of 10
    Thread: what size nozzles should i be running?
    1. Member ridemyfast's Avatar
      Jul 18th, 2010
      baltimore area
      2000 vw gti
      06-20-2012 11:23 AM #1
      i am looking at buying the snow stage 2 kit on friday and i have no idea on what size nozzles i should run. ive tried to contact usrt a few times but they havent responded to my emails
      what i have done:
      stage 2 unitronic
      3 inch turboback
      turbo inlet
      eurojet street FMIC
      cold air intake
      upgraded diverter
      thanks for the help in advance
      I spend money I don't have.
      To buy things I don't need.
      To impress people I don't know.
    2. Member 96AAAjetta's Avatar
      Jul 7th, 2008
      Ft. Bragg/Charleston S.C.
      2002 225TT
      06-20-2012 08:35 PM #2
      USRT wont give you information like that unless you buy a WMI kit from them. But if you're interested to know, you can check here
      http://www.alcohol-injection.com/en/nozzle-selector.php
      It a pretty basic calculator that uses displacement, max boost, and max RPM. It will give you an answer in GPH. You can find a calculator on the interweb to convert Gal/hr to CC/min then round up to the nearest nozzle available to you. If you plan to run 2 or more nozzles they all have to add up to the number the calculator gives you. Then round up, of course.
      Hope this helps.
      If a little's good, then a lot's better, and too much is just right.
    3. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
      06-22-2012 06:39 PM #3
      I always recommend a small nozzle after the FMIC, and an even smaller one post TB. saves your TB while still keeping your IATs nice and cold.
      60 or 100 cc after TB, 175cc after FMIC.
      2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
    4. Member ridemyfast's Avatar
      Jul 18th, 2010
      baltimore area
      2000 vw gti
      06-23-2012 12:44 AM #4
      Quote Originally Posted by 96AAAjetta View Post
      Hope this helps.
      thanks for the link.
      i planned on buying my water/meth kit from usrt since I've heard so many great things about their customer service. i stated in the emails i sent them that i planned purchasing from usrt and i still haven't received anything back.
    5. Member ridemyfast's Avatar
      Jul 18th, 2010
      baltimore area
      2000 vw gti
      06-23-2012 12:47 AM #5
      Quote Originally Posted by Krieger View Post
      where should i place the nozzle in the throttle body hose?
    6. Member 96AAAjetta's Avatar
      Jul 7th, 2008
      2002 225TT
      06-23-2012 11:16 PM #6
      Quote Originally Posted by ridemyfast View Post
      If you're placing a nozzle post IC, you want to put it as close to the exit of the intercooler as possible. As for post TB, you can get a spacer plate that is tapped for the nozzle, or you can pull that vacuum port out of the top of the throttle body(it comes out easily with pliers as it is just pressed in) and tap it yourself. Most folk don't recommend putting one close to the front of the throttle as the meth will eat your TB with the quickness.
    7. Banner Advertiser Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
      07-02-2012 05:22 AM #7
      Why would you say/think that? I would gladly give that info out. Sorry your emails were not answered, i know Scott had some issues with our accounts so they very well could have not been received. Anyway, i should be patrolling this forum a little more so if you have any more questions ask them here or PM me or Justin.
    8. Former Advertiser Justin@USRT's Avatar
      Aug 1st, 2011
      Philadelphia
      04.5 PG GLI
      07-03-2012 11:51 AM #8
      Sorry you have not gotten a response back. I try to answer all of the emails. Please send me an email at Justin@usrallyteam.com
    9. Member 96AAAjetta's Avatar
      Jul 7th, 2008
      2002 225TT
      07-08-2012 12:44 PM #9
      Quote Originally Posted by Quintin@USRT View Post
      I would say/think that cause of this message i got from Scott. Im not trying to bash you guys. Its a perfectly reasonable policy to have. As a tech in an auto repair shop, I've worked up quotes for people that took me a good bit of time only to have them turn down the work or take the quote to someone else, so i understand why you would have that policy. Again, im not trying to bad mouth or speak ill of USRT, im just passing on the info i was given in the hopes that it will help the next guy.
      Scott@USRT
      Forum Sponsor
      Jan 13th, 2005
      Haddon Heights, NJ
      MK4 Jetta 2.0T, Mk1 Scirocco 16v, 323 GTX
      Re: Advice on nozzle size?
      06-05-2012 12:03 PM
      Well, as I mentioned before, we'll happily calculate your nozzle sizes at the point that you are ready to invest. This is USRT policy so as to avoid major investment in a consumer's project only for them to take the information and run to eBay with it. It happened frequently enough for us to adopt this stance. The abuse burns us up big time, creates resentment when there needn't be any, etc. We're not about to be exploited. Of course, this has nothing to do with you individually.
      Scott F. Williams, Team Director
      US Rally Team
      www.facebook.com/usrallyteam
      Reply With Quote Forward
    10. Banner Advertiser Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      07-10-2012 04:05 PM #10
      yea he enlightened me when he saw the post so that was my bad. Odd i never knew that was a policy and i been working with him for 3years now
