Page 1 of 2 1 2 LastLast
Results 1 to 35 of 44
Thread: awp wiring thread
  1. 06-28-2012 08:42 PM #1
    heres the low down on awp wiring for most swaps check the bently to make sure colors are close more or less wires I removed the ones i didnt use and capped them off
    this ones going into my corrado cut and solder to fuse box
    awp or most motor codes corrado fuse box
    AWP SIDE----------------------------------------------------------CORRADO SIDE
    DLC t16 16 pin plug
    pin 1 black/blue {-------------------------------------------------------} Q/03
    pin 2 blank
    pin 3 blank
    pin 4 brown {---------------- ground----------------}
    pin 5 brown {---------------- ground ---------------}
    pin 6 orange/black {---- connects to T32a in spedo cluster and T10w pin 2----}
    pin 7 grey/white {---- connects to T32/T32a and orange plug T10----}
    pin 8 blank
    pin 9 blank
    pin 10 blank
    pin 11 blank
    pin 12 blank
    pin 13 white/red {---- connects to pin 1 white plug T10w----}
    pin 14 orange/brown {---- connects to pin3 white plug T10w T32a cluster----}
    pin 15 blank
    pin 16 red/white {----------------------------------------------------------------} Q/03
    orange plug T10
    pin 1 gray/white {---- connects to pin 1 on DLC----}
    pin 2 red/green {---- blank----}
    pin 3 black/green {---- connects to back up lights----} F/07
    pin 4 blank
    pin 5 blank
    pin 6 blue/white {---- connects to speed sensor in the cluster ----}
    pin 7 green {---- coolant fan control ----} A1/05
    pin 8 blue/red {---- a/c switch ----} N/05
    pin 9 blank
    pin 10 black/blue {---- brake lights ----} E/03
    brown plug T6
    pin 1 black/purple {---- ECU control connects with T14 ----} G1/10
    pin 2 purple/white {---- fuel relay----} G1/03
    pin 3 red/black {---- stater interlock ----} F/01
    pin 4 red/green {---- ECU ----} F/05
    pin 5 blue/yellow {---- control elements ----} G1/04
    White plug T10w
    pin 1 white/red {---- Goes to pin 13 DLC T16 ----}
    pin 2 black {---- Goes to DLC connects to all orange/black----}
    pin 3 white {---- Goes to DLC connects to all orange/brown----}
    pin 4 white/red {---- Goes to Clutch switch----}
    pin 5 brown/red {---- Goes to alt light in cluster ----}
    pin 6 brown/red {---- thermostat in raditor ----} A1/05
    pin 7 blank
    pin 8 blank
    pin 9 blank
    pin 10 blank
    T14 in the engine
    pin 1 green/black {---- oil pressure switch ----}
    pin 2 black/green {---- powers speed sensor switch 20a fuse ----}g1/11
    pin 3 green {---- speedo goes to T32/28 blue plug behind your speedo ----}
    pin 4 purple {---- engine coolant temp
  2. 06-30-2012 04:51 PM #2
    bump
    Sep 11th, 2009
    MN
    1990 Corrado AWP 20v 1.8T
    07-04-2012 09:26 PM #3
    What the **** is Q? What is Q to?
    I only used F, G1, G2 and (S; which you kind of minus since that is for the wipers) Z1 and IIRC Y.
    Supply pictures- interested in seeing how you did this. My route-
    http://forums.vwvortex.com/showthrea...20v-1.8T/page4
    it's not that I can't do it, it's that I don't know how yet...
  4. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    07-04-2012 11:33 PM #4
    Q is Alot if dash stuff. http://a2resource.com/electrical/CE2.html has Alot of good info.
  5. 07-05-2012 05:01 AM #5
    Quote Originally Posted by 2OVT View Post
    Q/03 is to 7.5 fuse from the corrado for the DLC in the bently for the 1.8t side
  6. 07-05-2012 05:02 AM #6
    hey bonesaw am i in the right direction
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    07-05-2012 10:26 AM #7
    If I recall correctly it just needs switched ignition.
    Sep 11th, 2009
    MN
    07-05-2012 11:04 AM #8
    Quote Originally Posted by $800rado View Post
    I'm confused. If you're doing a partial swap (splicing AWP to CE2) then why do you need to mess with Q? What part of Q is to which harness? Just interior?
    Q/03 Cigarette Lighter, Radio, Amplified Speaker Power
    explain to me why you need this, please? And wtf is the DLC?
    Also- did you use both sides of the T14?
    Sorry- I'm still figuring my wiring out.
  9. 07-05-2012 04:10 PM #9
    this would work out so much easier for you guys
    T6-brown connector
    pin 1 -black or black/purple 15 amp fused switched live 15 to ecu T121/3 Y (g1 pin 4, needs fuse)
    pin 2 - purple/white ecu T121/65 to fuel pump relay earth Y (g1 pin 3)
    pin 4 - red/green 20 amp fused constant positive 30 to ecu T121/62 Y (Y pin 4, needs fuse)
    pin 5 - blue/yellow fused 10 amp from fuel pump relay Y (g1 pin 10)
    T14a - 14 pin connector near battery
    pin 4 -purple coolant temp sensor (214) Y/M (G2 pin 3, requires resistor to read correctly)
    pin 5 - red/purple 10 amp fused switched live to injectors (183) Y ( Z1)
    pin 6 - yellow/black fused 10 amp from fuel pump relay (fuse shared with T6/6) Y (g2 pin 4)
    pin 7 - brown earth (204) (197) Y Earth to chassis or battery -VE (Edit by mat-mk3)
    pin 9 - brown/white earth for senders Y (G1 pin 6)
    T10W -White connector
    pin 4 - white/red ecu T121/39 to clutch pedal switch Y (Clutch pedal switch in car)
    10 Orange
    pin 1 - grey/white to ecu T121/43 (229) Y ( diagnostics K diag port)
    pin 2 - green/red to ecu T121/81 Y (Tach signal from ecu via tach adaptor to G1 pin 12)
    pin 6 - blue/white ecu T121/54 to speed signal in dash wiring Y (Hall speed sensor on clocks W pin 1)
    T10h Blue
    pin 1 - brown/white to brown/blue ecu T121/34 to throttle sender T6b/6 Y (Throttle pedal in car)
    pin 2 - green/white to green white ecu T121/72 to throttle sender T6b/1 Y (Throttle pedal in car)
    pin 3 - yellow/green to yellow/green ecu T121/73 to throttle sender T6b/2 Y (Throttle pedal in car)
    pin 4 - grey/red to grey/red ecu T121/36 to throttle sender T6b/3 Y (Throttle pedal in car)
    pin 5 - white/blue to white/blue ecu T121/35 to throttle sender T6b/4 Y (Throttle pedal in car)
    pin 6 - grey/blue to grey/blue ecu T121/33 to throttle sender T6b/5 Y (Throttle pedal in car)
  10. 07-05-2012 05:45 PM #10
    DLC is your data link connector so you can read your codes in the bently it is connected to a 7.5 fuse and links up to your radio so i picked Q/03 it is the fuse to my corrados radio as for T14
    i have it on paper ill post it
  11. 07-05-2012 09:40 PM #11
    Quote Originally Posted by dik-van-dub View Post
    T6-brown connector
    10 Orange
    T10h Blue
    where did you find this one from can you link the swap and for T14a pin 4 what kind or size resistor did you use
    Sep 11th, 2009
    MN
    07-05-2012 11:42 PM #12
    T6-brown connector
    10 Orange
    T10h Blue
    holy tats- thanks.
    When it says 'needs fuse' I am assuming you add a fuse? Sorry, I'm new to wiring and am still figuring all this out for my swap. It's the part I am stuck with
    What is all the 'Y' deals about?
    Also I am confused with the T14a, since that sits in the bay- are you guys just pulling it through the firewall or cutting and extending?
    Ok cool, that gives me a good idea. Have been trying to figure out what to do with daignostics port.
  13. 07-06-2012 12:59 AM #13
    T14a i ran mine through the fire wall
  14. Member
    Sep 11th, 2009
    MN
    07-06-2012 12:39 PM #14
    did you chop the connector off or what? pictures would be rad
  15. 07-06-2012 11:50 PM #15
    kept the plug cut as far back as you can
  16. Member
    Sep 11th, 2009
    MN
    07-07-2012 12:21 AM #16
    ok, just like I did then. I was planning on doing the same thing. I was always assuming when people said T14a that they were talking about one half of the T14a/b connector, so I just confused myself
    we should keep this going for a sticky eventually. I'd like to be able to get it all down pat before I splice my harness later this week
    and please more pictures of the harness through firewall.
  17. 07-07-2012 03:43 AM #17
    ill post the pics just trying to get it done in the right direction
  18. 07-07-2012 12:45 PM #18
    the y and n are for yes needed, n for not needed
    i keep the t14 plug in place it helps for when you want to remove your motor
  19. Member
    Sep 11th, 2009
    MN
    07-07-2012 02:49 PM #19
    And just spliced the other end of the t14 to the ce2
    Connectors?
    Also- my g60 doesn't have any sort of line to communicate to ISO 9141, so how should the dlc be ran?
    What about the black connector and the purple one?
  20. 07-07-2012 03:20 PM #20
    black is for the cruise control, and which purple connector are you reffering to
    any how link to thread is here
    the holy grail of wiring me7 ecu's
  21. Member
    Sep 11th, 2009
    MN
    07-07-2012 03:25 PM #21
    I'll take a pic. Assuming my purple is because my donor mk4 was an auto.
    edit: memory is telling me it is gray, not purple. my apologise.
  22. 07-07-2012 06:39 PM #22
    T6-brown connector
    10 Orange
    T10h Blue
    hey your brown connector T6 pin 4 says it goes to pin 4 of what ? yours says to Y\04 i put mine to F\05 its a ecu power and goes to a fuse box in the a2 side http://a2resource.com/electrical/CE2.html
  23. 07-07-2012 07:13 PM #23
    it actually is live from Y4
    why get power from other parts of loom when you can use the standard ce2 engine plugs makes removal a lot easier if need be
  24. Member
    Sep 11th, 2009
    MN
    07-08-2012 01:14 AM #24
    It was gray.
  25. 07-08-2012 07:39 AM #25
    i would say thats for the auto loom, but couldnt say for certain
  26. Member
    Sep 11th, 2009
    MN
    07-08-2012 02:09 PM #26
    figured it all out
  27. 07-09-2012 08:47 PM #27
  28. Member
    Sep 11th, 2009
    MN
    07-09-2012 11:08 PM #28
    I have stripped my harness and followed the rabbit hole.
    before-
    after-
  29. 07-10-2012 05:08 AM #29
    yup i cut mine pretty thin too
  30. Member
    Sep 11th, 2009
    MN
    07-10-2012 12:52 PM #30
    you should put up a build thread or post more pictures to give me inspiration to finish
    did you primlarily use F, G1, G2, Y and Z1 for the swap?
  31. 08-19-2012 03:37 AM #31
    Here's my contribution. I compiled this after looking at a whole bunch of swap threads, bently research, and trial & error. I just got everything to work today. A/C tommorrow and other small stuff.
    updated table
    great link
    http://www.clubgti.com/showthread.ph...ss-install-FAQ
  32. Member
    Sep 11th, 2009
    MN
    08-27-2012 04:07 PM #32
    awesome, lets keep this alive
  33. 09-04-2012 03:52 AM #33
    I updated my table a little.
    Everything works but the reverse lights, CEL, and VSS signal to ECU.
    The CEL doesnt light up even at start up. IDK why.
    I didnt hook up the reverse switch to the trans yet.
    The big issue is the ECU isnt getting a VSS signal though my speedo is working. Does the AWP ecu even need a vss signal? Is there anyway to get the signal to the ecu besides running a mk4 cluster?
  34. Member
    Sep 11th, 2009
    MN
    09-04-2012 05:00 PM #34
    Quote Originally Posted by qksilva View Post
    if you're not using the original trans that the harness is for, you'll need a tach adapter to convert the signal from analog to digital
  35. 09-05-2012 02:03 AM #35
    So, I need to get a signal converter for the vss? Im using a mk3 vss which i think outputs a digital signal
