I've been thinking about selling or trading my '93 Supercharged Corrado SLC. I have too many cars and need to downsize the fleet. I only drive this one a few times a year. I bought it in 2004 and had it shipped East from Oregon. I have the full service history since 2000 (73,500 miles).
I would entertain a trade plus cash (depending on the modifications/condition of the car) for the following:
MK1 GTI
MK1 4-Door Rabbit
MK1 Cabby - '89 Wolfsburg Edition
MK1 or MK2 Scirocco
MK2 - '89 Golf GL Wolfsburg Edition
MK3 Cabrio w/ VR6 Swap
BMW E36 M3 Sedan
Specs:
ENGINE & DRIVETRAIN:
OBD1 2.8 VR6 (Coilpack)
Z-Engineering ZR2 Cogged Belt Supercharger (8 psi)
Techtonics 2.5” Stainless Cat Back Exhaust System W/ Borla Muffler
Autotech Shock Therapy Ignition Wires
Optima Red Top Battery
Peloquin LSD
Dieselgeek Short Shifter
Samco Silicone Coolant Hoses with New Clamps
SUSPENSION:
Koni Coilovers
Neuspeed Front Strut Bar
Eurosport Rear Strut Bar
WHEELS/TIRES:
Oettinger RE 17x8 Wheels - Refinished by Perfect Metal Finishing
Continental DW Tires 215/40-17 (Less than 1500 miles)
BRAKES:
12.3" (312mm) Audi TT Front Brake Conversion
TyrolSport Brake Caliper Stiffening Kit
Zimmerman Cross Drilled Front & Rears Rotors
Mintex Red Brake Pads @ All 4 Corners
ECS Tuning Stainless Steel Brake Lines
EXTERIOR:
European Headlamps
Hella Tempered Foglights
FK Badgeless Grill
European (90mm) Front Lip Spoiler
Sharan Antenna
Bonrath Mono-Wiper 2nd Generation
European Wired Rear Fog light/Switch
Smoked Front Bumper Markers
Hella Air Horns
All Red Taillights
Passat Glass Moonroof Conversion
INTERIOR:
BBM 2 Gauge Pod
Autometer Boost Gauge
Innovate Motorsports Wideband O2
MOMO Competition Steering Wheel & Hub
Rieger Illuminated Shift Knob
Alpine IDA-X305S Head Unit
Kenwood 4-Channel Amplifier
4 Eclipse Speakers in Front Factory Locations
Polk Audio 6x9 Speakers Installed In Rear Deck
Custom Fitted Subwoofer Enclosure with 10” MB Quart Sub
Passat Beverage Holder
Passat Middle Visor Above Rear View Mirror
MKIII Dome Switch/Sunroof Switch
MKIII Illuminated Central Locking Switch
MAINTENANCE:
I have the Full Maintenance History since 2000/73,500 miles.
Current Mileage: 115K
Rebuilt Head, Timing chains, new Sachs Clutch, brake lines, Peloquin LSD and Samco hose install in 2007 at 106K miles, performed by TyrolSport.
New Water Pump, thermostat, fan switch, rear rotors and pads, new tires in 2011 at 113K miles.
Mechanically the car has no issues, its been looked after. The car has the original paint and has a few blemishes on the front and rear bumpers, hood, and right rear fender but nothing out of the ordinary for a car this age.
Known issues:
Wideband O2 works intermittently, just a loose connection.
Valve Cover needs to be repolished.
Sunroof seal needs to be replaced.
Hella air horns need to be reinstalled.
fresh paint / fresh leather interior / brand new totally refinished baller of baller BBS's / 60K on the passat VR with a brand new clutch / Koni's w/ Adjustable Camber just dialed in at Eurotire in fairfield at Neg 1 Deg all around... throwing no codes and starts every time. anytime you want ... and ill even guarentee a trade back cause i know how it goes...
