Page 2 of 2 FirstFirst 1 2
Results 36 to 44 of 44
Thread: 2005 MK4 2.0 non turbo - Where the hell is the fuel pressure regulator????
  1. Junior Member bybcworld's Avatar
    Jun 21st, 2011
    Pittsburgh Pa
    2005 Jetta Mk4 2.Slow!
    07-03-2012 09:34 AM #36
    Open hood...remove battery cable... wait 15 min... replace battery cable...get in car... leave drivers door open... turn key to on position and push pedal to floor for 15 seconds... turn key off while pedal is to floor... turn key to on again wait 5 minutes (don't touch pedal) while TB whirs and then stops... turn key off... close hood... get in close door... start car.
    There was a thread about how that MAY??? do a TB alignment after removal and then re install so since I did not have a VCDS set up I tried it.
    VCDS should hopefully arrive today so I can do it correctly!
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    07-03-2012 10:49 AM #37
    That's a new one to me. Sounds like somebody combined a nice hit of crack with a dash of wishful thinking
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  3. Junior Member bybcworld's Avatar
    Jun 21st, 2011
    Pittsburgh Pa
    07-03-2012 11:32 AM #38
    Ill see if I can find the thread to show ya! Its pretty interesting!
  4. Junior Member bybcworld's Avatar
    Jun 21st, 2011
    Pittsburgh Pa
    07-05-2012 09:34 PM #39
    So I did my TB alignment with the new VCDS (I love that thing man!) so we will see what happens in the morning when I go to start her up. I ran a full scan first and I did not have one single fault code (see below).
    BTW here is the link to that chicken dance thread I was talking about...
    http://forums.vwvortex.com/showthrea...ithout-vag-com
    You most definitely can see and hear the alignment being done when you use Vagcom like your supposed to! Its awesome! Worth every penny!
    Thursday,05,July,2012,19:20:50:21345
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 9M - VW Jetta IV
    Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
    75 76
    VIN: 3VWSK69M45M017963 Mileage: 113980km/70823miles
    Address 01: Engine Labels: 06A-906-032-BEV2.clb
    Part No: 06A 906 032 RE
    Component: 2L A4 AT4 G 6381
    Coding: 00003
    Shop #: WSC 00066
    VCID: 72E52D593EB4009
    3VWSK69M45M017963 VWZ7Z0D9667838
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01M-927-733.lbl
    Part No: 01M 927 733 MR
    Component: AG4 Getriebe 01M 5077
    Coding: 00000
    Shop #: WSC 00000
    VCID: 8C19D3A1BC50F69
    Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
    Part No: 1C0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0004097
    Shop #: WSC 00066 000 00000
    VCID: 336BE85D512E491
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 F
    Component: 04 AIRBAG VW61 0202 0003
    Coding: 12340
    Shop #: WSC 00066
    VCID: 27530C0DC5F6351
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J5 920 906 K
    Component: KOMBI+WEGFAHRSP VDO V55
    Coding: 15232
    Shop #: WSC 00000
    VCID: 356FD6450F5A571
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00066
    VCID: F0E1A751B0B8B29
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 C
    Component: 1H Komfortgerát HLO 0004
    Coding: 00258
    Shop #: WSC 00066
    VCID: 3773DC4D1556A51
    Subsystem 1 - Part No: 1C1959801A
    Component: 1H Tõrsteuer.FS KLO 0202
    Subsystem 2 - Part No: 1C1959802A
    Component: 1H Tõrsteuer.BF KLO 0202
    Subsystem 3 - Part No: 1C0959811A
    Component: 1H Tõrsteuer.HL KLO 0202
    Subsystem 4 - Part No: 1C0959812A
    Component: 1H Tõrsteuer.HR KLO 0202
    Address 56: Radio Labels: 3B7-035-1xx-56.lbl
    Part No: 3B7 035 180 G
    Component: Radio ZSW 0016
    Coding: 00031
    Shop #: WSC 00066
    VCID: 24491B01B4C0DE9
    End ---------------------------------------------------------------------
    Mar 6th, 2002
    1998 GTI 2.0
    07-06-2012 08:13 AM #40
    No faults, all readiness set, you're good to go
    Yeah, that tool is awesome
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  6. Junior Member bybcworld's Avatar
    Jun 21st, 2011
    Pittsburgh Pa
    07-06-2012 09:40 AM #41
    OK so I went to start the car this am and it still did the same thing (after new plugs, throttle body removed and cleaned, and vagcom TB re alignment) so I guess next will be replacing that fuel filter/regulator.
    It is running awesome though after that first cold start attempt!
    I am going to have the battery checked also to be sure it is putting out the correct power on that first cold start.
    Is it weird to enjoy/look forward to working on and trying to fix your VW??? LOL!
    Mar 6th, 2002
    1998 GTI 2.0
    07-06-2012 11:22 AM #42
    When the engine is cold (has been sitting overnight), turn the key on, DO NOT START THE ENGINE, observe ECT and IAT in measuring block 004. They should be within a couple degrees of each other, both plausible given ambient temps. If ECT is not plausible, replace that sensor.
    Once at operating temp, what are the values in 01-08-032?
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  8. Junior Member bybcworld's Avatar
    Jun 21st, 2011
    Pittsburgh Pa
    07-08-2012 08:10 PM #43
    OK checked these this morning. ECT was 30.0C and IAT was 30.0C
    The battery voltage was 12.2 V
    I remember reading somewhere that a good battery voltage was closer to 13 volts?
    Also (and this may just be a fluke thing) when I tried to start the car after doing these checks with the key in the on position for a few minutes it started right up on the first try ??????
    EDIT: One thing that has been f-ed up on this car since day one that I need to repair is the alternator wire is fried at the battery end to the point of where it actually has partially melted to panel on the top of the battery. I understand this is a common problem on these cars and I was going to eventually replace that and I am wondering if that could be causing this non 1st start in any way?
  9. 08-27-2012 03:13 AM #44
    Quote Originally Posted by bybcworld View Post
    Hello,
    Im having fuel problem with my 2004 jetta 2.0L BEV non turbo and I think its either the fuel pressure regulator or the fuel pump. I connected fuel pressure guage and the gage goes to about 15 psi when the car wants to die. Anyway where did you purchase your VCDS? Also, anyone out there have any input about the issue I am having? The car also shuts down (stalling) when really hot but will normally turn over if you wait few seconds.
    Thanks in advance?
