Results 1 to 8 of 8
Thread: Tow hitch and wiring installation
  1. 07-07-2012 12:07 AM #1
    Just picked up a 2012 TDI lux. Has anyone installed the hitch/receiver and wiring themselves? I did a search and did not come up with anything. Just wondering if it is a straight forward install ... I.e., essentially plug and play?
    Thanks!
  2. 07-11-2012 03:57 PM #2
    We just went through this thinking it was plug and play- when plugging in a boat trailer. The problem we ran into was the ground has to be in the trailer plug because if it isn't there, the car will recognize there is no ground and thus will not operate lights etc. Once we rewired the trailer so the ground was in the plug, it was truly plug and play. And our TDI towed very well!
    Mar 9th, 2004
    Laveen, AZ
    2012 TDI Sport, that replaced a 2006 V8 with all the options. Missing some of those !
    07-12-2012 06:05 PM #3
    I added the hitch reciever and plug, elecronics to my 2004. Was very easy and I had never done anything like it before. Basically had to pull off the rear bumper which is easy, unbolt the old cross member, bolt on the new crossmember with hitch (you will need a torque wrench for to torque correctly). Add electronics by pulling interior panels, and then put everything back on. I then took it to VW dealer I had a good relationship with service dept and they programmed for free for me. That was when I lived in Seattle area.
    It helps to have a buddy when you do this.
    As for my new 2012. I know I can do it on this one, but talked to a GM I know at a big Penske body shop in Scottsdale that I use and he will do it for $100 for me and I can then again take it to a local VW dealer I also have established a good relationship with and they will program for free for me.
  4. Member
    Mar 9th, 2004
    Laveen, AZ
    07-12-2012 06:50 PM #4
    I think there is a long thread on this over on Clubtouareg.com and someone has pics of his bumper dropped and it being a easy install.
  5. 07-13-2012 09:30 PM #5
    Quote Originally Posted by Tregger View Post
    Thanks for the info! I picked up the hitch and wiring kit today. I noticed that the hitch did not come with mounting hardware. Is hardware needed or do you install with existing hardware?
    Sam
  6. Member
    Mar 9th, 2004
    Laveen, AZ
    07-16-2012 01:24 PM #6
    Not sure on that one sorry. You might check the thread over on Clubtouareg or ask you service technician at the dealer. The should be able to let you know.
  7. Member VolksTrooper's Avatar
    Dec 4th, 2007
    Canada
    2000 TDI NB, 2011 Touareg TDI Campanella White, Sport package, Hitch, Pano Roof
    07-18-2012 09:30 AM #7
    See video below for a time lapse of install...
  8. 07-19-2012 12:46 AM #8
    Thanks that video is awesome!
    The mounting hardware for the hitch was missing. My dealer sourced the hitch from another dealer that had it in stock. My dealer called and the other dealer said that thay "forgot" the hardware. Hopefully I'll do the install when I get back in town next week.
