Results 1 to 2 of 2
Thread: What oil should I use for my 2004 R32?
  1. Member Dub$_Lifestyle's Avatar
    Jan 6th, 2012
    Portland, OR
    2004 RS .:R32
    06-24-2012 11:54 PM #1
    I know there is different types like 0w-40, 5w-40 and so on so which would be best for my car it has 62k on the odo
  2. 06-25-2012 12:54 AM #2
    In your climate, you could use 10w-40 dino if you don't mind changing it every 5000 miles. If you want to go longer, any 5w-40 will do the job and start better when/if it goes below freezing.
    Synth oil simply isn't needed w/o a turbo, or if you're doing extended drains.
    Ok, since I know people will bust my balls on this, try out the oil selector on castrol.co.uk
    http://www.castrol.com/castrol/secti...tentId=7073092
    Golf VR6
    EDGE 5W-30
    Magnatec 10W-40
    I'd use Pennzoil or Havoline. They work great in German engines, lots of moly.
