Results 1 to 7 of 7
Thread: MSed 16v doesn't like it when it's hot.
  1. 06-21-2012 04:55 PM #1
    whenever the air intake temp gets abover around 40, it barely idles and has little power.
    Is there a table i should be looking to tweak?
    Up and Atom!
  2. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    06-21-2012 08:05 PM #2
    What is your setup?
    FS:Sunroof Deflector
  3. 06-21-2012 08:20 PM #3
    2.0 16v
    MS1 V3.0
    P&P Head
    4 2 1 header
    Schrick 276 cams
    317cc injectors
    ITG Maxogen
    2.75" intake
    50mm Intake manifold
    8lb Flywheel
    factory 9A bottom with ARP
    Up and Atom!
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    06-21-2012 08:23 PM #4
    Where is it getting that hot of air? Which IAT do you have and where is it mounted?
  5. 06-22-2012 06:46 AM #5
    I'll have to check which one, but it is mounted right before the throttle body.
    Up and Atom!
  6. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    06-22-2012 08:22 AM #6
    I would think you want the open element sensor, I find that even with mine mounted in the middle of the intake tube it still heat soaks some. And being that it is density based, it will lean it out. How much authority do you give the ECU for correction? It should be able adjust for this and still have decent power.
  7. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-22-2012 03:00 PM #7
    Is the AFR noticeably changing, or is it something else?
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
