I think you missed a zero in there somewhere... if not, consider it sold![]()
#1
SOLD!!!
I have owned the car for a little over a year and it’s time for me to move onto something else. Since I have owned the car I have pretty much got this car back to 85% out of a 100% for the age of the vehicle.
I have a car fax on the car up till when I have owned it.
Silver in color
108xxx miles.
Mobil 1 synthetic
With sport interior
Has software on the car but I don’t know what it is. “it is not APR or GIAC” I boosts to 16lbs I’m guessing Revo”
UUC motorwerk 2 ½ cat back exhaust
APR bi-pipe Kit
Samco boost hose kit
H&R sport springs
I have since owned I have done
03 & 04 A8 flat five wrapped on Kumho ecsta’s with 6/32 with nitro filled
Rebuilt the 6 speed transmission with Brand new clutch, pressure plate and throw-out bearing
Brand new driver side rear lower control arm
New window tint
Brand new AWE vent mounted boost gauge
Brand new OEM radio
Replaced the temp control
Replaced sagging headliner
Brand new S4 rear trunk mat with blocks
New battery
2 brand new Forge 007 diverter valves
Brand new smoked turn signals
Both brand new HID bulbs
Brand new shift assembly
Brand new e-brake cables
Replaced pass side tail light
Replaced driver side mirror “auto dim went bad”
Brand new passenger and driver side front wheel bearing
Brand new all four front control arms
Replaced driver side front axle
Replaced the passenger side rear lower control arm
Brand new S4 monster mats
Brand new Spare key
Brand new engine belly pan
Brand new passenger side fog light and grille
Replaced passenger side turbo clamp
Brand new engine mounts
Brand new RS4 transmission mounts
Replaced ABS computer
Brand new NKG spark plugs
Brand new auxiliary water pump
Brand new O2 sensors
Brand new Bosch alternator
Brand new mass air flow sensor
Brand new coolant temp sensor
Brand new front Zimmerman drilled disc brakes and Hawk HPS street /sport pads
Brand new license plate housings and bulbs
Brand new cabin filter
Replaced front bumper assembly
I have had it aligned 3 times
Brand new Altimax arctic snow tires mounted on the S4 stock rims that can or don’t have to go with the sale.
Good used rear bumper assembly that can go with the sale
I just had the timing belt, tensioner roller, idler roller, water pump, thermostat, accessory drive belt, valve cover gaskets, intake gaskets and cam seals. “Valve cover, cam seals and intake gaskets were done @ 12k ago and the rest was just done”
The bad’s
Front cover has a 1 inch crack in it
Some scuffs and scrapes here and there due to the age
Driver side has a small cig burn on the “top/back section”
Trim around the hazard switch the clips are broke. Stays in place but will pop off easy
The base for the E-brake has a clip that’s busted off so the leather boot has nothing to hold it on.
Driver side inside door handle a little loose.
Inside rearview mirror is bleeding out the auto dim
Asking $10,095.00 for everything I have.
I'll be working on some updated pics here soon. I do have these older ones for now
#2
ClearWaterDubs Web -- CWD on Vortex
2012 CW 4Dr Golf R - | APR Stage 2+ (93) | APR HPFP | Scorpion TBE | DXD Stg2 Endur Clutch | EVOMS V-Flow | BSH PCV Fix | Diesel Geek SS | HPA Dogbone |
| NewSouth Boost Gauge | H&R FSB | H&R Sport Springs | Bistein Sport Rear Struts | LED Tails | Misc "Moar Better" Mods |
#3
Nooooo! Well, if its gots to go....
Bump for a proper seller. If it is broken, he gets it fixed one way, properly. No short cuts, no cheap parts. Someones getting a proper ride.![]()
#4
#5
#6
Wanna trade for a TT?![]()
Just got text from Baller:
"German's have found me. Jumped in friends Delorean. Explain more when I get back." - rookdubdoc
#7
My other brotha from anotha motha...
No trades at this time, I'm trying to thin out the herd that I got.![]()
#9
#10
#11
Hey! I thought I was yo otha brotha from anotha motha?!? Or was it, a different color motha? Anyways, BUMP for a good dude, and a nice whip!![]()
4th Annual Scooter's GTG European Car Show
Saturday June 9th 2012 Milwaukee, WI
www.scootersgtg.webs.com
http://forums.vwvortex.com/showthrea...1#post76703771
#12
bump for updated pics
and cause
#13
Seems like a nice pick up! Just a question, did you actually rebuild the transmission, or did you replace the clutch assembly?
Sam
#14
#16
Thanks![]()
Now buy it
