About the same setup as mine. Maestro 630 mafless base file runs like poo btw (well mine did). What kind of diverter valve or blow off valve are you using? Maf or mafless? Gotta upgrade to larger DV or BOV. CTS is a solid kit though. Oil drain line is a tad short so look around for a longer hose.Make sure you retighten your bolts on turbo - downpipe and wastegate bolts. Look into getting nordlock washers for that.
my base file idle's like poo. The new base file is a lot better in the midrange tho. Make sure you keep your vvt, it makes a difference
you can do all the studies you want about reactions times, etc. still does not negate the fact that Forge sells more than any of the other companies you named or the fact that 99% of their customers love their products. also, i could give a $hit about the "intelligent" posters or why you say they left
