Results 1 to 30 of 30
Thread: B5 pte5857
  1. Member joedubs's Avatar
    Feb 2nd, 2004
    07 wrx wagon, 99 a4 avant BT
    07-04-2012 03:55 PM #1
    Figured I'd post up since the car actually runs now. I had a built 2L 06a and a worked AEB head that I was putting in a Porsche 914. Long story short, life got in the way. I got married, went back to school blah blah blah and now the Porsche sits.
    Anyway, I sold the bottom end and picked up a b5 avant which is what I had wanted before I bought the Porsche). It needed a trans so i got a v6 trans with low miles and swapped it in.
    Originally I was going to just bolt the turbo on, build a downpipe, and build the motor next year. I ended up snapping a few manifold studs and decided to swap in the head that I had. Maybe it wasn't the most cost effective way to do things, but I wanted to be able to drive the car this summer and I just didn't have the means available to do rods right now too.
    Management is provided by Lugtronic. I had the ecu from the Porsche project and using kevin's guidance I built a PNP adapter similar to the one that he sells.
    The Exhaust is a full custom 3" turbo back. No cat, no muffler, no resonator and it's really really loud.
    Parts list:
    AEB head (assembled by QED)
    Supertech valves (inconel and black nitride)
    Cat gold valve springs
    new oem lifters, new exhaust guides, new cam chain tensioner
    Cat 3658 cams from QED
    Pagparts Vbanded manifold
    PTE5857. Billet, Ball bearing, Vbanded housing
    tial 38mm wastegate
    034 FMIC kit
    034 billet 044 drop in
    840cc's
    I also have fsi coils and a repair harness that I'll be using to upgrade at some point. Probably when I do the bottom end.
    Pics because nobody cares about words:
  2. Member Budsdubbin's Avatar
    Jul 14th, 2008
    Buffalo, NY
    BMP20th/00 chevy tahoe
    07-04-2012 05:53 PM #2
    20th build ~9:5:1 wiseco 81mm forge pisons~IE 20mm rifle drilled H beams~Calico rod bearings~snowperformance single injection water/meth~stock small port AWP head matched to a IE intake manifold~hemi throttlebody~Custom downpipe/turboback~Self maestro tuned~tial 38mm wastegate~GT3076r .63ar Vband~6 puck Clutchnet~PTE600.
  3. Banned rodgertherabit's Avatar
    Apr 16th, 2009
    Southern Michigan / Raleigh, North Carolina
    Jazz Blue #0802
    07-04-2012 06:23 PM #3
    I want to do a build like this sooo bad.
    for you.
  4. Member T-Boy's Avatar
    Jul 16th, 2003
    ATL
    07-04-2012 07:19 PM #4
    Good looking build.
    APR Stage 3071R+
  5. 07-04-2012 07:43 PM #5
    Sweet
    Quote Originally Posted by gdoggmoney View Post
    There's been too much butt sniffing before this dog fight.
    GONZO tuning PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
  6. Member
    Feb 21st, 2004
    Stanceville
    94 Jetta scrapin pinch welds
    07-06-2012 11:07 AM #6
    This looks very familiar I have the same setup going on my 98 Tropic green.
  7. Member Three3Se7en's Avatar
    Jul 1st, 2007
    Mississippi
    02 337. 08 F150
    07-06-2012 11:26 PM #7
    Stock bottom end? Looks good though.
    2.1L, 1000cc, Maestro, CompTurbo 5558, CTS, IE intake, Scat rods, more to come..
  8. Member joedubs's Avatar
    Feb 2nd, 2004
    07-12-2012 10:35 AM #8
    Yeah stock bottom end for now. Im thinking maybe an 06a swap next winter.
    Feb 21st, 2004
    Stanceville
    07-12-2012 11:47 AM #9
    Quote Originally Posted by joedubs View Post
    We are basically doing twin builds here. My 058 has brute rods in it, i'm moving the pistons/rods over to my 06A if it does not need a bore and a hone will clean it up. I want the internal waterpump and better accesory belt, not that old school crappy mk2 belt setup the AEB and early cars had.
    I've been running around in my MKIV Jetta with a 3076 hitting mid 20psi occasionally on a 193k mile never opened stock 06A bottom end. If you have a good tune and good fuel + spark, these things are pretty bulletproof. Before that I went years on a 3071R 100% stock motor at near 30psi sometimes, with lots of long highway pulls to heat up the oil and create high EGT's. Never an issue.
    Oh, I have a 914 on jackstands too, getting sheetmetal work. How awesome.
  10. Member joedubs's Avatar
    Feb 2nd, 2004
    07-19-2012 10:18 PM #10
    That's crazy, we are doing twin builds!
    Been driving the car a bit. Running off the wastegate spring it's boosting to around 18 psi (I haven't checked what spring is in there, but I believe they come with a 1bar. If so, I guess it's creeping a little).
    Ordered a vibrant resonator, and a magnaflow muffler. Hopefully I can quiet it down a little bit.
    Pardon my crappy front bumper. I want an s4 bumper, facelift headlights, and a new hood. One day.
  11. Member
    Feb 21st, 2004
    Stanceville
    07-20-2012 11:07 AM #11
    Nice! How does it feel?
  12. Member joedubs's Avatar
    Feb 2nd, 2004
    07-20-2012 11:45 AM #12
    Really awesome. And I can definitely tell that the turbo is just starting to wake up at that boost level. The map log shows it just starting to really climb then it flat lines.
  13. Member joedubs's Avatar
    Feb 2nd, 2004
    07-31-2012 11:32 AM #13
    Doing work.
  14. 07-31-2012 12:01 PM #14
    Nice build!
    Been trying to scoop up an 01 Avant, it's a pain in the ass finding a decent one that someone doesn't want a kidney for.
    MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
    P.P.T. - Pag Parts Turbo
    B6 A4 : Slow
  15. Member joedubs's Avatar
    Feb 2nd, 2004
    07-31-2012 12:50 PM #15
    Thanks!
    I looked for an 01 that I could get for a decent price for about a year. When I gave up this 99 fell into my lap for a price I couldn't pass up. It's not exactly what I wanted, but its a great base.
  16. Member
    Feb 21st, 2004
    Stanceville
    07-31-2012 01:46 PM #16
    Doing work.
    Nice. I've found whilte two mufflers quiet these cars down, they rob a ton of response and power.
  17. Member joedubs's Avatar
    Feb 2nd, 2004
    07-31-2012 05:33 PM #17
    Both are 3" non baffled designs. I really can't imagine them creating enough restriction to choke anything.
  18. Member
    Feb 21st, 2004
    Stanceville
    08-02-2012 02:07 PM #18
    Dude.... telling you from 100% experience and can take a picture. I have that exact same magnfalow from an old 42dd kit, and adding it behind my Aero Turbine 3" I lost spool, power, response and it was noticable. The car quieted down some sure, but at a price. The holes inside the magnaflow that go into the packing area allow heat/pressure to be lost along with noise.
    Much like we have 914's and mirror builds minus the avante I'd suggest making one removable for go fast days, and building another pipe from muffler 1 to exit for those days to avoid open downpipe under the car drone.
  19. Member joedubs's Avatar
    Feb 2nd, 2004
    08-03-2012 08:24 PM #19
    Time for a different exhaust.
    Ordered a dynomax VT.
  20. Junior Member
    Dec 3rd, 2010
    Brisbane, Queensland, AU
    99.5 Audi B5 A4 1.8T Quattro
    08-04-2012 07:30 AM #20
    Im running one and planning to get rid of it. The rattle is f*ckin annoying.
    Here's a vid of my car with the dynomax VT @ idle.
    http://youtu.be/K0ucacCtXD4
    Thats with a TD05H-20G turbo(psi concepts turbo kit).
  21. Member
    Feb 21st, 2004
    Stanceville
    08-14-2012 10:03 AM #21
    I have a straight silver hood on the 98 FWD parts car I have here.
  22. Member joedubs's Avatar
    Feb 2nd, 2004
    08-14-2012 10:11 AM #22
    Trade ya? :-)
    Car is much quieter with the VT, but still way loud. It doesn't rattle unless I turn on the head lights and the idle drops due to alternator draw. I may add a cat to quiet it down a little more.
    Thinking about an ME7 swap too. Never ending project.
  23. Member
    Feb 21st, 2004
    Stanceville
    08-14-2012 10:30 AM #23
    Trade ya? :-)
    Sure, throw in a few dollars and you have a deal. I'll take a closer look at it when I get home tonight
  24. Junior Member
    Dec 3rd, 2010
    08-20-2012 04:21 AM #24
    Trade ya? :-)
    I was about to buy the >4L version until I read this.
    Looks like a 2 muffler setup it is. I wonder what's the effect of running an aluminum pipe?
  25. Member joedubs's Avatar
    Feb 2nd, 2004
    08-25-2012 02:42 PM #25
    Definitely stay away from the VT.
    Again, it's not that it's bad, it's just that i dont think it lives up to the hype.
    I'm going to try and find an s4 3" milltek.
  26. 08-25-2012 03:09 PM #26
    My old milltek was closer to 2 3/4" iirc
  27. Member joedubs's Avatar
    Feb 2nd, 2004
    08-26-2012 05:12 PM #27
    Hmm. I thought A4 version is 2.5, s4 single is supposed to be 3". Maybe I'm wrong.
  28. 08-26-2012 06:14 PM #28
    Mine was on an B5 A41.8TQ.
  29. Member
    Mar 5th, 2007
    99 audi avant
    08-26-2012 08:29 PM #29
    A4 milltek is 2.75 and s4 is 3in
  30. Junior Member
    Dec 3rd, 2010
    08-29-2012 10:16 AM #30
    I'm gonna tack weld the butterfly valve to remain open. Sounds heaps better. With it closed, it sounds like ****.
    I managed to get the valve to remain open(temporarily)..not loud at all..just that at certain speeds, the drone is pretty bad.
