Results 1 to 11 of 11
Thread: stripped CV bolts
  1. Semi-n00b SneekyPete's Avatar
    Jul 4th, 2011
    Virginia Beach
    Momma's Golf, 98 jetta w/ 50% floorboards, 96 GTI 2.0"Dust Muffin"
    06-26-2012 01:05 AM #1
    o2o trans Pulling the passenger axle and two of the bolts (8mm triplesquare) are completely stripped. I mean stripped! I tried two diff types of screw extractors on the inside, nope. Bolt extractor on the outside, not enough clearance. Vice grips grab ahold of them, but i cant turn 'em becuase theres no room to. Any Ideas??? before i beat the heads off of 'em and hope i can get the threads out of the output flange. I imagine someone on here has had the same problem before. THX
  2. Member One_Off_Volk's Avatar
    Nov 30th, 2011
    L-Town, NH
    mk6 jetta, 1992 corrado r32 (in progress)
    06-26-2012 01:07 AM #2
    Weld a nut/screw to it and then do it. I just did that today. its annoying to do
  3. Semi-n00b SneekyPete's Avatar
    Jul 4th, 2011
    Virginia Beach
    06-26-2012 02:25 AM #3
    You think JB Weld will hold??? Thats the only welder i have right now.
  4. Member Scrubbs's Avatar
    Mar 13th, 2006
    GB Maryland
    Mk2,s Mk3's
    06-26-2012 01:11 PM #4
    no jb weld wont hold. when you take those bolts off, always make sure you clean the hole out. so the socket fits all the way in. But, since its already toast, take a brass drift and hit the heads of the bolt at the sides of the bolts. it will stretch them enough to allow them to be loosened. and of course replace them with new bolts. If the vice grips didnt work, get a new pair, and only use the outer part, there is just enough swing to loosen the bolt. you may have to reclamp 2 or 3 times.
  5. Member turbinepowered's Avatar
    Mar 18th, 2007
    Southeastern US of A
    '86 Interceptor 700, '82 Quantum Coupe, '89 Fox Wagon
    06-28-2012 12:34 AM #5
    Scrubbs covered everything I was going to recommend, I just want to thank the OP for spelling "stripped" correctly.
    I see "striped" all. the. time.
    Buy my Nighthawk?
    There is an area of a normal brain that lets the owner know the object works and needs to be left alone. Not all of us have it. It is like being colorblind.
  6. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    07-15-2012 01:40 PM #6
    Drill the heads off and the shank will come out by hand.
    FS:Sunroof Deflector
    Jun 15th, 2011
    North Carolina
    05 Passat Wagon, 1988 Cabriolet
    07-17-2012 07:49 PM #7
    Quote Originally Posted by ps2375 View Post
    If an extractor that goes on the outside of the bolt will not fit, this is the best way! Good luck..
    If they were not totally stripped out, I would try hammering in an allen...
    Working hard to show everyone that not all dealer mechanics are crooks. Most of us really care about our customers and their cars. You can read all about it on the car blog
    Any thoughts I post are my own. I am not speculating on any repair VWoA is making, has made, or will make.
  8. Member bennyboopy's Avatar
    Jul 28th, 2004
    2008 R32, 1995 2 door XJ, 1983 mulletmobile Camaro
    07-18-2012 01:27 PM #8
    One thing I have done in the past is to cut a slot into the bolt with my die grinder/dremel. Then I took a nicer steel(craftsman I think) 3/8" extension, chopped it down and cut it so it was just a straight slot at the end(like a screwdriver, but doesn't come to a point) maybe 1.5mm thickness by 10 mm protruding out. You can then use a ratchet and get much better leverage than a screwdriver. Even works in many tight spaces.
  9. Member Angrygilmore's Avatar
    Sep 28th, 2008
    ny
    87 scirocco 1.8 16vt with gotech mfi, 2001 gti 1.8t
    08-02-2012 07:22 PM #9
    hammer in a torx
  10. Member xpalendocious's Avatar
    Nov 28th, 2003
    El Sobrante CA
    560AWHP VR6T Quattro 92 GTi / 2004 Touareg 4.2 / 1992 GTI VR6 PRPLVR6 / 88 Vanagon GL Weekender
    09-15-2012 09:36 AM #10
    A bit late to the game, but hammering a 12 point 12mm socket over the outside always does the trick for me
    My VR6 Turbo Quattro Golf
    Antaki Motor Work - Mechanic for Hire - NorCal area
  11. Member rubndub's Avatar
    Feb 9th, 2008
    Ottawa Ont. Can.
    1996 Surf Green GTI
    10-06-2012 04:44 PM #11
    Quote Originally Posted by xpalendocious View Post
    This works for me every time. Go slowly!
    Surf Green is sick!
