VWVortex.com - Cabby project
    Page 2 of 3 FirstFirst 123 LastLast
    Results 26 to 50 of 64
    Thread: Cabby project
    1. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      79' diesel bunny 87' cabby
      07-30-2012 10:07 AM #26
      Monday ! Today my carpeting is supposed to be coming in also I bought a bushing for my gas pedal from 4crawler because PO neglected to lmk the cable was being held on by a ball of duct tape .
      I got it here and am very pleased with it:
      http://www.4crawler.com/Diesel/ForSa...lBushing.shtml
    2. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      07-30-2012 10:15 AM #27
      What's the easiest way to fit early rabbit back seats in a cabby? Or is it a direct fit?
    3. Member benrk's Avatar
      Feb 19th, 2012
      Winnipeg, MB, CDN
      '82 BMW 633CSi, '85 VW Cabrio, '94 Volvo 850, '04 Mazda 6
      07-30-2012 10:49 AM #28
      Our bumpers are painted, being an '85 I understand they should've been painted from factory, the way the paint chips & only being one coat matching the repainted body I beleive they originaly were unpainted though (on another car?) I tried some paint stripper on one spot earlier this summer & the paint came off really easy & it has been sitting outside since, still shiny.
    4. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      07-30-2012 11:50 AM #29
      Awesome, I can't wait to get mine stripped and polished.
      Sent from my HTC HD2 using Tapatalk 2
    5. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-01-2012 11:59 AM #30
      Okay guys another question when I get to painting the car, is it recommended to remove the top? Is it hard to do? Or just mask it off. Btw ill be going with a new color.
    6. Member ih8erickempf's Avatar
      Apr 23rd, 2004
      New Jersey
      06 A4 avant ,80 Rabbit p/u
      08-01-2012 02:59 PM #31
      that all really depends on you... if you are going to a completely different color i would advise removing the top... but then the real question is are you painting the door jams? removing the fenders and doors? cause if you arent and just doing a cheap respray then i would say mask it off and call it a day
    7. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-01-2012 04:27 PM #32
      Quote Originally Posted by ih8erickempf View Post
      Yes I'm removing fenders & doing the door jambs. How would I go about taking the top off?
    8. Member ih8erickempf's Avatar
      Apr 23rd, 2004
      New Jersey
      08-01-2012 05:35 PM #33
      memory serves me there is a tensioner cable that holds it on... loosen the bolts in the rear and it should come right off... being vague only because its been at least 4 years since ive done it... i just remember it being fairly easy
    9. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-02-2012 04:10 AM #34
      Awesome I'll take a look at it tomorrow morning, thanks!
    10. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-02-2012 04:13 AM #35
      I picked up some porsche script handles, and I wanted to polish them does anyone know if aircraft stripper works on them? I left it on for an hour and no results. None what so ever.
    11. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      08-02-2012 07:55 AM #36
      Your memory is pretty good, but...
      You have to take the 2 corners caps off, 2 Philips screws each side. The snap is on the back.
      Opening the top half way, and looking straight down. on the back side of the rear window seal you will see the cable.
      You will need a 10mm articulating ratchet, and a pair of needle nose, or 7-6mm open end wrench.
      If you safety your top. you can remove the strut pivot for easier access.
      NOW BE WARNED
      If you have a old top, then removing the cable and top from the cable tray you have to be really really careful, as the older tops are brittle, and can break, rip, shred, tear, and generally destroy itself. GINGERLY is the operative word, Don't yank or Pull hard, coax it out carefully.
      After you have it out, then you can Push it to the inside of the car body. Use plenty of Lube on the inner tray and top when going back, and don't over tighten the cable, as Snap crackle and pop comes to mind.
      Grounds, Grounds, Grounds Replace them things.
      Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
      Another Useless Ground Thread
      HAVE YOU CHECKED THE FAQ's ABOVE..PAGE 3 Thread 75? Why bother no one else does.
      You can lead a user to a link, but you can't make them click.
    12. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-02-2012 01:32 PM #37
      Awesome that's a great write up . Thanks man
    13. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-02-2012 03:14 PM #38
      I think the handles are powder coated the paint just doesn't come off guess I got to sand.
    14. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-03-2012 02:29 AM #39
      They sanded off like butter
    15. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-03-2012 05:28 AM #40
      Took off the rear bumper and am stripping all the paint off, and I hope to start polishing tomorrow.
    16. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-03-2012 03:07 PM #41
      Finished stripping and sanding the bumper time to polish, :-)
    17. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-04-2012 03:39 AM #42
      Took off the front one tonight will strip tomorrow
    18. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      08-05-2012 08:08 PM #43
      Finished both bumpers will post a pic tonight
    19. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      10-01-2012 04:22 PM #44
      Long time no update, but recently I did the water pump timing belt, and today i'm going to shave the side markers
      post pics later
    20. Member shanybu's Avatar
      Feb 25th, 2010
      Flagstaff, AZ
      1984 VW Rabbit convertible; 2013 VW Jetta Sportwagen TDI
      10-02-2012 07:14 PM #45
      Hey, did I see your car last Tuesday on the 215 freeway at about 11:15pm?
      Silly Rabbit, cabbys are for chicks...
    21. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      10-02-2012 11:30 PM #46
      Shaved
    22. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      10-02-2012 11:32 PM #47
      Okay now should I bondo it out smooth then primer, or use the filler primer then sand?
    23. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      10-08-2012 10:32 PM #48
      Went to paint today
    24. Member alexandersin's Avatar
      Oct 23rd, 2010
      Covina, California
      10-10-2012 03:11 PM #49
      Quote Originally Posted by shanybu View Post
      Mmmmm I don't think so. I have a doppelgänger? :p
    25. Member LAVDUBDUDE's Avatar
      Jan 27th, 2009
      Los Angeles
      02 Golf, 79 westy rabbit
      10-18-2012 04:51 AM #50
      Hey I want my snowflakes back! Finally found your thread. Post some pics of the new color, it looks bad ass.
