VWVortex.com - so it starts: PPT 3071 "build"
    Page 3 of 8 FirstFirst 1234567 ... LastLast
    Results 51 to 75 of 182
    Thread: so it starts: PPT 3071 "build"
    1. Member Dub-Nub's Avatar
      Sep 27th, 2005
      '86 BMW 528e, '01 VW Cabrio
      07-12-2012 09:59 AM #51
      Quote Originally Posted by jstnGTI View Post
      read up on it a lot before I made the decision. wanted to hear this bad boy scream for myself. sounded gnarly on YouTube.
      oh I know exactly what you mean becuase i was in the exact same position. I originally had the open dump on my pagparts build but in the end sent it off to him for a re-route because it was just getting annoying. i wanted to hear the turbo spool.
    2. Member mm2129's Avatar
      Feb 3rd, 2009
      Toronto, Ontario
      MKIV GTI 1.8T
      07-12-2012 10:58 AM #52
      subscribed can't wait to see more!
    3. Member Dub-Nub's Avatar
      Sep 27th, 2005
      07-14-2012 02:12 PM #53
      you better be putting it all together cause i know you got the tt manifold
    4. Member
      Jan 30th, 2012
      WA
      '05 GTI
      07-15-2012 12:11 AM #54
      Quote Originally Posted by Dub-Nub View Post
      hahah, yes!
      straightened everything out. shift linkage installed ( was a mother fcker to get unstuck from behind the motor since I rushed putting it in), dogbone attached, and started working on the half of ic piping I could without the mani.
      THEN, Friday the mani came in (:
      wrinkle black- sick.
      had to work 12's this weekend over night, so it took up some car time. but I was able to swap everything to the new mani and clean my throttle body.
      the 630's sit way higher, so I'm going to use some tubing as a spacer or a lot of washers and longer grip bolts. also going to need some new vacuum line cause the ports for the fpr are opposite.
      i'll get it sorted out.
      still waiting on software and fuel pump install kit.
      I'll get everything buttoned up so those are the last two things i need.
      MORE TO COME!
      sad to say it won't run this weekend :\
      3071/rods/ppt.. and still just a gti.
    5. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      2001 Audi TT Quattro
      07-15-2012 07:03 PM #55
      Proper fuel rail spacers can be purchased from USRT or ECStuning
    6. 07-15-2012 07:07 PM #56
      Quote Originally Posted by formerly silveratljetta View Post
      X2. It'll save u headaches! he he
      Pag Parts kit, PTE 5130, Brute rods, Eurodyne 630cc, Stg 2 water/meth, Pag Parts FMIC Kit with TT225 intake mani, Stage 3 Clutchnet n 17lb FW, 398whp @ 24psi
      Jan 30th, 2012
      WA
      '05 GTI
      07-16-2012 02:54 AM #57
      more of a DIY kinda guy.
      plus I had these laying around.
    8. 07-16-2012 01:48 PM #58
      Nice build. I would have went re-routed dump because the screamer pipe will get annoying in time.
      you must be old
      Joosey - DubAudi - Banchwerks - ForceFed Engineering - HighwayStar
      PVW 9/11
      Quote Originally Posted by uzi did it View Post
      you can compare me to kobe bryant of the vw world. i'm just that good.
    9. Member Dub-Nub's Avatar
      Sep 27th, 2005
      07-16-2012 01:49 PM #59
      Quote Originally Posted by ForVWLife View Post
      you must be old
      Respect your elders!!
      but no i am not old
    10. 07-16-2012 01:55 PM #60
      but no i am not old
      i actually missed your 2nd post the first time
      mine is open dump....i hear tons of spool then screams like none other
      PVW 9/11
    11. Member Dub-Nub's Avatar
      Sep 27th, 2005
      07-16-2012 01:58 PM #61
      so you heard the turbo spool then the pipe scream? Did you heat the turbo spool while the pipes screamed?
      Cause my turbo didnt spool slow
    12. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      01 Jetta Wolfsburg Ed, 04 Jetta GLI 24v 6spd
      07-16-2012 02:09 PM #62
      i glued/stacked washers
      My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    13. Member
      Jan 30th, 2012
      WA
      '05 GTI
      07-16-2012 03:17 PM #63
      anyone know what to do with my n275 valve wires? how to properly delete it?
      cut the wires and tape them off?
      as you know I have a manual boost controller, and maestro I assume will let me code it out.
      just have a left over plug.
    14. Member Dub-Nub's Avatar
      Sep 27th, 2005
      07-16-2012 04:23 PM #64
      Just tug the wires away somewhere, dont cut anything.
    15. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      07-16-2012 04:27 PM #65
      def do not cut wires, you can trim away the harness wrapping and re-wrap once you get some slack.
      i hear my turbo spool whilst my dum screams..cos the billet wheel, with no filter,etc is effing LOUD..it makes a creepy whine at idle..you can hear it sucking air..love it.
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    16. 07-16-2012 04:34 PM #66
      X3
      Sent from te lo mande desde mi cel!
    17. Member Dub-Nub's Avatar
      Sep 27th, 2005
      07-16-2012 04:42 PM #67
      Quote Originally Posted by Vegeta Gti View Post
      well that makes sense then
    18. Member
      Jan 30th, 2012
      WA
      '05 GTI
      07-16-2012 07:41 PM #68
      so you're telling me, leave it as is... Unplugged and tucked away?
      what if I cut the slack, and wrap the two individually (not touching)?
      still a bad idea? haha
      did some harness maintenance today. separated, re wrapped a couple things, cleaned it up.
      mostly for the new manifold, and tryin to keep my wires "tucked."
      when I had my harness apart the first time, I cut back the washer and coolant fluid sensor wires with no problems, resistored everything else.
      quick shot of my unfinished bay while I still had the motor in:
      real update coming shortly. almost finished the harness today, when I ran into that problem. core support and front mount will happen next.
    19. 07-16-2012 07:51 PM #69
      If you're going to cut ANYTHING out of the harness; it has to be resistored
      Quote Originally Posted by gdoggmoney View Post
      There's been too much butt sniffing before this dog fight.
      PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
    20. Member
      Jan 30th, 2012
      WA
      '05 GTI
      07-16-2012 11:51 PM #70
      as a temp solution, leave it unplugged or plug it in and cap the vacuum lines?
      i apologize for the amount of questions, I'm still not clear on what to do.
      just don't want to go limp q;
      SN: LOOOOOOK WHAT I CAME HOME TO!
      YES!
    21. Member David_Tedder's Avatar
      Oct 23rd, 2005
      Tdot/Barrie
      MKIV AWP, 08 TL-S 6MT
      07-16-2012 11:57 PM #71
      looks great dude,
      i would suggest some dei heat wrap for your oil/coolant lines
      and maybe some header wrap over your intake pipe ( i know it looks so good tho) but id prefer to have cooler intake temps, especially when its right above mani/wg
      just some thoughts
      My Build: 1.8L AWP PPT GT3071r Billet Wheel Tial Vband/8:1 Mahle Pistons/Arp Mains/IE H-Beam Rods/ACL coated Bearings Mains & Rods/ARP Everything/Fluidamper/IE Manual Timing Kit with Gates Belt/AEB head/Supertech Intake/Supertech coated Exhaust/Supertech Spring & Retainer kit/IE CVA1 Cams/IE Cam Gear/SEM Mani/Hemi TB/EV14 1000cc/ CM FX400
      PAG PARTS
    22. Member
      Jan 30th, 2012
      WA
      '05 GTI
      07-17-2012 05:40 PM #72
      ooooookay! really trying to sew this build up!
      downpipe installed, rest of the exhaust will be made locally after break-in happens.
      rear O2 sensor doesn't reach, might cap it off, might extend it, haven't decided..
      no cat, anyway.
      got some passenger side shaving done, looks ****ty IRL right now... not my main concern atm.
      core support mounted, started mocking up FMIC piping, getting ready to drill rebar.
      gotta go mount my IC.
      ALMOOOOOOOOOOOOOOOOST DONE!
      Quote Originally Posted by *+NEIL*+DIAMOND*+ View Post
      good call, buddy.
      got a resistor on the way.
      still need an answer for this.
    23. Member
      Sep 15th, 2005
      Silver Spring, MD
      '02JETTA (SOLD) '00TTQ (SOLD) '90 C2 964
      07-17-2012 06:12 PM #73
      if you can tune it out with maestro, don't bother plugging it in
      if you cannot, then leave it electronically plugged in only
      you don't have to cap anything, as there won't be anything attached to it, right?
      what are you using for boost control? an MBC or EBC or just from the WG for now?
    24. Member
      Sep 15th, 2005
      Silver Spring, MD
      07-17-2012 06:13 PM #74
      I really hope that you plan on cutting into the rebar, that is way too low and I am not sure how you will ever fit any bumper on there like that...if you manage to massage a bumper on there, then you will destroy your IC with the first speed bump then driving your car with no IC is not very much fun overboosting your turdbo ...
    25. Member David_Tedder's Avatar
      Oct 23rd, 2005
      Tdot/Barrie
      07-17-2012 07:13 PM #75
      you will 100% need to cut out ur rebar, something like this (i cut out too much cuz it was my first time but it did the job, make sure u have a serious cobalt drill bit and top notch sawz all blades, those rebars r no joke, i ended up using a torch
      PAG PARTS
