VWVortex.com - Need some help...
    Results 1 to 13 of 13
    Thread: Need some help...
    1. Member ClearBraGuy's Avatar
      Mar 4th, 2005
      08'R32 SOLD, 2012 Q5, 08' Infiniti M45s SOLD, 2009 HD Street Glide SOLD, Infiniti Fx35
      07-03-2012 02:50 AM #1
      Ok so I installed solowerks Coilovrs tonight. The install went well, but now I have an issue, the rear wheels are tucking in the fender. The only way to adjust up is to remove the lower control arm to get to adjustment. Does this seem right? The tools do not fit into the lower arm without it being swung down and out of the way. Any ideas are
      Appreciated!!! Pics in next post
    2. Member ClearBraGuy's Avatar
      Mar 4th, 2005
      07-03-2012 02:55 AM #2
    3. Member ClearBraGuy's Avatar
      Mar 4th, 2005
      07-03-2012 02:55 AM #3
    4. Member VR64ANT's Avatar
      Jan 24th, 2000
      SF Bay Area
      2008 UG R32 #3497
      07-03-2012 10:19 AM #4
      Even with the wheel off you can't get to it? Just rock it that low!
      Drive a hybrid. I need your gas. .:R
    5. Member NittanyR32's Avatar
      Aug 1st, 2011
      Central Pennsylvania
      2008 VW R32 [DBP #4582]
      07-03-2012 11:00 AM #5
      I have to drop control arm on my FK's to adjust rears. I've seen pics of people that install the collar upside down so they don't have to drop arm, but I wouldn't.
    6. 07-03-2012 11:45 AM #6
      Your installation is correct. It's a royal PITA yes. If you did your install yourself it shouldn't be that big of a deal to drop the CAs and spin them up.
    7. Member neu318's Avatar
      Feb 17th, 2003
      Coral Gables, FL
      2003 Silverstone GTI 1.8t(Gone), 2006 Brilliant Red Audi A3 3.2Q
      07-03-2012 12:09 PM #7
      On my A3 the adjustable perch is on top of the spring, not the bottom inside the control arm like in the picture. Not sure if that install is correct.
      Mods:Unitronics Stage 1+ | UM DSG Tune | Magnaflow Catback | HPA SHS Coilovers | MODSHACK VTDA intake
      VRSociety #172
      Quote Originally Posted by Boost112 View Post
      Interests:Food being shoved in hot chicks faces.... and other stuff....
    8. Member neu318's Avatar
      Feb 17th, 2003
      Coral Gables, FL
      07-03-2012 12:14 PM #8
      Found this picture of solowerks, I know it's not an R32, it's on a CC so it might be different for you but just so you could see.
      VRSociety #172
    9. Member mpearce's Avatar
      Apr 17th, 2003
      Delray Beach, FL
      2010 Jetta TDI, 2004 R32
      07-03-2012 12:48 PM #9
      If the kit came with a bolt to put through the rear spring adjuster to secure to the control arm I would leave it where it is. If not I would just install it on the top of the spring to make adjusting them easier in the future. On my FKs there was bolt supplied to secure it to the bottom so thats where I had mine installed.
    10. Member xbr80bx's Avatar
      Feb 2nd, 2007
      Wiesbaden, Deutschland
      Mk5 Golf R32 / Mk5 Jetta TDI (PD)
      07-03-2012 01:18 PM #10
      oops
      insert cheap credibility statement here...
    11. Member Ryan E.'s Avatar
      Oct 1st, 2002
      Huntington Beach
      '08 CW R32, '74 BMW 2002tii
      07-03-2012 01:45 PM #11
      That widow maker looks like it's ready to pop out.
      Yeah, each manufacture specifies the install order, my KW Clubsports have the adjuster on the top.
      It's actually pretty fast to drop the rear arm down, just 2 bolts. I'd imagione you're going to have to drop it down a few more times to get your height dialed in, so go get'em
    12. Member mfbmike's Avatar
      Feb 5th, 2011
      Miami, FL
      996 911 Turbo, E46 325i Sedan
      07-03-2012 06:19 PM #12
      Quote Originally Posted by Ryan E. View Post
      Every widowmaker looks like that.
      Current: 996 911 Turbo, E46 325i, MK7 GTI
      Past: E30 325i, B6 A4, NA Miata, FR-S, MK5 R32, MK1 Rabbit
    13. Member foreverblue's Avatar
      Mar 2nd, 2011
      Dirty Jersey
      08 .:R32 #2048/13 BMW 335i xDrive
      07-03-2012 11:54 PM #13
      Quote Originally Posted by mfbmike View Post
      that little ****er pop out once when I changed tire...
      My Build Thread
      Skyline-LED-Tail-light-DIY
      Quote Originally Posted by PSU View Post
      I also must say that Wei is one of the biggest bosses I have ever met.
      Quote Originally Posted by AWDMKV View Post
      Wei - he is a Funny Motha..
