Results 1 to 2 of 2
Thread: 8v timing issue.
  1. Member Sosl0w's Avatar
    Aug 21st, 2003
    Fredericksburg, VA
    07-05-2012 02:43 PM #1
    Have an 84 GTI with a timing issue i can't figure out. So I time the car perfectly. All marks and such line up, car starts up and idles perfectly. Put the car in gear and try to drive, it goes about 20 feet and then dies. Check the timing again and its completely off! Its like the timing changes as soon as the car has load under it. Not sure why its doing this. Any ideas?
    B5 S4
    84 GTI (Sold)
    03 24v turbo (sold)
    Nov 17th, 2001
    Northern Wisconsin
    07-05-2012 05:42 PM #2
    You don't indicate why you were messing with the timing to start with.
    Maybe a missing or sheared woodruff key at the crankshaft, the intermediate shaft or the cam shaft. I have also seen an intermediate shaft with a broken keyway as well as timing belts missing teeth, gear teeth full of crud causing the timing belt to slip and idler pulleys with failed bearings causing an out of round rotation. There are a number of possibilities -- take your pick.
    If you don't know when the timing belt was last changed you should consider installing a new timing belt and idler pulley. About $40 for parts on line. FR
