Page 1 of 6 1 2 3 4 5 ... LastLast
Results 1 to 35 of 177
Thread: so it starts: PPT 3071 "build"
    Jan 30th, 2012
    WA
    '05 GTI
    07-02-2012 11:29 AM #1
    so, after a long awaited big turbo dream of mine, I finally got started.
    did MAD research, got a little bit of money, and called Arnold at Pag Parts. very good decision.
    the wait from order to delivery turned out to a couple weeks, which worked out well because it gave me time to gather my parts.
    somebody asked me for a list of things I need for this build. This might help others:
    I can try, haha. had to buy a lot of things along the way.
    ppt v banded 3071 kit:
    Gt3071r turbo
    38mm tial mvs w/ open dump
    ppt exhaust manifold
    ppt custom intercooler w/ garret 550 hp core
    tial Q bov
    3" downpipe
    Seimens 630cc injectors
    Walbro 255 inline fuel pump
    AEM dry flow filter
    ppt 3" turbo inlet pipe
    Audi tt intake manifold
    Ic Piping by Arnold at pagparts
    2.5" 42dd cat back
    IE rods: rifle drilled, arp rod bolts
    oem main bearings
    oem piston rings
    oem head bolts
    timing belt/tensioner
    water pump w metal impeller
    new head gasket, valve cover gasket, intake/exhaust manifold gasket
    Sachs vr6 clutch kit w/single mass g60 flywheel
    Maestro 7 tuning suite
    fluids, tools, clamps, hoses, etc. etc.
    and so I started shopping:
    ariving first was gasket set ( head, valve cover, intake, coil pack), piston rings, and head bolts.
    next up was timing kit, water pump w/ metal impeller and some g12.
    then came IE rods w/ rifle drilling and oem bearings.
    My collection started building and my turbo kit was a week out from shipping, so yesterday I started work:
    with the core support removed, I started unplugging/labeling the harness, and disconnecting anything holding the motor into the frame.
    downpipe was a bitch to unbolt, haha
    gettin ready to come out.
    "SHE'S AIRBORNE!"
    some love for the 1.8t. first motor I've pulled, so I was pretty excited.
    then, I started stripping/prepping it for things to come
    Motor has not even 74k on it. Valve cover off, cams look great, timing chain looks great:
    currently sourcing a poly drive head bolt tool, so progress has come to a halt. problem should be solved in the next couple days.
    Clutch comes today, And fingers crossed my kit ships today, if not, it definitely will tomorrow.
    Edit:
    thank you, brush research:
    thanks for viewing! comments welcome.
    Jan 30th, 2012
    WA
    '05 GTI
    07-02-2012 11:29 AM #2
    So, i made a shi-ton of phone calls, finally got pointed in the right direction to a little place called "tool town," that had my polydrive tool. FOR $12! i felt like i stole something because i saw it going for $35 around the internet.
    with this awesome find, i was able to press on and remove all ten head bolts in the proper sequence.
    TDC:
    head removed:
    lots of carbon buildup. not sure what to attribute that to, but i'm not going to worry too much about it, clean it up, and press on.
    flipped the motor over, and began removing all four pistons.
    pistons out: gotta clean up all the oil from the cylinder walls, of course.
    crank is in great shape, and oil pan was spotless.
    when i get a second wind, i'll start separating oem rods from pistons, attach the IE ones, clean up carbon buildup from on top and between piston rings and install the new ones to spec.
    btw, clutch kit came in yesterday:
    -SACHS VR6 Clutch Disc
    -SACHS VR6 Pressure Plate
    -SACHS OEM Throw-Out Bearing
    -SACHS Single-Mass 14 pound "G60" Flywheel
    that's all for now, still waiting to hear from arnold about my kit shipping! ICAN'TWAIT!
    3071/rods/ppt.. and still just a gti.
    Jan 30th, 2012
    WA
    '05 GTI
    07-02-2012 11:30 AM #3
    happy belated 4th everyone. I want to thank all my fellow military members for serving, and all the vets for giving their lives, sacrifices, and service for our freedom.
    As a small update, I've cleaned up the ins-and-outs of my pistons, assembled the rods, and cleaned up the deck of my block.
    I chose not to use that 3m pad, as it was too abrasive. Ended up using a really fine 3m pad that is used for smoothing surfaces between coats of paint. something similar to the surface of a sponge.
    all cleaned up and assembled.
    block looks good, still need to show my head and valves some love.
    next up is deglazing the cylinder walls, piston ring gapping/install, and installing the pistons and bearings back into the motor. hopefully I'll have this accomplished in the next couple days.
    Edit:
    just finished (1&2)
    (3&4
    surprising myself every day at how fast I'm learning and how fast progress is being made. still trying to make sure I hit every mark and don't miss a step! BT is becoming a reality, hahaha.
    yesterday got all my piston rings gapped, clocked, and installed. rods/bearing went in smoothly, just need to torque things down to spec, and I can start buttoning things up. oil pan, head gasket/head goes on next.
    thanks for watching!
  4. Member
    Jan 30th, 2012
    WA
    '05 GTI
    07-02-2012 11:30 AM #4
    IT'S HEEEEEEEREEEEE!
    Christmas on my doorstep.
    always a good sign:
    I was too excited to take pictures so this is the aftermath, haha
    tial q bov
    external wastegate, also by tial
    PPT exhaust manifold, welds look awesome
    TIP, open dump from wastegate, table salt, everything v-banded
    walbro inline fuel pump, siemens 630cc injectors
    and finally! gt3071r
    can't wait to get all these goodies in.
    still waiting on maestro, and audi tt manifold. Maestro shipped separately from eurodyne, so that should be here this week. I'm going to expedite the shipping on my manifold so I can get this bad boy buttoned up and ready to boost!
  5. Member T-Boy's Avatar
    Jul 16th, 2003
    ATL
    07-02-2012 11:48 AM #5
    Cool build...good choice of company and hardware! You'll like the 3017r
    APR Stage 3071R+
  6. Member
    Jan 30th, 2012
    WA
    '05 GTI
    07-02-2012 02:18 PM #6
    I cannot wait! tryin' to do it right the first time, learned a lot from other builds.
  7. 07-02-2012 02:23 PM #7
    Awesome ! Will be watching
  8. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    07-02-2012 04:52 PM #8
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  9. 07-02-2012 04:53 PM #9
    Subscribed
    Quote Originally Posted by gdoggmoney View Post
    There's been too much butt sniffing before this dog fight.
    GONZO tuning PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
  10. 07-02-2012 04:56 PM #10
    nice build you got going.. good luck with it
  11. Member Three3Se7en's Avatar
    Jul 1st, 2007
    Mississippi
    02 337. 08 F150
    07-03-2012 01:35 PM #11
    Your shirt looks pretty clean.
    2.1L, 1000cc, Maestro, CompTurbo 5558, CTS, IE intake, Scat rods, more to come..
    Jan 30th, 2012
    WA
    '05 GTI
    07-03-2012 02:02 PM #12
    Quote Originally Posted by Three3Se7en View Post
    i can't count how many white v-necks i've trashed working on the car. luckily they come in 5 packs! hahaha
  13. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    07-03-2012 02:52 PM #13
  14. Member
    Jan 30th, 2012
    WA
    '05 GTI
    07-05-2012 08:55 PM #14
    bump for small update.
    sn: my left thumb hurts from putting those cir-clips back into the pistons. barely got the fourth one in, haha.
  15. Member sledge0001's Avatar
    Oct 7th, 2007
    Somewhere in the Nazi State (CA)
    2004 1.8 BT New Beetle Conv
    07-05-2012 10:07 PM #15
    Nice!!!!
    Quote Originally Posted by Arin@APR View Post
    I'm outta here... you guys are idiots. You can quote me on that and throw it in all of your sigs.
  16. Member
    Feb 21st, 2004
    Stanceville
    94 Jetta scrapin pinch welds
    07-06-2012 11:11 AM #16
    That is normal carbon buildup for a VW. The PCV systems are super dirty. That leads to coke on the piston crowns valves and etc.
    Looking good!
  17. Member
    Jul 24th, 2010
    Kirkland, WA
    B5 Passat Wagon
    07-06-2012 11:25 AM #17
    Good work man! Especially for your first time, I've pulled motors but never broke one down to the internals but it looks like fun
    Quote Originally Posted by scirockalot8v View Post
    delete your account and start over.
    Oh the Mark 4 forums.., how I will miss you.
  18. Member adgoff21's Avatar
    Sep 19th, 2004
    Dalton, GA
    20th AE #2360
    07-06-2012 01:43 PM #18
    Sent from my DROID2
    Pagpart 2871R
    South Bend Clutch Silent SMF - Level: Awesome
  19. Member
    Jan 30th, 2012
    WA
    '05 GTI
    07-07-2012 03:12 PM #19
    bump, significant update.
  20. Member formerly silveratljetta's Avatar
    Feb 6th, 2007
    2000 Jetta 1.8T Drag Car, 2001 Jetta 2.slow daily beater
    07-07-2012 03:36 PM #20
    dream build
  21. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    07-07-2012 09:23 PM #21
    Quote Originally Posted by jstnGTI View Post
  22. Member Three3Se7en's Avatar
    Jul 1st, 2007
    Mississippi
    02 337. 08 F150
    07-07-2012 10:56 PM #22
    I love the Tial Q BOV. No fluttering there. Nice parts too. VBand everything.
  23. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    07-08-2012 12:07 AM #23
    Sweet man, for the record, you can use a 8mm (i believe) allen key to REMOVE the poly drive bolts, but not reinstall them. For future reference for other people really, seeing as you have the tool now
  24. Member
    Jan 30th, 2012
    WA
    '05 GTI
    07-08-2012 04:47 AM #24
    ran outta reserve pages. thanks everyone for the positive feedback!
    so today, i did MAD work. I did all I could before the excitement made me tired enough to stop.
    was working really hard, so less pictures were taken.
    I put the arp rod cap bolts through two torque cycles before their final resting position. checked the sides with my feeler gauges for clearance and all went well.
    so I started buttoning things up.
    oil pump, baffle, and oil pan back on, fresh head gasket:
    got the water pump on, timing belt tensioner, and timing belt. this part was kind of stressful for me because sh!t kept moving when I tried to put the belt on the tensioner. luckily i got it first try and everything was at TDC, so I was able to press on.
    then I started to have fun
    v-bands made my life super easy
    and before calling it a night I got all the lines ran from the block to the turbo.
    just have a lot of questions about the external wastegate. never worked with these before so I'm not exactly sure what to do with all these springs it came with. which one do I run? do I have to take it apart and swap the one already in there? and I noticed ports for h2o and air (I think it said), what do I do with those? also do i put vaccuum to the top? wastegate noob over here... I know.
    I'm going to try to overnight my tt manifold, get that all situated. still got some odds and ends I need to pick up before I can completely finish putting everything together. I'd say I'm a week out from turning the key! YES! (:
  25. 07-08-2012 07:03 AM #25
    Your wastegate set up is going to be based on how your planning to be boost control.
    Are you using N75, EBC, MBC? if EBC which EBC?
  26. Member '04JettaGli's Avatar
    Jun 22nd, 2012
    Twentynine Palms, CA
    2004 MKIV GLI
    07-08-2012 07:39 AM #26
    Looks awesome man, looks like a blast too. You stationed in WA? Can't wait to see the rest fall into place!
  27. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    2002 1.8T JETTA & 2000 TTQ
    07-08-2012 10:47 AM #27
    Quote Originally Posted by 87vr6 View Post
  28. 07-08-2012 11:47 AM #28
    just have a lot of questions about the external wastegate. never worked with these before so I'm not exactly sure what to do with all these springs it came with. which one do I run? Most of the time they come with the 14.5 psi spring, but you may want to double ck with Arnold. If you want to run a higher one, go to the tial page and you'll find the code for the colors do I have to take it apart and swap the one already in there?only if you want to run a stiffer spring and I noticed ports for h2o and air (I think it said), what do I do with those? also do i put vaccuum to the top? wastegate noob over here... I know. It has two ports...top and bottom. If you run a manual boost controller u will use the bottom one. If you run an electronic boost controller u will use the top one.
    On a side note...I remember when doing my build.....good times !
    Pag Parts kit, PTE 5130, Brute rods, Eurodyne 630cc, Stg 2 water/meth, Pag Parts FMIC Kit with TT225 intake mani, Stage 3 Clutchnet n 17lb FW, 398whp @ 24psi
  29. Member
    Jan 30th, 2012
    WA
    '05 GTI
    07-08-2012 04:31 PM #29
    so, a simple reference to the instructions supplied with the wastegate informs me I just run a vacuum line from the IM -> mbc and then mbc-> WG. thought it was more complicated than that. I still haven't chosen an mbc to go with. suggestions?
    please tell me if I misenterprated the drawing.
  30. Member formerly silveratljetta's Avatar
    Feb 6th, 2007
    07-08-2012 05:12 PM #30
    I have a simple aluminum ball and spring MBC if u want it PM me
  31. 07-08-2012 05:45 PM #31
    Any ball n spring will do....blox, turbosmart, hallman etc. If you want to go fancier you can go dual stage mbc. It gives the option to run lo boost n with the touch of a button hi boost. And yes, mani to mbc to wastegate.
    Sent from te lo mande desde mi cel!
  32. Member
    Jan 30th, 2012
    WA
    '05 GTI
    07-09-2012 02:35 AM #32
    been working working working so all I have left is the parts I don't have. Trying to get back on the road and enjoy this bad boy.
    in no particular order:
    got my TIP mocked up and mounted.
    cleaned up my valve cover after that picture was taken.
    got a fram (lol) oil filter today and filled it with ND30, also poured about two quarts over the cams and chain before I torqued down my valve cover.
    should I put more? or prime my pump before start up and THEN add more? is two enough before I start priming?
    I started bolting on my accessories; PS pump, alternator, A/C, accessory belt.
    I chise to omit this brace of the oem IM because I'm going to be using a TT manifold.
    so instead of bottoming out the bolt, I chiseled this washer/spacer/whatever off and everything was good (:
    also started setting up my WG (thanks guys).
    plugged all side vacuum ports except the one I'm using and the one above the barb there and I'm venting to atmosphere on the top. Re-used some vacuum line heat shield material from the old turbo.
    called it a night.
  33. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    07-09-2012 06:39 AM #33
    doing werk man... everything is coming along great
    F23 Frankenturbo ll Bosch 550cc ll Eurodyne Maestro ll 034 Motorsports High Flow Exhaust Manifold ll Eurojet street FMIC ll Cooling Mist Dual Nozzle W/M ll 287whp, 290ft/lbs (18psi) ll stock bottom end ll
    http://www.frankenturbo.com/
    http://www.usrallyteam.com
  34. 07-09-2012 07:22 AM #34
    Coming along nicely...kudos to you! Did the same IC kit using the TT mani n it works nicely. Looking forward to dyno numbers in the near future. In the meantime, keep enjoying the build!
  35. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    07-09-2012 07:27 AM #35
    Looking good! See if you can run the oil feed line a little bit further away from the exhaust mani
