VWVortex.com - Rear license plate holder
    Results 1 to 10 of 10
    Thread: Rear license plate holder
    1. 06-29-2012 03:27 PM #1
      How does the rear license plate holder plastic piece attach to the hatch? I notice that at the top of mine it seems to be falling back. Does it snap into place or do the license plate screws help to hold it in?
    2. Member cata's Avatar
      May 19th, 2006
      Canada eh
      06-29-2012 04:16 PM #2
      It's deff not via the license plate screws. That's what you do if you want to get it to connect the ghetto way The rest of the answer I do not haz.
      May 31st, 2001
      Tacoma, WA
      04 DBP R32, Corrado SLC
      06-29-2012 05:04 PM #3
      It's held on with part number: 171853939. There are 4 back there. They are small rubber/metal clamping grommets.
    4. 06-29-2012 05:21 PM #4
      Quote Originally Posted by ZEBLOR View Post
      Thanks for the help. Is the plinth just pulled on/off for removal or is there a trick to removal? I wonder if they are still available...
      May 31st, 2001
      Tacoma, WA
      06-29-2012 07:22 PM #5
      Quote Originally Posted by a_riot View Post
      Just pull them off with some pliers. These are available. This is what I use in the Euro tub kit I sell. I have them in stock. Here an ETKA screen shot!
    6. 06-29-2012 07:41 PM #6
      Thanks. I still don't understand how to get the plastic holder off the hatch though. Is it just pulled off? I don't want to break this expensive piece of unobtainium
      Dec 6th, 2011
      Lincoln Park, NJ
      1992 Corrado SLC; 1980 Triumph TR7 710 original miles
      06-30-2012 01:24 AM #7
      Once you get the 4 tabs/grommets off from inside the hatch lid, you can pull it out so the tab surface is beyond the lid. Then slide it down. There is a lip on the bottom of the plastic frame. If you pull it straight off, you'll likely break off the tab/gutter. Mine had double sided tape on it. So took abit of effort to get it off. Not sure if they came that way from the factory.
    8. Member vdubCorrado's Avatar
      Nov 8th, 2001
      Baltimore MD
      15 Ram 1500 - 91 Corrado - 97 Cobra
      06-30-2012 01:27 AM #8
      all OEM plate tubs had 2 sided tape on the bottom lip where it wraps the hatch so that's normal...
    9. Member dogger's Avatar
      Jul 29th, 2005
      Pasadena, CA
      1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro S-Line
      06-30-2012 04:28 AM #9
      Chances are the plastic tabs on the backside are broken. They almost all break. It was yet another brilliant and cheap design by VW. There is one that is behind the wing motor and its not easy to reach.
    10. 06-30-2012 01:01 PM #10
      Quote Originally Posted by dogger View Post
      Yes you are probably right *sigh*...
