Results 1 to 3 of 3
Thread: EGT very high !! need help
  1. Junior Member
    Sep 14th, 2009
    Israel
    07-05-2012 03:02 PM #1
    Hello
    I have a 97' Passat 1.8T B5 AEB engine.(125k km)
    3 days ago i was doing a track day and when the car was at 200km(less than 7000RPM) the EGT shows 930c at fifth gear.this is strange becase 900c is the max to be on the safe side so i cant pass 200km even the car can go to 250km easy.
    Today i notice that the EGT is 930c at 180km fifth gear,930c at 140km 3rd gear(!)
    I must say that month ago i didnt had this issue,i ran 4th gear to 200km 7500RPM and EGT shows less than 900c,it was 880-890c
    when driving 100-100km it shows 600-700c.
    my setup:
    GT28RS
    FMC
    440CC injectors
    Big fuel pump
    HKS BOV
    Manual boost control (3 pipes)
    2.75" from downpipe all the way
    chip for GT28RS
    Clutch Masters stage 3
    The manual boost control set to 1.4 BAR
    Any Idea what is wrong?
    Thanks
  2. Junior Member
    Sep 14th, 2009
    Israel
    07-18-2012 04:08 PM #2
    i replaced the fuel filter,plugs,lambda sensor,maf sensor,no vacum leaking,i did wideband up to 1.6 bar and it was ok,
    still egt too high,black smoke on 3rd gear,
    any idea...?
  3. Member vdubb3dan's Avatar
    Apr 7th, 2004
    Scranton PA
    Bagged B5.5 1.8T/81 rabbit diesel/tons of B3's
    07-18-2012 04:50 PM #3
    Sounds like you're running very rich. What sort of a/f numbers are you seeing?
