Results 1 to 20 of 20
Thread: a noobie lamin-x application tutorial (plenty of pics!)
  1. Semi-n00b BlackPearlGti's Avatar
    Oct 14th, 2009
    2012 GTI Deep Black Pearl
    07-07-2012 10:38 PM #1
    Im sure there are a million of these, but I get so excited doing anything to my GTI so why not. Lamin-x gives a pretty good tutorial themselves on application, but i wanted to show a gti specific application..
    Stock GTI for the most part...
    find a shady spot...dont want to do this in the Florida sun
    Photobucket
    fogs on
    Photobucket
    closer view
    Photobucket
    some items you will need. water, razor, and lamin-x of course. The instructions provided said that for small applications such as this you would not need to use water, but i found it much easier with water
    Photobucket
    clean fogs real well. any bug guts or dirt/mud you definitely want to remove
    Photobucket
    Photobucket
    Photobucket
    go ahead and open laminx package and separate each film and set the one you are not applying aside
    Photobucket
    Photobucket
    size it up
    Photobucket
    wet the fogs and the adhesive side of the film, its better to use a sprayer but i dont own one and was to eager so i just used some bottled water.
    Photobucket
    Photobucket
    Photobucket
    place the bottom side down first, and i used a credit card wrapped in a rag to apply and push out the bubbles
    Photobucket
    Photobucket
    push the film into all the edges as best you can
    Photobucket
    use a razor to cut the excess film and tabs, use the empty space as a guide
    Photobucket
    Photobucket
    my happy helper!
    Photobucket
    all done!
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Thoughts: The application was super simple and easy. You can apply and remove and reapply the film no problem. In retrospect i would definitely use a sprayer for the water instead of just pouring the water on there haphazardly. It worked for the most part but I am certain it would have made it a bit simpler when i needed to reposition the film. Lamin-x says that any tiny bubbles and haze will go away within a couple days to a couple weeks, but if you do a wet application and use a card to smooth out the bubbles while applying it shouldnt be a problem at all!
    2012 Black Pearl GTI | Seat Inserts | Yellow Lamin-x fogs | Toggle Switch Garage door hack
  2. Semi-n00b
    Jun 12th, 2012
    Fairfax
    07-07-2012 11:41 PM #2
    Great write up and thanks! Considering doing this mod in the near future!
    2012 CSG GTI Autobahn 6MT
  3. Member mark6kevin's Avatar
    Jun 22nd, 2012
    NJ
    Bagged '12 GTI
    07-08-2012 01:24 AM #3
    nice
    work hard. drink harder.
    instagram: itznj
    my photo thread.
  4. Member
    Jul 27th, 2011
    slc ut
    01 2.slow, 03 1.8t, 09 gti(RIP) 2010 GTI, 2011 GTI stage 3+ :D
    07-08-2012 01:30 AM #4
    i did exact same application and i developed bubles a week later
    APRKo4, vogtland 50mm springs, carbino 1+2, custom exhaust, some kind of wheels??
  5. Member InstantKarma's Avatar
    Jan 4th, 2005
    Kenosha, WI
    2010 GTI
    07-08-2012 02:07 AM #5
    did the same with mine a while ago... I love the look on darker cars
  6. Semi-n00b BlackPearlGti's Avatar
    Oct 14th, 2009
    07-08-2012 10:41 AM #6
    i agree, lamin-x with dark cars are great. Nice wheels you have, VMR's?
    Jul 25th, 2011
    SO.MISS
    2011 GTI
    07-08-2012 11:04 AM #7
    the only thing i cut off were the tabs...and i did that before i went outside. Pretty much cleaned, watered, applied, pressed the edges into the small gaps around the light. looks great 3 months later.
  8. Member rhodri45's Avatar
    Feb 19th, 2012
    Chucktown SC
    static mk6 GTI, variable mk3 GLX
    07-08-2012 11:17 AM #8
    Quote Originally Posted by ohsnapzombies View Post
    same here. love it.
    I've seen hookers with less gap.
    Click here for lulz. ~
    mk6. | Instagram @rhodri45 | Chucktown Dubs.
    Feb 3rd, 2012
    Nashville TN
    2001 jetta wolfsburg, 2012 GTI
    07-08-2012 11:20 AM #9
    Looks nice, one of my things to do on my list when I finally start making the car my own.
    By the way I noticed A couple of things, do you happen to be in the army?
    101 ABN (AASLT)
    2012 GTI
    APR STAGE 2, APR CARBONIO, EUROJET TBE, NEW SOUTH VENT BOOST GAUGE, COLOR MATCHED SIDE MARKERS, EUROCUP HOLDER
  10. Member InstantKarma's Avatar
    Jan 4th, 2005
    Kenosha, WI
    2010 GTI
    07-08-2012 01:29 PM #10
    Quote Originally Posted by westcoastdsh View Post
    Bremmers
  11. Semi-n00b BlackPearlGti's Avatar
    Oct 14th, 2009
    07-08-2012 01:49 PM #11
    Quote Originally Posted by Sleepysapper View Post
    i am, how'd you know?
  12. Member Rresetrrewind's Avatar
    Jul 23rd, 2011
    Connecticut
    '07 GTI
    07-08-2012 02:26 PM #12
    Bracelets. lol. I noticed it too.
    Quote Originally Posted by OEM+ sluts View Post
    Slam it, treat it like s*** and break stuff.
    Tumblr | instagram@rresetrrewind | Timeline | AccuAir
  13. Member
    Feb 3rd, 2012
    Nashville TN
    07-08-2012 04:06 PM #13
    bracelets, watch, your girls arm band and what looked like running shoes. I guess people in the service just always stand out once you've been in a while yourself.
    101 ABN (AASLT)
    2012 GTI
  14. Member ina04gli1.8t's Avatar
    Sep 23rd, 2010
    Coral Springs, Fl.
    2012 United Gray K04GTI 91 triple black Carrera 2
    07-08-2012 07:02 PM #14
    This is the first thing I did after window tint. I went darker on the headlights & think the fogs look much better with yellow bulbs. Nice write up though
    | 2012 United Gray|Two door | MT | Eurojet Catless TBE | Carbonio Intake 1&2 | APR K04 |.APR Intercooler| BBS LM's | H&R Ultra Lows|VWR short shift | Southbend Stg.2 Endurance Clutch| Red Footwell lighting|Autotech Insert |Rear Wiper Delete | Vag-Com Tweaks courtesy of Mike |Podi boost gauge|euro switch|
  15. Member
    Aug 2nd, 2009
    Butler, PA
    '12 GTI
    07-08-2012 10:14 PM #15
    Did mine the day I got the car, only other advice I have is this.
    Don't be hideously hungover.
  16. Member
    Aug 24th, 2010
    Montreal
    2011 CSG GTI
    07-08-2012 11:22 PM #16
    Did the fogs with relative ease and came out great.
    Did the tails twice and was an uber bitch - was not satisifed with the results. Second time doing them I tried to be as obsessive compulsive as possible and followed all tutorials and online tips but they just didn't come out as well as I wanted.
    Maybe I am a perfectionist but the pre-cut lamin-x seemed too small and never sealed as well as I would have liked in some places.
    I am going to get them professionaly tinted at this point. Anyone know a good shop in Montreal?
  17. Member pi ka chuuu's Avatar
    Dec 14th, 2009
    where oranges grow
    golf 5
    07-09-2012 06:41 AM #17
    i did this to mine as well. although, i have a 5th gen and the fitment wasnt as good on mine as it was on yours. I almost felt like it was a mistake on lamin-x's behalf. the film was too small and didn't cover the whole fog light. I still run it like that but oh well. I'm glad yours came out good though, looks great
  18. Junior Member
    Aug 12th, 2011
    Cincinnati, OH
    2011 GTI 4Dr 6MT
    07-09-2012 07:31 AM #18
    Good timing on this post ... ordered Lamin-X over the weekend for my '11 !! Thank you !
  19. Semi-n00b BlackPearlGti's Avatar
    Oct 14th, 2009
    07-09-2012 07:34 AM #19
    Quote Originally Posted by MontrealJoker View Post
    lamin-x does sell whole sheets rather than precut films that way you don't have to worry about size issues... just another idea
  20. Semi-n00b BlackPearlGti's Avatar
    Oct 14th, 2009
    07-09-2012 07:38 AM #20
    Quote Originally Posted by pi ka chuuu View Post
    i agree the precut ones definitely cut it close on the size, i had maybe a millimeter or two around the edges and if you don't line it up well enough it could equal a bad application. But if you take your time...and i cant stress this enough...use a wet application, positioning it correctly can save your install
