#1
In the process of replacing my wheel bearings a few days ago, I bent up the reluctor/speed sensor ring on the front drivers side. After putting the car back together, the ABS system kicks in on that wheel almost every time I stop the car. I have a new wheel hub on order, but it will take a week or so to get here, so I pulled fuse #9 from inside the car so I could at least drive it.
1) The ABS and traction light are on, and the BRAKE light is flashing, I'm guessing this is normal because I unplugged the ABS fuse, can anyone confirm this should be happening?
2) Will it hurt the car to drive it for a few days with ABS disabled?
3) Should I pull the ABS and ABS pump fuse from under the hood too, or just the #9 fuse in the cabin?
Thanks.
Whatever happened to sex drugs and rock n roll? Now we just have aids crack and techno.
#2
#3
