Page 1 of 2 1 2 LastLast
Results 1 to 35 of 37
Thread: f.s audi 2011 audi a3 radio
  1. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    1992 jetta/2008 audi a4
    06-25-2012 09:25 PM #1
    like the title says I have a 2011 radio for sale used for about a week before upgrading to navi
    no issues scratches or any defects with radio code
    200$
    Looking for 195/45r15 toyo t1r's ? If so contact me for details
    mk1 parts http://forums.vwvortex.com/showthrea...1-gti-part-out
  2. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    06-26-2012 10:45 PM #2
    Bump
  3. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    06-29-2012 10:50 AM #3
    Make an offer or trade
  4. Member NBPT_A3's Avatar
    Jan 1st, 2011
    Southie
    06 8p
    06-29-2012 01:30 PM #4
    I just want your dub din and cage....give it, now.
    FSI, Lava Grey Inside Black Dipped Outside, Stoptech Big Kit, Bilsten Struts, H&R Springs, GIAC 93 Octane Flash, 6000K HID, Forge Atmospheric Spacer, Carbonio intake.
  5. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    2003 Silverstone GTI 1.8t(Gone), 2006 Brilliant Red Audi A3 3.2Q
    06-29-2012 01:47 PM #5
    Just out of curiosity, what is the difference between this and the symphony II other than the bigger screen?
    Mods:Unitronics Stage 1+ | UM DSG Tune | Magnaflow Catback | HPA SHS Coilovers | MODSHACK VTDA intake
    VRSociety #172
    Quote Originally Posted by Boost112 View Post
    Interests:Food being shoved in hot chicks faces.... and other stuff....
  6. Member VWAddict's Avatar
    Jun 12th, 1999
    Orlando, FL
    '08 Audi A3 (8P), '99 Golf MkIV, '89 Porsche 951S
    06-29-2012 02:55 PM #6
    Quadlock versus ISO connectors.
    Different coding and different external connectivity and serial communication with things like OEM iPod interfaces... I think you need to replace any iPod docks etc with a newer spec to communicate with this.
    Also, VERY different diversity. This is the Symphony 2+. The older Symphony II used switched diversity, the newer Symphony 2+ uses phase-diversity. Apart from the antenna connections being different, (Fakra versus older ISO) only one antenna of the two will work correctly. Most people just 'cheat' the same signal into both antenna inputs using a 'signal splitter', but the diversity doesn't function correctly that way, so you lose signal in low signal strength/high-noise environments.
    You can 'correct' the problem by replacing the two antenna boosters in the rear hatch, and changing some of the wiring. then adapting the second connector behind the dash.
    In terms of the rear hatch, it's the reverse of doing the RNS-E conversion, which I did a few years ago.
    Read this link from page 4 onwards... you need to do the reverse to get this to work correctly.
    http://audiforum.us/threads/converti...th-rns-e.5662/
    The correct solution is posted a=on post #79. -It used to be on page 8, but now it's on page 4.
    When I sold my Symphony 2+ unit, I included the two antenna amplifiers from the hatch, and sent the buyer a print of this how-to page also. -Everything worked flawlessly, I understand. -I recall that I sold it for $115 shipped, including the two amplifier modules.
    Quote Originally Posted by MisterJJ View Post
    A "jump from a VW to an Audi"?!? I wouldn't call it a jump. It's more like shuffling along the sidewalk, tripping on a crack, bumping into a gorgeous blonde, walking away in a daze, and later finding out that she stole your wallet.
  7. Member VWAddict's Avatar
    Jun 12th, 1999
    Orlando, FL
    06-29-2012 03:02 PM #7
    Here's a schematic of the differences between phase diversity and switched-diversity ("Schaltdiversity" in German):
    This graphic precedes the Symphony 2+, but the newer Symphony 2+ is phase-diversity, and the older Symphony 2 and Symphony1 were both switched-diversity.
    Actually, GreyJetta, if you have access to VAG-COM and you scan your car, you'll notice a fault code saying 'ZF Antenna Short-To-Ground" because since you've swapped a navigation in place of a Symphony, you'll have the newer phase-diversity amplifiers connected into a switch-diversity head unit...
    So if you sell this to someone with an older head unit, you should trade rear hatch amplifiers with the buyer, and then add the 90cM fakra cable and 3-pin connector cable as described in post #79 of that link which I posted earlier.
    That way you'll BOTH end up with the correct amplifier modules and you won't have the 'ZF short-to-ground' fault code permanently showing up on your scans.
  8. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    06-29-2012 06:58 PM #8
    I have a 2008 A3. I bought the radio from a friend that up graded to navi. I have oem navi So I don't need this stereo unless I use it for a garage radio or in my 1981 caddy
  9. Member VWAddict's Avatar
    Jun 12th, 1999
    Orlando, FL
    06-29-2012 08:16 PM #9
    It doesn't work as a garage radio at all well unless you have the correct antenna & amplification system... that was EXACTLY what I was going to do with my old one, before I tried feeding it. it'll play CD's, and that's about it. -No radio.
    A1 Caddy... (LOVE the A1.. I've owned a couple, even got married in one!) tougher still to make it work. _Specially with the A3 shape (It doesn't fit in a single DIN or even a Double DIN hole; faceplate it too big.
    It WILL work excellently in your 2008 A3. All non-navi A3's after 2007 were prepped with phase-diversity antenna systems from the factory.
  10. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    06-30-2012 12:18 PM #10
    Quote Originally Posted by VWAddict View Post
    I never listen to the radio only cd's or aux or satellite radio so no worries there
    for the fitting in the caddy, I'll be installing a mk2 dash to update the interior a little Since I already have a full digifiz so I can relocate the hvac controll lower and trim the Audi radio to fit .
  11. Member VWAddict's Avatar
    Jun 12th, 1999
    Orlando, FL
    07-01-2012 05:10 PM #11
    That'll work I think. -Be mindful however that (and you can check this by looking at the one you have) the controls on the front panel extend out BEYOND the extent of the double-DIN backbox, and past the Double-Din standard fascia size... This means that it won't fit into a standard double-din location, though -depending on how generous the clearances are on an A2 dash- you MAY be able to get it to fit.
    Be mindful also that it won't shut off with the key, unless you use the 'accessory' positive feed to POWER the radio... in which case you'll always have to enter the code every time you turn the key. -There's no 'switched-positive' connection that 'turns on' the Symphony 2+, that happens over the CAN bus. -My Porsche has a double-DIN radio slot, but in that particular case, there is nowhere near enough clearance to allow for a larger front panel (to include the buttons & switches etc) so it wouldn't work... When I powered it up on the bench and looked into the wiring options, it also became clear that it was going to ALWAYS stay on after the key is removed, also power off after a set time period (I forget if it's 30 or 60 minutes) since it never gets the CAN bus message that the key is in the 'run' position, so it always does the 'power down to save the battery on the assumption that someone may have left the radio running in the parking lot' option.
    You can find out for yourself how long that default 'timeout' period is, by just powering it up on the bench with a CB radio power supply clipped to the appropriate pins on the Quadlock, then entering the code, telling it to play the radio or CD ow whatever, and seeing how long it stays on for. -After a while it powers off. -You can then power it back up WITHOUT having to re-enter the code since the power hasn't been interrupted since the code was last entered.
    That's why I sold mine in the end... couldn't really dig the idea of a garage radio that kept powering itself down, and -even if I rigged a way to jimmy it into the 951's dashboard (filing down the two side 'lips' around the dash reces and smoothing them would possibly have worked) but that still left me with something that kept powering itself down, and either stayed on when I took the ey out (until it powered down again after whatever the timeout period was) or -if I wired id so the power cut off when the key was removed) had to have the code entered every time I wanted to turn it on.
    In the end it only really works in a CAN-bus enabled Audi, I decided.
  12. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-01-2012 07:57 PM #12
    Hmm that is something I'll have to think about. I had my rnse unit hooked up in my garage for a while just had it wired to a toggle
  13. Member VWAddict's Avatar
    Jun 12th, 1999
    Orlando, FL
    07-02-2012 08:37 AM #13
    Cool... you're obviously well up to bench-testing the unit to evaluate it then... -Probably best if you power it up and run a couple of speakers (don't forget, you have to add an amplifier for the rears) and assess its behavior.
    In addition, find out if it came from a BOSE-equipped car, since if it's set up for the Bose config, then the front amplifiers will be disabled... if you have a VAG-com, you can just throw it in your car, then check the way it's coded and make any necessary changes, if you want to use the internal amplifier for the front channels. (rears will HAVE to have an amplifier, since they're only line-level output.
  14. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-02-2012 07:06 PM #14
    Bump
  15. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-03-2012 09:26 PM #15
    Make me a offer
  16. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-05-2012 03:57 PM #16
    Up up and away
  17. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-08-2012 07:14 PM #17
    Bump offers or trades
  18. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-17-2012 06:58 PM #18
    Trades or offers ?
  19. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-23-2012 04:14 PM #19
    Bump might have a brand new hvac face lift control for sale also
  20. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    07-26-2012 05:49 PM #20
    TTT
  21. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    08-09-2012 04:39 PM #21
  22. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    08-13-2012 10:14 PM #22
    140$ shipped
  23. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    08-17-2012 02:04 PM #23
    Bump eBay bound soon
  24. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    08-25-2012 04:56 PM #24
    TTT
  25. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    09-09-2012 12:38 AM #25
    Bump TTT
  26. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    09-17-2012 06:43 PM #26
    Bump
  27. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    10-02-2012 04:50 PM #27
    Bump
  28. Member 155VERT83's Avatar
    Aug 1st, 2000
    Alexandria, VA
    '11 MBZ C300 4MAT Sport, '99 Audi A4 2.8Q
    10-05-2012 10:42 PM #28
    Quote Originally Posted by greyjetta View Post
    Bump
    Is your TT flat bottom steering wheel still FS?
    Signature blank...
  29. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    10-06-2012 10:08 AM #29
    Sorry the steering wheel sold. Radio still for sale
  30. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    10-14-2012 06:59 PM #30
    stereo for sale
  31. Member Ponto's Avatar
    Jan 11th, 2012
    Edmonton, AB
    2007 Lava Grey A3 3.2, 1958 Beetle Deluxe
    10-17-2012 10:41 PM #31
    I am interested!
    Picking up my 2007 next week...
    Kinda skimmed through the thread, but I would have to do some work with coding to get it to work? Or what?
    (might go back and read...) ahaha
    Quote Originally Posted by NBPT_A3 View Post
    And I'll be like "Don't speak to your mom like that, get back to polishing those wheels"
    2007 A3 Lava Grey 3.2VR quattro
  32. Member VWAddict's Avatar
    Jun 12th, 1999
    Orlando, FL
    10-18-2012 08:15 AM #32
    This is the one which reads MP3 CDs, yes.
    It has a Quadlock connector for most of the goodies, and a FAKRA connection for the antennas. -If you're swapping an earlier radio in, you'd need an ISO-to-Quadlock conversion harness, as well as a Fakra converter, and for full radio reception you should change the two amplifier modules in the rear (to address the different divergence issues), and swap out some FAKRA cables back there too.
    I did the amplifier conversion the other way around in my car (going from this style radio to the NAV). It's very doable for anyone with patience, no need to get a garage/installer involved or anything like that.
  33. Member Ponto's Avatar
    Jan 11th, 2012
    Edmonton, AB
    10-18-2012 08:25 AM #33
    Easy peasy then! haha I should be able to figure it out.
  34. Member Ponto's Avatar
    Jan 11th, 2012
    Edmonton, AB
    10-18-2012 08:25 AM #34
    double post whoops
  35. Member greyjetta's Avatar
    May 3rd, 2006
    scarborough
    11-25-2012 02:28 PM #35
    Bump
