VWVortex.com - carb conversion
    Results 1 to 6 of 6
    Thread: carb conversion
    1. Junior Member D727's Avatar
      Jun 6th, 2012
      mk4 2003 gti 1.8t, and mk2 1990 gli 2.0 16v
      07-03-2012 01:56 PM #1
      im trying to convert my fuel injected 1990 2.0 16v gli into a carberated 16v i found the carb kit from black forrest and it comes with the carb manifold.i know i also need a vacume advanced distributor but idk where to find one that would fit can anyone plz help me out and give me some advice thx
    2. Member Ice.dk's Avatar
      May 27th, 2007
      Karup J Denmark
      1986 Golf GTI 16v fun driver 2008 Passat 3C Variant 2,0 TDI Highline Daily driver
      07-03-2012 05:42 PM #2
      The distributor Should directly on from a saab 900 non turbo engine that what i was getting to when i had the same idea with a carb build maybeed you can rebuilde one fra a 1,3 engine with hall sender or elsre soy can still use your stock ignition ecu from the 16v engine
    3. Junior Member D727's Avatar
      Jun 6th, 2012
      07-04-2012 04:00 PM #3
      i pln on getting rid of the ecu and tryn to run with a vacume advanced
    4. Junior Member D727's Avatar
      Jun 6th, 2012
      07-11-2012 06:00 PM #4
      Quote Originally Posted by Ice.dk View Post
      do you know where i can find ths?
    5. Member flytech78's Avatar
      Nov 25th, 2003
      Dallas TX
      94 850csi, 92 miata, 2005 volvo v50t5 ,84 1.9tdi gti
      07-11-2012 06:11 PM #5
      i got one from a bmw e30 they are vacuum advance and bolt right up... search local junk yards make sure the vacuum is good by sucking on it and seeing if it holds vacuum.
      1 1 2 3 5 8 13 21 34 55
      Good bye and thanx for all the fish!
    6. Junior Member D727's Avatar
      Jun 6th, 2012
      07-16-2012 06:10 PM #6
      do you have a part number or the year i need
