Results 1 to 13 of 13
Thread: need help for my 16v gli!! mk2
  1. 06-21-2012 04:43 PM #1
    i have a big problem! i got a 87 vw mk2 gli 1.8 16v, i have rebuilt the entire engine! and the car will not start! i have no current to the distributer i have tried everything i know its an electrical problem but i starting to give up! someone please help!
  2. 06-21-2012 04:51 PM #2
    Check back to the coil, then check back to the ICM.
    where you from?
    Up and Atom!
  3. 06-21-2012 04:57 PM #3
    i have already put in a new coil and checked the icm, the weird thing is that when i turn the key to off it has current! when i turn the key to on it has no spark?
  4. 06-21-2012 04:57 PM #4
    and i am from greensboro NC
  5. 06-21-2012 09:18 PM #5
    im in winston, i have a 92 gli. im not the most tallented tech but i may be able to help if you havent sorted it out
  6. 06-23-2012 10:14 AM #6
    sounds good man, the car is in jamestown, when do you have time to check it out?
  7. Member my02VR6's Avatar
    Jan 6th, 2005
    Sac, CA/ Gresham, OR
    24v 2.9 GTI/90 GLI 2.0 16v
    06-23-2012 07:20 PM #7
    Ignition switch? What exactly does it do when you turn the key? Is the starter engaging? I know you said dist, just checking everything. Check all the grounds and clean/check all electrical connections.
    02.5 24v GTI: 2.9L, JE pistons, IE rods, eurospec 264/260° cams, Wavetrack LSD, TT dp/hiflow cat, 2.5" TT catback/ borla, Oettinger, 18x8 RS-GT on BF Goodrich, Brembo GT front BBK, 28mm/25mm Neuspeed swaybars, H&R coilovers, etc. More info & pics
    90.5 16v GLI: Calypso green, >30mpg, 15x7.5 RMs, 195/50 Yoko Sdrives, PSS9s, 2.25" TT catback/ borla, USRT shift kit, .80 5th.
  8. 06-24-2012 02:37 PM #8
    yea brand new ignition switch 2 haha its a headache
  9. 06-28-2012 11:42 PM #9
    might sell the car now if any good offers out there! or maybe trade for a swap!
  10. Member 91JET16V's Avatar
    Jan 6th, 2012
    Tri Cities, WA
    1991 Jetta 16v, 1986 Jetta 8v, 1998 GTI VR6, 2003 GMC 1500
    06-29-2012 04:53 PM #10
    So the car ran before you rebuilt the engine?
  11. Member 91JET16V's Avatar
    Jan 6th, 2012
    Tri Cities, WA
    06-29-2012 04:56 PM #11
    You don't have the wires going into the coil reversed or something?
    Why did you replace your ignition switch? Was it a issue before? Is it a brand new switch?
  12. 06-30-2012 09:46 PM #12
    yes it has a brand new switch, and the coil is connected correctly, and the car did not run when we bought it so we did a complete rebuild on thi engine,
  13. Member 91JET16V's Avatar
    Jan 6th, 2012
    Tri Cities, WA
    07-01-2012 12:53 AM #13
    I think in this situation you need a Bentley manual and need to start checking out all wires that have to do with the ignition system, this is assuming your computer is good. You could have a bad connection on a wire, break in a wire inside the housing, maybe somebody wired something backwards? I would check a wiring diagram and start checking continuity, and double check everything is wired correctly. How is your Hall sender?
