Results 1 to 4 of 4
Thread: Experience with Volkswagen UP!/Seat Mii/Skoda Citigo - anyone?
  1. Junior Member My1stIbi's Avatar
    Oct 15th, 2010
    The Netherlands
    Several Citroens, Ibiza ST (6J8)
    07-04-2012 11:05 AM #1
    Awaiting the arrival of the Seat Mii for the misses I was wondering if anyone has had one of these hooked up to VCDS yet and if the program recognized all the modules in it?
    And maybe found any nifty options?
    I have a HEX-USB+CAN interface myself so it should be able to get at least some info from the car. Just have no car to test this on .
  2. Junior Member My1stIbi's Avatar
    Oct 15th, 2010
    The Netherlands
    08-07-2012 04:06 PM #2
    Just for posterity (we got the car last Saturday):
    I've managed to enable these options in the Mii using the label descriptions from my Ibiza 6J as the control modules seem similar:
    -17 instruments
    byte 0 bit 6: Fuel consumption to km/l (bit 4 was enabled to start with and bit 5 and 7 set to 0 )
    - 09 cent.elect.
    byte 0 bit 5: single door unlock
    byte 12 bit 6: cornering lights
    byte 21 bit 2: cornering lights with turn signals
    byte 13 - bit 0 and 1: parking lights option
    bit 0: Parking lights ON only w/o Ingnition ON possible
    bit 1: Parking lights Function active
    byte 10 bit 2: coming home
    byte 14 bit 4: tear whiping
    byte 23 bit 6: DRL can be disabled with this bit (standard on)
    channel 43 - comfort turn signals from 3 to 5
    I couldn't enable the front power window comfort functions. This is due to the fact that the doors don't have modules of their own.
    Autoscan with manufacturer settings:
    Code:
    Saturday,04,August,2012,22:09:35:47062
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 6N0
    Scan: 01 03 09 10 13 15 17 19 25 44 56 61 AD
    VIN: VSSZZZAAZxxxxxxxx
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    AD-Brake Sensors -- Status: OK 0000
    Address 01: Engine (------CHYA)       Labels: 04C-906-020-CHY.clb
       Part No SW: 04C 906 020 H    HW: 04C 907 309 C
       Component: 1.0l R3 MPI   H01 3364
       Revision: U8H01---    Serial number:
       Coding: 00110032022401000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM10MPI01104C906020H 001006
       ROD: EV_ECM10MPI01104C906020H.rod
       VCID: 204513103BD8C29
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 D    HW: 1S0 614 517 D
       Component: EBC 460 ESP   H08 0011
       Serial number: A0013N2
       Coding: 22BF24718BAD02F744FD24FAD1B1405059B100
       ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
       ROD: EV_Brake1ESPMP1TRWVW120.rod
       VCID: 3065E3506B38729
    Address 09: Cent. Elect. (J519)       Labels: None
       Part No SW: 1S0 937 090     HW: 1S0 937 090
       Component: PQ25 BCM      H57 0555
       Revision: -8------    Serial number: --------------
       Coding: 62B82B0000010000000001F02E28ACC077C0426F7E820440200000020100
       VCID: F0E5A35023B8B29
    Address 10: Park/Steer Assist (J446)       Labels: None
       Part No SW: 1SL 919 475     HW: 1Q0 919 475
       Component: PARKHILFE 3K  H03 0005
       Revision: --------    Serial number: 32901219100498
       Coding: 100001
       ASAM Dataset: EV_EPHVA14SE1200000 001001
       ROD: EV_EPHVA14SE1200000.rod
       VCID: 132F4CDCFA6EA91
    Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
       Part No SW: 1S0 959 655     HW: 1S0 959 655
       Component: VW10Airbag00D H03 0005
       Revision: --------    Serial number: 003G3003S9H-
       Coding: 000000000000000000000000000000003044
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       VCID: FBFF847C72FEC11
       Serial number: 3495RRB40511ADPECOVB
       Serial number: 3505RRB404P1ADPCK0AU
       Serial number: 3555NRB405P1ADPEGGVO
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 1SL 920 860 Q    HW: 1SL 920 860 Q
       Component: KOMBI         H08 0021
       Revision: X0008005    Serial number: 00000000000000
       Coding: 114A00
       ASAM Dataset: EV_KombiUDSMM9RM10 A04708
       ROD: EV_KombiUDSMM9RM10_VW12.rod
       VCID: 5AB161F85D04589
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-19.lbl
       Part No SW: 6N0 909 901     HW: 1S0 937 090
       Component: GW-K-CAN TP20 H57 0555
       Revision: -8------
       Coding: 021200
    Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 1SL 920 860 Q
       Component: IMMO          H08 0021
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: EAD1B1380D64489
    Address 44: Steering Assist (J792)       Labels: None
       Part No SW: 1S1 909 144 G    HW: 1S1 909 144 G
       Component: EPS_ECU       H30 1503
       Coding: 0001000101000000
       ASAM Dataset: EV_SteerAssisNSK 009004
       ROD: EV_SteerAssisNSK.rod
       VCID: 3777D84C8E56A51
    Address 56: Radio (J503)       Labels: None
       Part No SW: 1SL 035 156     HW: 1SL 035 156
       Component: Radio         567 5538
       Revision: AA001001    Serial number: SEZ8Z1M5018930
       Coding: 0000040802
       VCID: 040D7F8087003E9
    Address 61: Battery Regul. (J840)       Labels: None
       Part No SW: 1S0 907 534     HW: 1S0 937 090
       Component: Batt-regelung H57 0555
       Coding: 032B7864
    Address AD: Brake Sensors (J939)       Labels: None
       Part No SW: 1S0 907 201     HW: 1S0 907 201
       Component: CV-SENSOR     H06 0450
       ASAM Dataset: EV_CVSen 001001
       VCID: E7D7C80C1E76751
    2 Faults Found:
    12289 - Unknown Error Code
              C10FD 00 [008] - Electrical Failure
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 45
                        Mileage: 11 km
                        Date: 2000.14.12
                        Time: 12:07:56
    12290 - Transport Mode Active
              U1105 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 1 km
                        Date: 2000.14.00
                        Time: 18:12:39
    End   ---------------------------------------------------------------------
  3. 01-13-2013 07:47 AM #3
    Could you please post an autoscan after you finished coding these properties. I am a Citigo user and I'd like to match it with yours. Thanks.
  4. Junior Member My1stIbi's Avatar
    Oct 15th, 2010
    The Netherlands
    01-14-2013 04:32 PM #4
    As requested, this is with Scandinavian DRL on and front DRL with low beam instead of standard front DRL lights. I've changed the full consumption correction to 110 (!). Don't know if that shows up in the autoscan though.
    Code:
    Sunday,06,January,2013,15:24:35:47062
    VCDS Version: Beta 12.10.1 (x64)
    Data version: 20121121
    Chassis Type: 6N0
    VIN: VSSZZZAAZXXNNNNNN
       ROD: EV_ECM10MPI.rod
       VCID: 204513103B74351EA81
       VCID: 3065E3506B94859E381
    Address 09: Cent. Elect. (J519)       Labels: 1S0-937-08x-09.clb
       Coding: 63B82B0000010000000005F06F2BBCC877C0426F7E860448200000020100
       VCID: F0E5A3502314459EF81
    Address 10: Park/Steer Assist (J446)       Labels: 1Sx-919-475.clb
       Coding: 100001
       VCID: 132F4CDCFAC25E86253
       ROD: EV_AirbaVW10BPAVN750_VN35.rod
       VCID: FBFF847C725236C65D3
       Crash sensor for side airbag; driver side:
       Crash sensor for side airbag; passenger side:
       Crash sensor for front airbag; driver side:
    Address 17: Instruments (J285)       Labels: 1Sx-920-xxx-17.clb
       Coding: 514A00
       VCID: 5AB161F85DA8AFCEA65
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Revision: -8------
       Coding: 021200
       ROD: EV_ImmoUDSMM9RM10.rod
       VCID: EAD1B1380DC8BF4EB65
    Address 44: Steering Assist (J792)       Labels: Redir Fail!
       VCID: 3777D84C8EFA52A679B
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Coding: 0000040802
       VCID: 040D7F8087ACC93EAC9
       Coding: 032B7864
    Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
       ROD: EV_CVSen.rod
       VCID: E7D7C80C1EDA8226A9B
    2 Faults Found:
    12289 - Function Limitation due to Optical Constraint
              C10FD 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 45
                        Mileage: 11 km
                        Date: 2000.14.12
                        Time: 12:07:56
              U1105 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 1 km
                        Date: 2000.14.00
                        Time: 18:12:39
