Results 1 to 23 of 23
Thread: 20v head on.aeg 8v block
  1. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    06-30-2012 12:50 PM #1
    Will 1.8t chips work for my head swap
    VolkSwagON
  2. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
    06-30-2012 01:09 PM #2
    ...This is a much, much harder swap than you'd think. If you have an AEG, just boost it with a C2 or kinetics kit.
    If you want to make your 2.0 8v faster, read the thread below!
    http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
  3. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    06-30-2012 10:03 PM #3
    Just wanna know what tuned ecu will work
    VolkSwagON
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    07-01-2012 12:17 PM #4
    Depends whether you are boosted or NA.
    FS:Sunroof Deflector
  5. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
    07-02-2012 05:11 AM #5
    i ran a BT 1.8t tune on my 8vT just fine. You dont need to swap heads to run the tune. just swap in the harness and rewire the coil pack drivers. Takes about an hour.
  6. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    07-12-2012 06:26 AM #6
    u have a thread of your build? or pictures
    VolkSwagON
  7. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    07-12-2012 01:23 PM #7
  8. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    07-26-2012 09:29 AM #8
    so your saying u ran a 1.8t Chipped ecu on a 2.0 8v..just by splicing some wires on the harness
    VolkSwagON
  9. Member 02vwgolf's Avatar
    Oct 6th, 2009
    SE-PA
    02 vw golf gls
    07-26-2012 11:05 AM #9
    Yeah i have talked to him about this process... get yourself a 1.8t ecu and engine side harness, then grab a haines manual and rewire it to power the single coilpack that a 2.0 has instead of the 4 that the 1.8t has. Also need to incoporate a MAP sensor, but then you can run any 1.8t tune on your 2.0t
    Sent from my VS840 4G using Tapatalk 2
  10. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    07-26-2012 02:29 PM #10
    Quote Originally Posted by mikeyaka23 View Post
    yup.. cam position plug and the 4 coil drivers.
    1.8t has 4 ind. coil packs
    2001+ 2.0 has 4 ind. coils in ONE PACK. so works the same way
  11. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    08-09-2012 06:37 PM #11
    so your saying u can run a 1.8t chip like lets say a Unitronic stage 2 chip on ur 2.0 8v a chip that basically gives u 50 hp
    VolkSwagON
  12. Member chasem407's Avatar
    Feb 18th, 2008
    Orlando, Florida
    2.1 20v BT
    08-09-2012 07:51 PM #12
    .... you're missing it.... too much to explain at this point, but no, you're looking at it wrong.
  13. Member elRey's Avatar
    May 15th, 2001
    16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
    08-09-2012 07:53 PM #13
    a chip that gives you 50hp on a turbo engine. A stock 1.8T ecu on a stock 2.0L car does not a 180hp make.
    Nor does a 1.8T chip give a 2.0L NA 50 more hp.... if that's what you were getting at.
  14. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    08-09-2012 08:02 PM #14
    idk whats better a whole 1.8t swap......head swap......or turbo the 2.0 8v
    VolkSwagON
  15. Member 02vwgolf's Avatar
    Oct 6th, 2009
    SE-PA
    02 vw golf gls
    08-09-2012 08:32 PM #15
    Not to sound rude but it sounds like just doing a 1.8t swap will be the easiest and give you what your looking for
  16. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    08-09-2012 08:37 PM #16
    my friend sellin a motor cheap to me with harness and ecu. all i really need for my mk4 jetta is Keys ignition lock and harness engine ecu cluster
    VolkSwagON
  17. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    08-10-2012 02:10 AM #17
    not if you're doing the IMMO defeat...
  18. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    08-10-2012 02:12 AM #18
    also i just read the rest of this thread....you completely got confused.
    I'm saying run a 1.8t ecu to run a 8vT setup. You're saying run a 1.8t ecu to make turbo power
  19. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    08-22-2012 01:01 PM #19
    i have a t3/t4 turbo a 1.8t smic and other parts to my build maybe make a short runner who knows...soo about the ecu situation.. explain it step by step please
    VolkSwagON
  20. Member 02vwgolf's Avatar
    Oct 6th, 2009
    SE-PA
    02 vw golf gls
    08-22-2012 03:25 PM #20
    Unless you are trying to make huge power, and want to swap harness's and ecu's... i would just run a 2.0 turbo tune. You will be able to make just below 300hp on one of these tunes with a set of 440cc injectors. I'll pm you more info if you need it
  21. Member chasem407's Avatar
    Feb 18th, 2008
    Orlando, Florida
    2.1 20v BT
    08-22-2012 05:27 PM #21
    lol
  22. Member VwBoy2.0L's Avatar
    Sep 30th, 2008
    Colorado Springs
    2002 Volkswagen Golf 4 dr 2.0L
    10-09-2012 01:18 AM #22
    Quote Originally Posted by Quintin@USRT View Post
    Nice save me a lot of money. Basically a 2.0L 8V is a 1.8T without a turbo and 20V head right. The question is will it be able to keep up with a 1.8T? If I were to get something like a unitronic BT 600cc flash will it still be able to withstand all that power? Or will u just have to swap the whole thing into a 1.8T.
  23. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    10-09-2012 03:00 AM #23
    Quote Originally Posted by VwBoy2.0L View Post
    on a 1.8t you need rods for over 300wtq...
    on a 2.0_8v you need rods AND pistons...
    (1.8t and 2.0 rods for AZG/AVH/BEV/AWW/AWP are the the same 19mm wrist pins w/tapered small end)
    (1.8t and 2.0 rods for AEB/AEG are the same 20mm wrist pins)
