VW Dual Port Race Engine? - Needs Rebuild Motor has been sitting outside for several years. Great parts engine, or rebuild if you decide to rebuild it WILL NEED A REBUILD! Engine is stuck. A lot of good parts---Good Case. Bought this a long time ago- I Was told this was a 1914cc build engine (used to have 48IDA's but sold the carbs, so there is no carb(s) on the engine. No carb, no intake, no manifolds. 12V Case # VW 000.101.102B stamped on the side of the engine's oil sump. not the deep sump. No markings in the usual spot, below the firing order on the gen stand. Power pulley. External oil cooler with stock oil cooler block off plate, hose mount. over sized oil pump gear cover. dual port intake, 36 hp shroud, 0 231 129 010 Distributor with no vac adv. aluminum clip on valve covers. One weird J tube comes out right below the push rod tubes on the drivers side, other one is missing. $150- LOCAL PICKUP ONLY. Must pick up in Waterville, ME. 423-nine30-6400. Call/text/email
