Page 1 of 2 1 2 LastLast
Results 1 to 35 of 60
Thread: Yukon XL brake pads & rotor cost...WOW
  1. Member Phil Pugliese's Avatar
    May 18th, 2000
    Reno, NV
    2010 Jetta Sportwagen TDI
    06-21-2012 10:51 AM #1
    We need brakes & rotors on the Yukon and was quoted 700 for the fronts and 700 for the rears..that sounds DAMN high. Anyone else know what a full-sized SUV's brakes should run?
    CLICK * POINT * CHUTE
  2. Member Max Rebo's Avatar
    Apr 11th, 1999
    Pottstown, PA
    '07 BMW 335i
    06-21-2012 10:54 AM #2
    That does sound high. What size are the rotors?
    I'm not looking forward to the day I have to replace the pads and rotors on my 335. Good thing they last a long time.
    Oddfellows Local 726
  3. Member CSFiend's Avatar
    Jan 13th, 2007
    Minneapolis, MN
    03 Outback
    06-21-2012 10:57 AM #3
    Quote Originally Posted by Phil Pugliese View Post
    What year Yukon? Where's the quote from?
  4. Member
    Jan 27th, 2003
    Toyota Sienna Crossover SUV,Nissan GT-R
    06-21-2012 10:58 AM #4
    Where was the quote from, dealer or independent?
  5. Member adrew's Avatar
    Aug 14th, 2003
    Texas
    Yaris x2
    06-21-2012 10:59 AM #5
    Seems high to me. RockAuto says ACDelco rotors are $58.79/ea for the front and $45.89/ea for the rear. Pads are about $40 per set.
    Improving the signal-to-noise ratio
  6. Geriatric Member AKADriver's Avatar
    Nov 20th, 2001
    Unreal VA
    NB Miata
    06-21-2012 10:59 AM #6
    Maybe a little over half that.
    The rotors are similarly priced to the ones for my Honda Odyssey on rockauto. Yes it's a full size SUV, but Chevy/GMC trucks are some of the most common cars on the road, the parts are generally cheap. The pads aren't priced unusually high either.
    The labor rate should be low. The calipers are the standard sliding type based on the shape of the pads in the photos. The rotors are the floating type, the hubs don't have to come off to change them. It should be a totally standard brake job. If the shop is quoting you some sort of surcharge for trucks/SUVs, walk.
    I don't practice llanteria
  7. Member ZoomBoy's Avatar
    Jun 3rd, 2002
    Toronto
    2003 Civic SiR
    06-21-2012 10:59 AM #7
    Buy pads and rotors at NAPA, bring to independent shop to install. Save hundreds.
  8. Junior Member
    Sep 2nd, 2010
    Inland Empire, CA
    2007 Subaru Legacy
    06-21-2012 11:01 AM #8
    GM brakes are the easiest to do. DIY for a fraction of that cost.
  9. Member Phil Pugliese's Avatar
    May 18th, 2000
    Reno, NV
    06-21-2012 11:03 AM #9
    Not sure of the size..it is a 2008 XL 1500 4wd.
    I am not a DIY guy with a job like this.
    The quote is from GMC dealer. I thought it was way high too.
  10. Geriatric Member AKADriver's Avatar
    Nov 20th, 2001
    Unreal VA
    NB Miata
    06-21-2012 11:06 AM #10
    Quote Originally Posted by GrundleJumper View Post
    Yeah, DIY even changing all the little clips and springs and hardware would be around $200 per axle.
    I'd expect an indy shop to be in the $700-$1000 range depending on their parts markup and the labor rates in your area. $1400 has gotta be dealer rates.
  11. Member Fe2O3's Avatar
    Jan 13th, 2009
    Atlanta, GA
    74 Beetle
    06-21-2012 11:06 AM #11
    Quote Originally Posted by AKADriver View Post
    x2
    $1400 is insane, imo.
    Quote Originally Posted by phryxis View Post
    sprayed it on, waited some time, and proceeded to go at it with a scraper, some pliers, and a lot of f-ing hard work.
  12. Member the flying grape!'s Avatar
    Dec 4th, 1999
    08 528i, 02 VW 337, 93 F-150
    06-21-2012 11:07 AM #12
    The garage must be including the replacement of the muffler bearings. Normally you don't have to replace those for a brake job.
  13. Senior Member spockcat's Avatar
    Jun 4th, 2003
    07 Z4MC, 11 328i Touring
    06-21-2012 11:11 AM #13
    You think that is expensive. Typical dealer quote for a Touareg is $1000 to $1200 for front brakes (pads/rotors) alone.
  14. Member GolfTango's Avatar
    Feb 15th, 2001
    Not Fancy CT
    09 Mazda5 GT, 09 Saturn Aura XE
    06-21-2012 11:12 AM #14
    NAPA, Rotors are $50 each for Premium ($50 each rear, $40 each front)
    Ceramic front pads $26
    Ceramic rear pads $36
    Total cost $256 with tax.
    Brake cleaner and pin lube $5
    And two hours of your time and some
    And if you go to Advanced or AutoZone, most of the pads have a lifetime warranty. So bring them back, get new ones...free.
    My flickr
    Me
    The best way to give advice to your children is to find out what they want and then advise them to do it. - Harry S. Truman
  15. Member rpmk4's Avatar
    Jan 24th, 2008
    Plainfield, IN
    13 Wrangler Rubicon, 04 yz250
    06-21-2012 11:13 AM #15
    i believe it. my dad just had his done all the way around on his 01 yukon xl 2500 at the dealer, $1200....
  16. Member Phil Pugliese's Avatar
    May 18th, 2000
    Reno, NV
    06-21-2012 11:13 AM #16
    OK..I an NOT going to do it myself. Any idea where I should take it..extra points if you know a place in Reno.
  17. 06-21-2012 11:14 AM #17
    This must be a stealership quoting you.
  18. Member GolfTango's Avatar
    Feb 15th, 2001
    Not Fancy CT
    06-21-2012 11:15 AM #18
    Buy parts, find shady tree mechanic....two hours of labor at let's say $50-80 an hour. Should be able to find someone in Reno to do it cheap, hell probably could find someone to do it for a case of Busch and $20.
    My flickr
    Me
  19. Member GLI Dan's Avatar
    Sep 28th, 2006
    Tallanasty
    04 GLI Sold, 2004 330ci SMG
    06-21-2012 11:17 AM #19
    Is there another chevy dealer in town? Better yet maybe a fleet dealer? If not that then find a goodyear gemini tire shop, tires plus, discount tire any of the chain places.
    GM uses ac delco stuff which is nearly the most readily accessible car equipment on the planet I'm sure one of those shops will be cheaper.
    Quote Originally Posted by tampaSi View Post
    You could not give me an auction-rat sub $10k E39 M5 for all the blow in Cartegena. Which probably would have at some point been in the trunk of said M5.
  20. 06-21-2012 11:23 AM #20
    Quote Originally Posted by GolfTango View Post
    ^^this dude, go buy all the parts have a indy shop do the work. Since its a really straight forward (easy) job you may have a friend that can knock it out in a couple hours, just buy him some and you're good.
    I have 02' Denali and I'm about to do this job myself.
  21. Senior Member spockcat's Avatar
    Jun 4th, 2003
    06-21-2012 11:24 AM #21
    Call Big-O-Tire. Ask them for a quote on a full brake job on a 2008 XL 1500 4wd. If you like the price, be sure to get a the name of the guy who quoted it and an appointment. If you don't like the price, continue to call around. A GM vehicle like this should be very straight forward for almost any shop. You aren't asking for a brake job on a Ferrari GT250 Berlinetta SWB afterall.
  22. Member Phil Pugliese's Avatar
    May 18th, 2000
    Reno, NV
    06-21-2012 11:32 AM #22
    I called Big 0 and they were over a $1K too. I am kinda new to the area and don't have any mechanic friends..(ski deals..connections..a ton there ) But this IS our second vehicle and I think if get the parts together..I should be able to round someone up. It sucks..when I sold cars back east, I would always have a parts/mechanic guy to do work after hours. I need to expand my social circle out here.
    Thanks for all the help so far...this is still the best car site out there.
  23. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    05 gti , 01 cbr929rr, bicycle.
    06-21-2012 11:41 AM #23
    I run a indy shop and I would prob quote around 800. thats using all high quality parts.
    Dubstatic
    REP860
    CornStatuS
  24. Member
    Sep 11th, 2009
    PHX
    D3 A8L with all the fixins, 4door VR6T, Roofless VR6T, Vanagon, Passat Wagon,
    06-21-2012 11:45 AM #24
    Normally I wouldn't recommend a mobile mechanic but since we are talking about the most remedial job you can do on a car it's probably just fine.
    Inexpensive Mechanic in Reno
    If it's a spare car just order your parts online and when they arrive call some of the listings until you find someone that makes you feel warm and fuzzy. Lots of qualified techs do side work on the weekends to supplement their income. Dont be afraid to ask for qualifications - spending a few extra dollars on a guy that appears to be the most qualified will probably give you peace of mind.
    I browsed the ads a bit and this guy would be my first call - Gary the mobile mechanic
  25. Member mike_A3's Avatar
    Jun 30th, 2008
    NE Ohio
    04 TL 6MT, 06 Ridgeline, 96 Cherokee
    06-21-2012 11:57 AM #25
    I honestly don't know your life situation, but why wouldn't you do it yourself? You can buy the tools and still save money. If its a second vehicle anyways, its no big deal if you mess something up.
    ^^ I probably have no idea what I'm talking about. ^^
  26. Member Phil Pugliese's Avatar
    May 18th, 2000
    Reno, NV
    06-21-2012 12:34 PM #26
    Quote Originally Posted by ..Derek.. View Post
    Yup. Called him. Thanks for the help. Why I didn't check CL for this...D'oh. Gary is the first one I called too.
  27. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    96 Jetta - 300K Club, Truck, Boat, Quad
    06-21-2012 12:37 PM #27
    can't do them yourself?
    rotors and pads are soooo easy.
    There aint no OZ in rape.
  28. Member GolfTango's Avatar
    Feb 15th, 2001
    Not Fancy CT
    06-21-2012 12:39 PM #28
    Quote Originally Posted by WakusPakus View Post
    Yes, we established this already.
    My flickr
    Me
  29. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    06-21-2012 12:42 PM #29
    i know we did.
    doesn't mean i can't ask, now, does it?
    could've had a change of heart, or grew a sack and figured hey, it's worth a shot to save the $.
  30. Member
    Nov 8th, 2002
    Whitefish, MT
    2004 Forester 1997 LX450 1975 Rabbit
    06-21-2012 12:43 PM #30
    Quote Originally Posted by mike_A3 View Post
    He can't even find a mechanic on his own. Probably better he isn't working on the brakes of his 2.5
    ton vehicle.
  31. Member
    Jun 22nd, 2006
    Edgewood, MD
    Euro Ford junk collection
    06-21-2012 12:43 PM #31
    Why are people always surprised that parts for a $60,000 car are expensive?
  32. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    06-21-2012 12:45 PM #32
    Quote Originally Posted by saron81 View Post
    But it is just a Chevy (GMC).
    WOW
  33. Member adrew's Avatar
    Aug 14th, 2003
    Texas
    Yaris x2
    06-21-2012 12:46 PM #33
    Because, underneath, it is very similar to a $20k one of these:
  34. Member rpmk4's Avatar
    Jan 24th, 2008
    Plainfield, IN
    06-21-2012 12:49 PM #34
    i get this all the time. People call in for a ring and pinion on their early 00's F350 dually and are shocked it's going to be $500+. Just because you paid 10k for the truck doesn't mean it uses cheap parts. There is a reason the truck was so expensive new.
  35. Member UncleBens's Avatar
    Oct 30th, 2000
    2011 Hyundai Sonata; 1996 BMW M3
    06-21-2012 01:20 PM #35
    i know we did.
    Maybe someone not so mechanically inclined isn't interested in messing with the most important safety component on the car? you know, like common sense
