Results 1 to 11 of 11
Thread: Gas tank help!
  1. Member delanodub's Avatar
    Oct 29th, 2009
    Delano,Minnesnowta
    1982 VWRabbit
    07-02-2012 02:15 AM #1
    The gas tank on my 83 rabbit is leaking. From the very bottom. Its like someone poked 3 pin size holes it in. I tried draining it and using a gas tank patch kit but it failed. Its on the very bottom so some leaked out and ****ed it up. Next I'm gonna try some jb weld. Anyone have another tips? putting a new one in looks like hell.
  2. Member Jesse-B's Avatar
    Dec 4th, 2011
    Fort Myers, FL
    1984 Vw Rabbit, 2004 Passat W8 wagon.
    07-02-2012 06:03 AM #2
    Replace the tank.
    Nov 30th, 2011
    Northern NJ
    84 Rabbit Convertible, 1990 Volvo 740 Turbo
    07-02-2012 08:30 AM #3
    Yeah, replace it. JB weld will work for a little, but gas is harsh on it, and will cause it to get soft and just flake off. I've seen it happen, and within a week, maybe a week and a half if your lucky, you'll be in the same boat.
  4. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    07-02-2012 10:29 AM #4
    You can try JB Water weld. We've had that on our diesel tank for probably 2 years now with no issues.
    Quote Originally Posted by TM87 View Post
    VW-making mechanics out of owners since 1957.
    The project - '84 Jetta 1.6TD, 186k+, fully rebuilt, Giles IP and injectors, 2.5" custom exhaust, 51mpg
    Hers - '03 BMP 20thAE GTI, 125k, all stock...for now
    His - '01 Jetta TDI, 126k. Now has 3 pedals, as it should!
  5. 07-02-2012 11:24 AM #5
    Quote Originally Posted by Jesse-B View Post
    Replace the tank.
    Agreed.
    Another reason to replace the tank is because of the inevitable disintegration of the plastic baffling box inside the tank. This leads to the right- hand- turn- starvation syndrome, when the fuel pump intake runs dry on a turn with a low fuel level tank.
    Spectra 4B is the common replacement tank. It has baffling, too. There is more information in the forum FAQ/DIY sticky thread.
  6. Junior Member RabidRabbot's Avatar
    Dec 7th, 2004
    Minneapolis, MN
    1981 Rabbit 1.6Diesel
    07-02-2012 05:52 PM #6
    I just replaced the tank in my 1.6D. (same tank as gas). i got the tank off ebay and it had free shipping. $80 total. i am very happy with the new tank and am now modifying the old tank for wvo use. por15 makes a tank repair kit but you have to take the tank out anyway to use it. (plus i think it wont work with that plastic thing on the inside.) Anyway, get two good jacks on the back end, drop the axel, take the brake lines off.... sigh... yea- i never wanna do it again but i am very happy that i did. its hot as hell here in MN right now man, have on hand.
  7. Member steady dubbin''s Avatar
    Nov 8th, 2010
    the porn shop
    swallowtail
    07-03-2012 05:28 PM #7
    replace it for sure
  8. Member SGLoki's Avatar
    Dec 12th, 2004
    The Ham
    88 fox RIP 86 jetta RIP 81 rabbit RIP, 1984 GTI RIP, 03Ranger RIP, (03 Legacy, 03 Allroad, 86 Jetta)
    07-03-2012 06:18 PM #8
    Replace it... Patches are temporary junk.
    the only other solution is to find a place that will rinse it, fume it off, and braze it.. For the hassle and cost it'd be best to replace that internal rust prone 30 year old piece of crap for a bit more. $80 is cheap!
    1% defined: Lone wolf, no club. Duct tape it yourself. It is broken down 1% of the time, and work is always 1% completed.
    2% defined: I'm too old to drive broken sh*t and VW people are cool. DBVW!
    Quote Originally Posted by nsindel View Post
    May I introduce Senor SGLoki -
    the man, the myth, the slamdancer...
  9. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    07-03-2012 10:41 PM #9
    the biggest hassle is disconnecting the rear axle and brake lines
    but nothing that will destroy your car obviously....
  10. Member delanodub's Avatar
    Oct 29th, 2009
    Delano,Minnesnowta
    1982 VWRabbit
    07-04-2012 06:10 PM #10
    Thanks for the help guys! Ill give the jb weld a try for the mean time. Then ill just order a new tank off of ebay!
    pics 4 click
  11. Member avidgolfer's Avatar
    Sep 8th, 2008
    Florida
    '83 Caddy 2.0 16v, '12 Sportwagen TDI 6MT
    07-05-2012 12:48 AM #11
    Quote Originally Posted by SGLoki View Post
    ^This, anything else is just dangerous.
