Results 1 to 4 of 4
Thread: '86 Rocco/ 8v - vacuum deleting advice
  1. Member Slowlow's Avatar
    Oct 25th, 2008
    Kingsport, TN
    '56 Single Cab, '62 RustSlut, '86 Scirocco II, '02 GTI
    06-26-2012 05:50 PM #1
    Hey all! I've got this '86 scirocco 8v, and it could use some vacuum lines. While I'm in there I'd like to delete any unnecessary plugs or hoses!
    I'm not concerned with smog/ emissions etc.. Just want the least amount of lines I can get away with.
    Thanks ahead of time!
    Sam
    Aug 14th, 2005
    Germany
    06-27-2012 03:33 AM #2
    That engine really does not have an excessive amount of lines attached. Sure there are two or three which can be deleted but their function out weights their removal I think. It is not really a matter of emission control, that engine is kind of "pre-emission", it is a matter of a better running engine, driveability. For the sake of removing a foot or two (maybe) and a small device or two you end up with an engine which just does not work as well. If that's your wish then just slap on a carburetor and delete almost everything under the hood except for the motor.
  3. Member Slowlow's Avatar
    Oct 25th, 2008
    Kingsport, TN
    06-27-2012 12:33 PM #3
    I'm too used to aircooled cars with basically no vacuum.. To me this thing has a ****load of lines.
    Anyone else?
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    06-27-2012 02:23 PM #4
    Convert it to MS, then you only have 2 vacuum lines. One for the brake booster and one to the MS unit. This does requite you to switch to the digi dizzy and run fuel and spark via the MS. And you delete all of the injector lines.
    Like so:
    FS:Sunroof Deflector
