When you push the AC button in do you feel the compressor kick on? The light will stay light up either way, so you can't tell based on the light.
#1
So my AC Compressor has been making a squealing noise for the past 6 months, but I have never had an issue with my AC not working. Today, in the 100 degree weather my AC was not cold. I turned it on and it didn't blow cold. I am guessing that my AC Compressor decided that today was the day to die.
The only thing that has been done lately was a cam install and a battery relocation, so I don't think that has anything to do with it.
I am pretty sure it was the fans because my car did not overheat at all and I am pretty sure I heard them running.
I am guessing that its just a case of my AC Compressor dying?
Does this sound right? How can I test this?
SLAW [Straightline Autowerks]
PM for fender rolling and coilover installs in South Jersey
#2
#3
Turn your AC on with the car running. You should hear a very audible CLICK when the compressor clutch engages. If you don't, there is a good chance that the compressor died.
#4
#5
The OP already said he knew his compressor was squealing for the past 6 months. Obviously the bearing went out.. *smh*
#6
I figured this out weeks ago, replaced ac compressor and all is well.
Sent from my SGH-T989 using Tapatalk 2
