Results 1 to 16 of 16
Thread: Ross-Tech, I'm stumped 17551 - Load Calculation Cross Check: Upper Limit Exceeded
  1. Member FuturaYell00's Avatar
    Apr 11th, 2004
    Eastside/Seattle
    2000 Futura Yellow VR6 GTI
    07-07-2012 09:48 PM #1
    I will start from the beginning. 2000 VR6 GTI 150k miles. I had no prior codes/CEL until a couple of weeks ago after some maintenance. Two weeks ago, I replaced my chains, guides, clutch, and front bearings, wires, and plugs. Coil pack is in great shape (replaced a couple years back) While I was in there, I removed my upper intake (obviously to get to the chains) and I removed my Throttle body to give it a nice cleaning. I cleaned all connections while I was in there as well. I realized I needed to do a TBA before I started the car, so I bought my $100 license and used basic settings to perform a TBA once the car was put back together.
    After about a week I started getting this code:17551 - Load Calculation Cross Check: Upper Limit Exceeded
    I performed the TBA a few more times, bought a new filter for my short ram intakeI, I have had the intake for 8 years, with no problems. The code kept coming back, so I bought a brand new Bosch MAF. After about 4 fresh starts after clearing the code again..... ITS BACK.
    One thing I thought was odd, but perhaps its normal is that when I wedge something onto the pedal, the rpms don't stay constant, they jump around a range of about 200 rpms, sometimes staying a bit more constant than others. I have sprayed hoses and intake area with carb cleaner looking for change in idle, nothin... So what could it possibly be?
    Here are some values I ran, but I don't know if they are irregular, and what the fix would be if they are.
    Group 060: TVS 1 (10.9%) TVS 2 (89.1%) Throttle adaptation steps counter (9) (ADP run OK)
    Group 020 engine running: 680rpm Engine load (23.3%) Injection timing (3.69ms) MassAirFlow (4.83g/s)
    Here is the full auto-scan. Thanks for any and all help.
    VCDS-Lite Version: Release 1.1
    Saturday, 07 July 2012, 18:13:21:16971
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55 ,56,57,75,76
    Address 01: Engine Labels: 021-906-018-AFP.LBL
    Controller: 021 906 018 M
    Component: MOTRONIC ME7.1 G V04
    Coding: 00031
    Shop #: WSC 01316
    VCID: 184309286B9D
    1 Fault Found:
    P1143 - 35-00 - -
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
    Controller: 1J0 907 379 R
    Component: ASR 20 IE CAN 0001
    Coding: 13204
    Shop #: WSC 01316
    VCID: 40F38148538D
    No fault code found.
    Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
    Controller: 3B1 907 044 B
    Component: CLIMATRONIC V 1.0.0
    Coding: 01000
    Shop #: WSC 01316
    VCID: 203321C8B3CD
    Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
    Controller: 6Q0 909 605 A
    Component: 09 AIRBAG VW5 0003
    Coding: 12345
    Shop #: WSC 01316
    VCID: 351DE09C1C4F
    Address 17: Instruments Labels: 1J0-920-xx0-17.LBL
    Controller: 1J0 920 920 D
    Component: A4-KOMBIINSTR. VDO V16
    Coding: 07262
    Shop #: WSC 01316
    VCID: 253D30DCACEF
    IMMO-IDENTNR: VWZ7Z0X1699963
    Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01316
    VCID: F0939188A3AD
    Address 46: Central Conv. Labels: 1J0-959-799.LBL
    Controller: 1J0 959 799 AJ
    Component: 62 Zentral-SG Komf. 0001
    Coding: 00256
    Shop #: WSC 01316
    VCID: 867FD750B129
    2 Faults Found:
    01358 - Internal Central Locking Switch; Driver Side (E150)
    27-10 - Implausible Signal - Intermittent
    00913 - Window Regulator Switch; Front Right Driver (E81)
    End --------------------------------------------------------------------------------------------------VCDS-
  2. Member kyle_b's Avatar
    Jul 11th, 2007
    east coast
    swapped, managed, and turbod A2 | Daily B6 sedan
    07-08-2012 12:12 AM #2
    check and post your fuel trims(mvb 32) after fault has occured
  3. Member FuturaYell00's Avatar
    Apr 11th, 2004
    Eastside/Seattle
    07-09-2012 07:59 PM #3
    Any Help appreciated. It just keeps getting worse. Here are the latest codes AFTER replacing the MAF with a Brand new Bosch one.
    Measuring blocks 32:
    Adaptation (Idle) Bank 1 Sensor 1 = (-0.6%)
    Adaptation (Partial) Bank 1 Sensor 1 =(-6.3%)
    Here are the latest codes. Car ran great for a week after all the work. Now it seems to be running a bit rough.
    Monday, 09 July 2012, 16:47:40:16971
    Control Module Part Number: 021 906 018 M
    Component and/or Version: MOTRONIC ME7.1 G V04
    Software Coding: 00031
    Work Shop Code: WSC 01316
    VCID: 184309286B9D
    3 Faults Found:
    16497 - Intake Air Temp. Sensor (G42): Signal too High
    P0113 - 35-10 - - - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    P1143 - 35-10 - - - Intermittent
  4. 07-09-2012 10:22 PM #4
    The new MAF is also bad, or China crap clone, go back to old one, or get an OEM factory new unit only!
    Warning!
    Many issues with clone China Bosch crap!
    Since a work detail was just done.
    Timing on the new chain is incorrect, slightly retarded, but within window of ecu threshold to not cause a correlation DTC. However, can cause the cross check DTC.
    An air leak due to improper gasket install or line negated installed or reversed?
    A bad brake light switch. Incorrect wattage brake light or wrong bulbs installed.
    A bad ecu or ground connection. Implausible ignition switch or supply voltage ecu relay.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  5. Member FuturaYell00's Avatar
    Apr 11th, 2004
    Eastside/Seattle
    07-09-2012 10:43 PM #5
    I hear you loud and clear, but it seems odd the new MAF would be bad. Bought brand new Bosch from MJM. As far as the timing, the car ran great for a little over a week 1000+ miles with no codes thrown. Cam lock tool was used and intermediate shafts were lined up correctly, checked by myself and 1 other mechanic to confirm correct place.
    Could the 17551 code be from a a bad TB or TPS if either was damaged while cleaning?
    How do these codes indicate that the timing is retarded?
    Also what indicates the wrong bulbs or brake light switch?
  6. 07-09-2012 11:31 PM #6
    Experience my friend.
    Just kidding!
    The Brake light switch is a direct link to the EPC, so is the clutch switch.
    Highly unlikely the TBA pedal switch is bad. However, if a bad OXS heater is on the fritz it can also cause this to mislead the ecu inside for false bad ground attenuation.
    The throttle valve itself could be bad, however is also not very likely.
    If out of spec it can cause so stupid issues such as this. Because the lamps are tied to it, this can also escalate the issue.
    Take the MAF apart, and take pictures of the #s inside, post for me to see, or email.
    It is actually very possible the new MAF can be bad right out of the box, in some cases.
  7. Member FuturaYell00's Avatar
    Apr 11th, 2004
    Eastside/Seattle
    07-09-2012 11:51 PM #7
    Email sent.
  8. 07-10-2012 12:10 AM #8
    Replied
    You sir,.... have a BOSCH clone!
    Nite.
    Feb 25th, 2010
    Wilkes-Barre, PA
    07-10-2012 10:01 AM #9
    Need a new mass OEM. Have seen all mass be bad right out of the box. So you will no be the first.
    Good Luck
  10. Member animaniac's Avatar
    May 25th, 2005
    Staffordshire, Uk
    Golf 1.8T
    07-10-2012 01:18 PM #10
    17551/P1143/004419 - Load Calculation Cross Check: Upper Limit Exceeded
    Possible Solutions
    Check Mass Air Flow Sensors (G70)
    Check Throttle Pedal
    Check Throttle Pedal Position Sensor (G79)
    Check Throttle Pedal Position Sensor 2 (G185)
    Check Throttle Body
    Check Angle Sensor 1 for Throttle Actuator (G187)
    Check Angle Sensor 2 for Throttle Actuator (G188)
    Check Engine Control Unit
    If that is a bosch clone mass meter, then that will be your problem..
    I've had many cheap mass meters and they don't last long so i got a genuine bosch one, it was a re-manufactured one and the box had the bosch holograms on it.
    Diagnostic technician and conspiracy theorist.
    www.infowars.com www.davidicke.com
    Fixed the infowars link.
    Alex jones powered by the souls of the founding fathers!
  11. 07-11-2012 04:51 AM #11
    Cloned re-manufactured parts should be considered terrorism here.
    STOP FOD!
    Give before it hurts!
    http://www.fodcontrol.com/foreign-object-damage.html
  12. Member aircooled56's Avatar
    Jul 6th, 2006
    San Luis Obispo
    2004 R32
    10-12-2012 02:15 PM #12
    I'm curious for any more help on this matter. I'm dealing with the same problem after years of no MIL on after recently cleaning my throttle body. Really sucks
    .:R32 RennSport
    Buttonwillow #13 2:02.411 Laguna Seca 1:45.485 Willow Springs 1:39.762
    www.usrallyteam.com For all of your hardcore racing needs!
    www.Speedhunters.com
  13. Member FuturaYell00's Avatar
    Apr 11th, 2004
    Eastside/Seattle
    10-12-2012 02:34 PM #13
    Months later, my MIL comes and goes, it even goes off for periods over 1000 miles then it randomly comes back. It's a total mystery to me, I still don't know whats causing it. Hopefully someone else can chime in with some more help...
  14. 10-12-2012 04:18 PM #14
    If you have the correct authentic MAF, then you must have a very so slight vacuum leak, an aftermarket coil pack, wrong plugs heat range, or worn, aftermarket OXS sensors or modified exhaust.
    Reversed vacuum line?
    Even a new OEM MAF can be bad, please don't forget they are junk to begin with.
    Did you get the firmware update needed?
  15. Member aircooled56's Avatar
    Jul 6th, 2006
    San Luis Obispo
    2004 R32
    10-13-2012 08:18 AM #15
    What firmware update? For what? How do you reverse a vacuum line? There are so few to begin with. Ill start with replacing vacuum lines as that seems most likely in my case.
    .:R32 RennSport
  16. 10-13-2012 11:04 AM #16
    Component: MOTRONIC ME7.1 G V04 <<<<
    This one when referencing this post, not you because, you have not posted an auto-scan.
    Lines can be hooked up in reverse for this application, I see it often.
    Wanna post a scan or start your own thread?
