VWVortex.com - Automatic Shift gate cover
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 45
    Thread: Automatic Shift gate cover
    1. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-06-2012 01:07 AM #1
      So I saw the thread where the guy in a mk4 bought the momo knob and put a manual shift surround in place of the PRND etc. And I have an mk3 automatic so I wanted something cleaner in my car cause that thing is hideous.
      So to start off with I went out and bought the manual shift surround from this guy kinda ripped me off but I was desperate junks yards didn't have them started by cleaning it then.
      [IMG][/IMG]
      STEP ONE: you want to cut a portion in the top part of the surround so the car can go into Park. Like so.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      STEP TWO: your going to want to make sure the cuts big enough. Then either use the OEM shift boot or make your own and to make your own is pretty straightforward just undo an OEM boot and trace it out on the material you want and get it stitched having a sewing machine is very helpful and a mom who can help haha
      In the OEM boot there is a spring that wraps around the shift surround to hold the boot in place your going to want to make sure you see a tunnel like to feed the spring through our new boot
      I had to cut the spring to get it off then twisted the ends together once through the new boot to stay in place to make sure I taped it with electrical tape, and the result for the boot will look like this:
      [IMG][/IMG]
      STEP THREE: To get your boot to stay up is a bit difficult but i had the manual knob and the clamp it had that keeps the OEM boot in place looking at how that worked I applied it to the little cylinder plastic that goes under the knob on MK3 automatics.
      I had yarn wrapped around it, stuck on by spray adhesive, (tried to go for a rat look in the interior but changed routes) therefore the yarn help thicken the cylinder so I fed the boot through the clamp folded it over to make it stay in place then taped the fabric to the clamp to secure it stuck the cylinder with the yarn side going into the clamp and getting to sit flush with the boot then stuck it on and was surprised I did it lol. I'll get pictures of this part soon!
      STEP FOUR: If your shift surround is a different color your going to want to paint it. The best way of going about this is to buy plastic spray paint ScotchBrite the surround wipe it down with a clean rag and paint light coats, give it some flash time, then give another coat, to speed my flash time I used a blow dryer on heat mode, no the paint won't peal its how every car is painted once down they bake it. So that shouldn't cause the paint to peal. Then put the boot back on a. Da then knob and our done!
      [IMG][/IMG]
      [IMG][/IMG]
      If any questions drop a reply here. I know its an automatic don't have to remind me twice. The reason for the fabric being that pattern is cause my head liner is the same way.
    2. Member VW-G's Avatar
      Jul 28th, 2010
      NWO
      not volkswagens
      07-06-2012 09:20 AM #2
      That's actually pretty cool
      Quote Originally Posted by toothpick View Post
      location says, NWO,.. what is that, new world order? are you a rockerfeller?
      Quote Originally Posted by DeathLens View Post
      I managed to destroy the car in 2 days...wait, did I say destroy? I meant make it awesome.
    3. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-09-2012 02:45 PM #3
      Quote Originally Posted by VW-G View Post
      Thank you!
    4. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-09-2012 02:59 PM #4
      This was one of the first mods i did to my MK3 Golf ... I modified my shifter lever so I could leave it in Neutral and just put the E-Brake. I do put it in Park sometimes though.
      I also got a 'MOMO Automatico' Shift Knob (Chrome & Black Leather) for it, flows very well. I'll snap a picture during my lunch break and post it on here for you to see
    5. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-09-2012 04:12 PM #5
      How did you get it to sit in neutral??
      Sent from my SGH-T959V using Tapatalk
    6. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-09-2012 04:35 PM #6
      Quote Originally Posted by VWDUBLUVIN View Post
      There's a metal tab that needs to be pushed down if I remember correctly. You'll notice it if you move from Park to Neutral. Just mess with it a bit. Anyway, here's a pic of mine:
      Oct 22nd, 2007
      New Haven, CT
      Mk3 windsor Gti 2.0, Mk1 Jetta 16v
      07-09-2012 04:37 PM #7
      thats pretty cool.
      Im not sure if this will fit but theres guys that do this in Mustangs.
      In addition to the shift boot this might fit on the shift lever... to get rid off the huge auto knob.
      http://www.uprproducts.com/mustang-b...-polished.html
      kind of expensive and im sure theres cheaper knobs out there, but this one is pretty solid.
    8. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-09-2012 04:50 PM #8
      Quote Originally Posted by Mileperhr View Post
      thats pretty cool.
      Doesn't work for us. I had contacted a retailer that sold those to get specs and it wasn't gonna work when I compared it.
      Luckily, I found the MOMO Automatico knob for cheap here on Vortex and love the way it looks.
      I had done the same thing on my old Civic that was Automatic using a Auto Spoon Duracon Knob, here's a picture:
    9. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-09-2012 04:51 PM #9
      Thanks guys. I'd like the momo one but from what I remember its even more of an expense then the Mustang one, I need a new knob though.
    10. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-09-2012 05:11 PM #10
      Yeah, the MOMO one is very pricey. I got lucky when I found the one I bought.
    11. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-10-2012 04:08 AM #11
      Ya I should start looking for a good used one too!
    12. Member Shaniqua's Avatar
      Oct 14th, 2008
      Sweet home, Alabama
      '00 Cabrio, '02 Passat
      07-10-2012 09:32 AM #12
      Really sweet. i might actually do this.
      but putting a manual knob on it and leaving it in neutral? now your kinda being lame.
    13. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-10-2012 09:49 AM #13
      Quote Originally Posted by Shaniqua View Post
      It's not a Manual Knob, the MOMO Automatico Knob (pictured on my MK3) is made specifically for Automatic Vehicles.
      If you're referring to the one I had on my Civic, then I can see where you're coming from. However, that "manual knob" is actually an Automatic Knob. I did not do the design of it, Spoon Sports designed it with the "Manual" look to it, you push down the button to engage into gears. It's actually a very rare and discontinued shift knob. Check the pics, click to enlarge.
    14. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-11-2012 03:25 AM #14
      Ya these are all automatic knobs. do it and show me the result!!
    15. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-11-2012 03:27 AM #15
      But quick question to you dannymk3 does your PRND321 light up in the dash??
    16. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-11-2012 09:25 AM #16
      Yes, my gear indicator in the speedometer still works.
    17. Member MKIIIRobby's Avatar
      Jul 9th, 2007
      Covington, WA
      98 Jetta (show car), 2013 Fiat 500 Lounge (daily driver), 95 Corrado (project car)
      07-11-2012 11:23 AM #17
      Very very cool! I love it!!!!
      I think my VW is broken. The check engine light is off!
    18. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-11-2012 11:47 AM #18
      I removed the Shifter Cover this morning before heading out to work, to take a pic so you can see the 'modifications' I did in order to be able to leave the car in Neutral and still remove the key from the ignition. Please excuse the dirtiness and crust, I need to clean my car really bad (LOL!) just been super busy.
      Hope this helps!
    19. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-11-2012 06:08 PM #19
      So it's supposed to have a light on it? Or just the black and white screen.
    20. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-11-2012 06:09 PM #20
      Thanks man!
    21. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-11-2012 06:31 PM #21
      Mine lights up green
      Oh and no problem on the picture, hopefully it helps you in making your shifter stay in neutral and remove the key from ignition.
    22. Member Shaniqua's Avatar
      Oct 14th, 2008
      Sweet home, Alabama
      07-11-2012 09:07 PM #22
      Im still confused on why you wouldnt just put it in park?
    23. Member DannyMK3's Avatar
      Feb 14th, 2012
      FL
      96 VW Golf 4DR
      07-11-2012 09:35 PM #23
      I don't understand, what's there to be confused about?
      I put it in park in situations when putting it in park is necessary, such as being on an incline. The rest of the time I choose to leave it in neutral and use the ebrake.
      Does it really matter to you what gear I leave my car on?
    24. Member VWDUBLUVIN's Avatar
      Apr 3rd, 2011
      Surpise, Arizona
      07-11-2012 09:47 PM #24
      Quote Originally Posted by DannyMK3 View Post
      thank you that is very helpful mine does not do that so the cluster will be coming off soon, and yes thank you for the other picture that will be the projects for tomorrow, ive been sick today and yesterday couldnt do anything
    25. Member LG6R's Avatar
      Oct 20th, 2003
      Mk3
      07-12-2012 12:28 PM #25
      There's an orange bulb (1.1w) in the back of it that's supposed to light it up when you turn the lights on. Once you take the cluster out, you'll see it.
