Page 1 of 2 1 2 LastLast
Results 1 to 35 of 39
Thread: Will buff right out...
  1. Member unreal's Avatar
    Aug 23rd, 2004
    PA, USA
    2010 Mk6 Golf
    06-21-2012 08:06 AM #1
    ANA/AJX 767-300ER hard landing in Narita a few days back.
  2. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    06-21-2012 08:39 AM #2
    Now THAT is good metal buckling!
  3. Senior Member J-Tim's Avatar
    May 26th, 2000
    06-21-2012 08:49 AM #3
    Yikes!!!
  4. Member Tornado2dr's Avatar
    Mar 31st, 2001
    Split Pants, VA
    06-21-2012 10:17 AM #4
    Holy crap!
    Logic tells me that the plane is probably still flyable, but based on aircraft stress and longevity standards in the industry, is the airframe beneath just a hunk of aluminum scrap right now?
  5. Senior Member spockcat's Avatar
    Jun 4th, 2003
    07 Z4MC, 11 328i Touring
    06-21-2012 11:35 AM #5
    Just needs a little bondo and some fresh paint!
  6. Member kerridwen's Avatar
    Aug 3rd, 2001
    Mexico City, Mexico
    Yamaha XT660R & XT660X
    06-21-2012 04:20 PM #6
    Hull loss / write off?
  7. 06-21-2012 04:24 PM #7
    This'll be flying in a 3rd world shortly...
  8. Member unreal's Avatar
    Aug 23rd, 2004
    PA, USA
    2010 Mk6 Golf
    06-21-2012 05:25 PM #8
    Quote Originally Posted by kerridwen View Post
    This has happened a number of times to the 767-300; as far as I know, most have returned to service.
  9. Forum Sponsor Brendan@bwalkauto's Avatar
    Nov 28th, 2009
    Redwood City, CA
    2001 540/6, LEAF SL.
    06-21-2012 06:32 PM #9
    Quote Originally Posted by unreal View Post
    Speaking from first hand experience?
  10. Member chrismkay3's Avatar
    Jan 16th, 2008
    Winnipeg
    e46 m3
    06-21-2012 08:38 PM #10
    probably not; however, it will almost certainly be a lengthy and very expensive repair
    pilots, how did this even happen?
  11. 06-22-2012 05:26 PM #11
    A lot of work but is repairable. They will shore up the aircraft and remove the skins on the top side that wrinkled, splice in stringer sections were stringers were buckled and then inspect for damage from the nose gear back to the center wing. The repaired aircraft will be as strong or stronger than than the aircraft was before the incident.
  12. 06-22-2012 05:29 PM #12
    Quote Originally Posted by chrismkay3 View Post
    Not a pilot but I believe Narita can be vary tough to land at sometime due to crosswinds. IIRC Fed-Ex lost an aircraft there when trying to land.
  13. Member
    May 15th, 2007
    Fussa, Japan
    06-22-2012 10:30 PM #13
    Go arounds are free folks, remember that.
  14. Senior Member J-Tim's Avatar
    May 26th, 2000
    06-23-2012 07:32 AM #14
    Quote Originally Posted by yz1337 View Post
    Not when you are a 6 feet off the ground.
  15. Member unreal's Avatar
    Aug 23rd, 2004
    PA, USA
    2010 Mk6 Golf
    06-23-2012 09:13 AM #15
    You absolutely can (and should) go around after that kind of bounce. It'll touch back down as the motors spool, but that's not a big deal; you'll avoid the nose slam, which is undoubtedly what caused the damage.
    Big thing about the -300 is not adding forward pressure, even on a normal touchdown. You'll get a slight pitch up moment as the spoilers come out, but that only requires you to let out some back pressure. Landing the nose generally requires light back pressure, nothing forward of neutral. Strong forward pressure can cause forward fuselage damage, even after touching the mains down normally.
  16. Member
    May 15th, 2007
    Fussa, Japan
    06-23-2012 10:52 AM #16
    Quote Originally Posted by J-Tim View Post
    back to ground school and basic airmanship with you
  17. 06-23-2012 04:14 PM #17
    Yup. A go around/aborted landing can be initiated at any time.
    Practicing wheel landings for my tail wheel endorsement found me going around a few times after touching down and having a wicked bounce
    I've also heard of airliners shooting CAT II/III approaches, going missed, and having the wheels touch down due to the low minimums and spool up/reaction time.
  18. Member unreal's Avatar
    Aug 23rd, 2004
    PA, USA
    2010 Mk6 Golf
    06-23-2012 07:54 PM #18
    Quote Originally Posted by joness0154 View Post
    Very true. That's why we train to commit to a go around. Once you hit the "go" switches, you're taking it back in the air, even if you touch down momentarily.
  19. Member
    Dec 11th, 2002
    '03 Golf TDI
    06-24-2012 08:28 PM #19
    ...Landing the nose generally requires light back pressure, nothing forward of neutral.
    In the crazy French contraption that I fly, you release all pressure on the stick on touchdown and the 'derotation program' eases in a little down elevator and brings the nose down with a thunk.
    Very strange. It's smoother if you ease in a little forward stick after the mains make contact, then pull back a teenie weenie bit just as the nosewheel touches. Silly fly-by-wire airplane.
    And yeah, once you decide to go around, you commit and go.
    If it's not foggy
    and you have your fog lights on
    you are a doofus.
    "Pro Tip: Don't **** with people who've been trollin' longer than you've been alive." - OOOO-A3
  20. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    06-25-2012 09:24 AM #20
    Quote Originally Posted by Gern_Blanston View Post
    If you try to override the computer does it just give up and let you?
  21. Member
    May 15th, 2007
    Fussa, Japan
    06-25-2012 10:18 AM #21
    I see it
  22. Senior Member J-Tim's Avatar
    May 26th, 2000
    06-26-2012 07:17 AM #22
    My point is that there is so much inertia is that a massive crosswind like that will slam you to the ground before you have a chance to:
    1. Apply the full throttle
    2. Have the fans spin up and give you enough thrust to get up again
  23. Member
    May 15th, 2007
    Fussa, Japan
    06-26-2012 08:29 AM #23
    thats great, and I agree. That has no bearing here though as the entire issue was pilot induced when he slammed the yoke forward in desperation rather than calmly add power, allow the mains to touch and continue on the go around. The mains can handle a fairly massive impact with little to no damage. Pushing the nose forward in an attempt to get on the ground can have catastrophic consequences, as seen here. He's lucky he just bent some metal.
    Lets put it this way...if he went around but touched down and something on the mains broke, he'd get razzed a lot at work, and probably be flying in a couple of days, case you're right, winds can just screw you. After this though, if he still has a job, i guarantee he has a simulator date for a EP ride/checkride (I dunno what the civilian side guys do/call it), and is sitting nowhere but a jump seat.
  24. Member NHDUBN#2's Avatar
    Sep 5th, 2007
    "Live Free Or Die"
    2006 9-7X 5.3i & a few Surfboards.
    06-26-2012 09:31 AM #24
    What would happen if this was one of the new generation of planes with the Carbon Composite structures? (777)
    Quote Originally Posted by Turbiodiesel! View Post
    I have been drunk many a time, but I can't say I've ever had the urge to sexually abuse a wild animal.
  25. 06-26-2012 01:13 PM #25
    787.
    You will buckle the skin and stringers lol
  26. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    00' VR6 12' V6 TDI 72' 914-6
    06-26-2012 01:22 PM #26
    Quote Originally Posted by Danza. View Post
    787.
    carbon fiber prefers to shatter/splinter rather than buckle.
    Larry
  27. Member NHDUBN#2's Avatar
    Sep 5th, 2007
    "Live Free Or Die"
    06-26-2012 01:24 PM #27
    Quote Originally Posted by .LSinLV. View Post
    I guess thats my point. It would be a instant write off. Would it not?
  28. 06-26-2012 01:38 PM #28
    The stress causing failure is due to buckling. The failure mode is different yes.
    It would be repairable.
  29. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    06-26-2012 01:45 PM #29
    I didn't say it wasn't repairable...but I am sure to costs and QAA would be extensive.
    Larry
  30. Member unreal's Avatar
    Aug 23rd, 2004
    PA, USA
    2010 Mk6 Golf
    06-26-2012 06:57 PM #30
    Crazy French contraption.
    The 777 might do something similar, but I like my old manual Boeing. I was telling a couple of our company 777 pilots how everything in the 767 is connected to something via cables and hydraulic actuators. Hell, even the thrust levers connect to a hydromechanical fuel control; they feel beefy and take a good push to move. I think they were drooling a little bit. Real airplanes for the win!
    It'll still do it, no problem. The engines will only go back to approach idle anyway, which means they're ready to spool up in a hurry if necessary. In fact, adding go around thrust will more than likely spare the nose, as the pitching moment from the underslung engines will bring the nose back up. That pitching moment can be rather impressive if you're not ready for it, so protecting the tail is paramount if you've touched back down.
    Anyway, Japan can get pretty dicey. I landed the aircraft type in question in Japan a few months back with a 35-40 knot crosswind and moderate turbulence down final; I was spring loaded to go around, but the turbulence settled out enough to put it down safely. The airplane is very stable, but the physics work the same as anything else. Just a bad day for this crew.
  31. Member
    Feb 12th, 2001
    douglasville, GA
    92 vw corrado
    06-30-2012 08:06 PM #31
    Actually that totally depends on which model 767. Most have fadec engines, thus no cable to the fuel control. We have cables on our cf6-80a2 motors but t hats it. The rest are fadec engines.
  32. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    07-01-2012 09:15 AM #32
    Quote Originally Posted by NHDUBN#2 View Post
    That and liquefying all the passengers thanks to the billions of carbon shards
  33. Member unreal's Avatar
    Aug 23rd, 2004
    PA, USA
    2010 Mk6 Golf
    07-01-2012 08:48 PM #33
    Quote Originally Posted by twilk View Post
    Busted. I was thinking about our non-FADEC jets.
    We have 7 767s, 2 of which are non-FADEC. Also, our RB211 757 is non-FADEC. Definitely prefer the FADEC from a pilot's perspective.
  34. 07-12-2012 12:23 PM #34
    Quote Originally Posted by stratclub View Post
    I was reading about this on airliners.net, and the consensus was the same, yes, it will be repaired. While this kind of damage doesnt happen all the time, it has happened before, and has been repaired unless the airframe is very old. Im sure boeings go team will be on there way out to work on it soon.
  35. Member
    Jun 2nd, 2002
    Toledo, OH
    Speed6
    07-12-2012 04:28 PM #35
    Wow. It is so freaking cool to have actual 7x7 pilots on this board. I am a total airplane nerd. I will be working on my private pilots license in the next year or so.
    Can't wait.
