Results 1 to 3 of 3
Thread: Mk I Polo G50
  1. Semi-n00b Sebavw's Avatar
    Oct 21st, 2008
    Poland
    95` Corrado 8V
    06-29-2012 12:18 PM #1
    Hi everyone, i`m new in Polo Forum, and i want to present my buddy`s car, he don`t have time because of work, so i have permission to present small project.
    As topic says:
    MK I VW Polo from 79 year
    Engine:
    1,3 l PY
    G60 compressor
    bigger injectors,
    G60 fuel pressure regulator
    custom water cooler
    K&N air filter
    MB intercooler
    tooth belt drive for G60
    bigger fuel pump
    all seals, o rings etc brand new
    custom stainless exhaust
    and a lot more tricks for more power
    Gearbox:
    std G40 gearbox with new joints
    Outside:
    original look
    refurbished body
    New black paint
    lots of chrome parts
    Motorsport rear lights
    modified front
    mk I gti front spoiler
    Chasis:
    14" RSL Motorsport wheels,
    G40 brakes (refurbished), new ATE powerdiscs on front, and new ATE drums on rear, new custom cables,
    new brake lines, etc.
    GT Cupline kit -60mm
    front and rear strut bars and others in weak points.
    Inside:
    new leather / alcantara seats
    Wiechers rollbar
    G40 gauges + pressure, temp, amp VDO gauges
    Schroth seat belts ( to mount)
    So, time for some pics:
    On the start car was green
    than we do some work for more place for new engine:
    New heart:
    And more cuts:
    fat G60 don`t want fit easy:
    lots of cutting in front...
    And after maintenance, more strut bars between stringers and final painting :
    MB intercooler, a bit angular, but does the job:
    Brakes:
    from this perspective, most often you will see polo
    And after first test drive:
    That was on 1 stage, boost around 1,2bar, std ecu.
    At this time is going stage 2, with ported head, custom intake, external oil cooler, smaller G wheel, new camshaft, new Sachs race clutch, another engine block ( better condition), new piston rings, so polo do some kilometers without boost. In next month will be new ecu, boost around 1,5 bar, and estimated power 200+ hp.
    So here we go again with new stuff:
    Old parts:
    More power- toth belt drive:
    Sachs race clutch- to 300Nm:
    Bigger oil cooler with mocal thermostat:
    And it looks like this, here still without intake manifold:
    Front:
    And this is actual photo of little killer:
    All work is performed independently.
    More info with time, car is still in progress.
    Greets from Poland
    May 20th, 2009
    Wolverhampton
    1990 VW Golf 1.3
    07-01-2012 02:15 PM #2
    Brilliant little Polo! Is the G60 charger holding up? I heard they are a weak point on the G40 engine because the little 1,3 revs faster?
    Mk2 Golf 1.3 POV
    Vortex DNB/Jungle
  3. Semi-n00b Sebavw's Avatar
    Oct 21st, 2008
    Poland
    95` Corrado 8V
    07-01-2012 04:08 PM #3
    Quote Originally Posted by Doogal View Post
    Yes, it`s G60 charger, should be good, we have actually smaller G charger wheel so wil be revs much faster than original but still should be safe. Car doesn`t do thousand of kilometers, it`s only for weekend fun. Charger is after maitenance and modifications, so it`s life is much much shorter, but we`ve got another charger in mint condition, so we will see how it will be run, if something goes bad, we take another.
